Top Boxes - Questions
captain_ramshackle
PostPosted: 14:37 - 13 Feb 2015    Post subject: Top Boxes - Questions Reply with quote
I've got a Givi top box that came with my bike and I have a few questions
1) Why is it possible to detach a locked top box and walk off with it? Doesn't this render it's locking ability slightly pointless
2) Why are they so expensive? The build quality seems pretty low.
3) Do people make top boxes that lock to the bike?
4) Do people frequently steal top boxes?
5) Are you happy leaving your helmet in your top box in a car park? If yes, is it because your box can't be removed while locked?
Taught2BCauti...
PostPosted: 14:59 - 13 Feb 2015    Post subject: Reply with quote
Hmmm... I have a Givi Top Box that came with my bike, and it definitely locks to the mounting plate that is bolted to the bike.
You have to turn the key, and press the top button to open the lid, or the bottom button to release it from the mounting plate.
As far as I know, all Givi Top and Side boxes work like this, as long as they are attached to the correct mounting plate.
I'm happy leaving all sorts of stuff in mine, as messing it causes the alarm to go off.
I would guess that with Givi, you are paying a bit extra for better quality materials - and perhaps a bit for the name.
I have seen cheaper brands that fade to grey in sunlight, and you could probably tear the lid open without too much trouble.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Baffler186
PostPosted: 15:02 - 13 Feb 2015    Post subject: Re: Top Boxes - Questions Reply with quote
1) Mine was not like this, it was a cheapo one but could only be unscrewed from the inside.
2) Never had an expensive one.
3) I thought all of them did
4) Don't know
5) I would never leave anything of value in it, no matter how secure the top box seemed. Same reason I would not leave my wallet in a car glove compartment - thieves will chance it if desperate
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
UncleFester
PostPosted: 15:02 - 13 Feb 2015    Post subject: Reply with quote
Sounds like you might have the wrong box on the wrong plate - i have two Givi boxes both need different mounting plates. They only lock ( and are not removable once locked ) to the correct plate.
Dumb question - are you sure you're locking it properly?
2017 Z1000SX
barrkel
PostPosted: 15:05 - 13 Feb 2015    Post subject: Re: Top Boxes - Questions Reply with quote
All of the Givi topboxes I've used are locked to the plate when locked shut. The big red button (as it typically is) doesn't depress without the lock turned, and the big red button needs to be pressed in order to unlatch it from the base plate. Perhaps your lock mechanism is broken.
You probably think Givi is expensive because you haven't seen how much good OEM boxes cost. Givi is medium-priced. You pay a lot more for colour-matched ABS plastic with quality paint and finish.
Most do.
I've never had one stolen.
I would if it was for the cinema or something, but at work I take my helmet inside. That way, it's not cold or wet (from the morning ride) depending on the weather.
PostPosted: 15:08 - 13 Feb 2015    Post subject: Reply with quote
Can't detatch my boxes without using force or a key.
Happy to leave lid either locked inside or padlocked to grab rail/helmet lock depending on where I park and how paranoid I'm feeling.
In Manchester I try not to draw attention to my big red ducati, so leave the massive red panniers off and usually carry my helmet.
At a festival I won't leave the helmets out, I lock the helmets away so people don't use them as rubbish bins.
I'm sure top boxes get stole all the time...same as bikes.
Tax disc holders were expensive for what they were, topboxes are similar.
Thought that Givi did decent boxes....[shrugs]
mentalboy
PostPosted: 15:09 - 13 Feb 2015    Post subject: Re: Top Boxes - Questions Reply with quote
Catch not working properly, Givi's lock to their mounting plates.
Because that's what people are prepared to pay for them - market forces, etc, etc. Yup the build quality is fairly low but I think the same about the average motorcycle build quality compare to thirty years ago.
Yes, try Givi.
