Chain & Sprocket
ScaredyCat
PostPosted: 16:55 - 12 Feb 2015    Post subject: Chain & Sprocket Reply with quote
Please forgive the n00b questions but I've just been out to my bike to start prepping to ride to work again, thought I'd start riding again tomorrow but judging by this I wont.
Started to clean the chain, noticed a few links like this:
https://dl.dropboxusercontent.com/u/188253/_bcf/chains1.jpg
They are stiff and don't show much sign of moving when I use my fingers. The chain 'jumps' occasionally as I spin the rear wheel. I don't mean it jumps off the sprocket, I mean it flicks up momentarily as I spin the wheel.
The chain was fine before I stopped riding, mid December. I lube it after every ride. What's the likely cause? The links seem stiff the chain is very tight, no slack at all. The bike has been on its centre stand (appears to have seized a bit too Sad ) for the entire time.
Is the chain b0rked? This is what my rear sprocket looks like:
https://dl.dropboxusercontent.com/u/188253/_bcf/chains2.jpg
Is that ok (other than needing a clean) or classed as worn. Do you have to change sprocket & chain at the same time? Honda's quoted price for a sprocket and chain set is £184.14 then there's fitting on top, with a 1 hour scheduled time for the job. I need a new rear tye too Sad
Subframe might be twisted but chain definitely not slack..
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Minty
PostPosted: 16:59 - 12 Feb 2015    Post subject: Reply with quote
I'd oil it and go for a spin, see if the links loosen up.
My fingers smell of your mum.
PostPosted: 17:00 - 12 Feb 2015    Post subject: Reply with quote
You could try working the stiff links with some grease or oil and see if you can free them up but it's likely needing replacement.
For the figure you've been quoted to replace the set you could by a chain and sprocket set and a decent chain tool and do the lot yourself and then you'll save from each time onwards.
It'a a straightforward job.
davebike
PostPosted: 17:01 - 12 Feb 2015    Post subject: Reply with quote
That chain doesn't look good
NC700 c&S set not from Honda DID and JT sprocket from an independent £120 and 50 to fit
I give a a very good lub and see how much it pulls off the rear sprocket if not much ride it and keep it more lubed it will probable sort it elf out if not too worn
Dave
NC750Xdct + others at work !
[email protected]
Just_James
PostPosted: 18:54 - 12 Feb 2015    Post subject: Reply with quote
Sprocket looks ok to me.
Does the chain have a split link in it? If so I'd whip it off and leave to soak in a bucket of white spirit for a couple of hours then give it a good lube before refitting.
If you can't easily remove the chain then I'd do as others have suggested and just lube the hell out of it Thumbs Up
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
RhynoCZ
PostPosted: 19:07 - 12 Feb 2015    Post subject: Reply with quote
The chain is dead, the sprocket is alright. Definitely check the front sprocket though. Thumbs Up
Northern Monkey
PostPosted: 19:30 - 12 Feb 2015    Post subject: Reply with quote
Can you wiggle the stiff link with a pair of pliers? I'd get some thin oil on it, then wiggle the link to let it penetrate
andys675
PostPosted: 19:34 - 12 Feb 2015    Post subject: Reply with quote
try busters, they had street triple C&S kits on ebay the other day for £85 posted, or a chain for £75 and it was proper DID gold link stuff
mentalboy
PostPosted: 20:29 - 12 Feb 2015    Post subject: Reply with quote
+1 Thumbs Up
Easier if you can get it off but can be done in-situ, be prepared to give it some beans with the pliers. Save up for a new chain as it'll probably only get you another 6 months at the most, usage dependant.
As for replacement always do chain and sprockets together, if you only replace a worn chain the two older sprockets will wear out your chain much quicker -ebay every time, JT or DID (I have just purchased a JT set for the Zed for £100 out here Mr. Green )
Make mine a Corona.
SQL
PostPosted: 23:42 - 12 Feb 2015    Post subject: Reply with quote
Clean with diesel and it will be fine, I took my derbi chain from a right mess to very smooth with petrol diesel mix and a sponge.
Major Doss
PostPosted: 23:56 - 12 Feb 2015    Post subject: Reply with quote
Whilst some erstwhile members would suggest you make videos when you cleanse the rear end, may I suggest maybe laying off the soap when one is laying dormant for the cooler seasons? Keep your teeth and links nice and wet. I suggest this merely as your rear end looks ripe and clean for the summer. That chain is probably fine, dependant on your lubrication regimen. But, as always; replace C+S as a pair if chain fubar'ed.
TL;DR One minute ride around the block, lubricate, check function again after a 5 minute ride. You'll then know before you whip it off for a change of rubber.
BTW, tell Honda to fuck off re; labour, if they are changing the tyre.
Infact, diy. And lube it. Wink
The last post was made 11 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 70 Kb