Not that I'm aware of but I'm sure it happens
Yes, yes
Owner/user of both Givi Monokey and Monolock topbox/panniers
EDIT: Not sure if the different box and plate scenario would apply. My panniers will not mount on the topbox plate and vice-versa (The panniers are sold as dual use so will mount as a topbox IF I had the right plate. That is to say Monokey and Monolock boxes cannot use the other's plate (despite having read someplace a while back that one would fit the other)
Make mine a Corona.
orangepeeleo
PostPosted: 15:15 - 13 Feb 2015    Post subject: Reply with quote
Mine locks to the base, can't pop the red button and remove it without unlocking it first, I know this because the cover I bought is too small for bike+topbox so I have take it off every night to cover my bike up Embarassed
I always keep my gloves/lid and buff in there whenever I'm not on the bike, whether my topbox is in my kitchen cupboard or on the bike when parked outside work/ASDA
Bikes : HN125 (sold) - Lexmoto ZSX 125 (Stolen!) - Currently bimbling on : '10 YBR
PostPosted: 15:54 - 13 Feb 2015    Post subject: Re: Top Boxes - Questions Reply with quote
UR doin it rong.
Buy a Lextech one then.
Everyone does. Mine bolts in from the inside with a bolt that anyone with a crowbar could pop without breaking stride.
Can't say I've ever heard of one being stolen or broken into.
Yes, yes, and because it's below the value where I'd care.
captain_ramshackle
PostPosted: 16:00 - 13 Feb 2015    Post subject: Reply with quote
Then it seems my top box has a fault (went down and checked)
When locked the button you press to unclip it from the tray moves freely. You can't get into the box so it is locked.
ADSrox0r
PostPosted: 16:20 - 13 Feb 2015    Post subject: Reply with quote
It's already been said but believe me, third party luggage is nowhere near as expensive as OEM colour matched.
Take a look at how much my full pannier, top box and rear rack costs (Not for the faint hearted) It was one of the reasons I made sure when buying second hand it came with the touring kit, it's worth a mint alone.
https://bikes.honda.co.uk/motorcycles/my-bike/accessory-brochures/_jcr_content/par1/textcolumnwithimagem_12/textColumn/richtextdownload_dab/file.res/HUK%20MC%20HGA%20VFR800F.pdf
orangepeeleo
PostPosted: 16:25 - 13 Feb 2015    Post subject: Reply with quote
Shocked
UncleFester
PostPosted: 16:29 - 13 Feb 2015    Post subject: Reply with quote
When you lock it and clip it on, does it sound like it has locked but just pops off with little effort?
I think you may have either a broken lock or the wrong box for that base.
2017 Z1000SX
captain_ramshackle
PostPosted: 16:41 - 13 Feb 2015    Post subject: Reply with quote
Nope. It clicks down firmly and is solidly attached. I've checked and the base plate is a Monolock which is meant to be used with the top box.
mentalboy
PostPosted: 17:44 - 13 Feb 2015    Post subject: Reply with quote
I have had occasion to remove the locking system on my Monolock topbox in the past because it gets gummed up with roadmuck quite easily and eventually reaches a state that makes the button almost impossible to push open and the catch jams up.
Remove the lock, clean it up and whilst it's out check the movement of the locking arm against the button for removing the box from it's mount.
Make mine a Corona.
Nash GT
PostPosted: 18:21 - 13 Feb 2015    Post subject: Reply with quote
As above, if anything I've had problems taking it off when it has been on the bike for long periods of time as the locking mechanism gets covered in road shite, salt, grime etc.
It is quite sturdy and has never given me reason for concern, helmet and gloves get left inside at work
Suzuki GSF600N
talkToTheHat
PostPosted: 01:29 - 14 Feb 2015    Post subject: Reply with quote
Take the mechanism apart and clean it. It should lock onto the bike with a positive click and not be removable without pushing the button which requires the key be in the unlocked position.
I bought a second hand givi e45 just over two years ago, I had to clean a sticky mechanism as it had a habit of coming loose on the go and throwing the topbox down the road, which is proper scary when it throws you off balance cornering on a wet slippery road. I greased the mechanism with a little rubber grease. Its been fine since but I check carefully. E45 Topbox is indestructible. It was battle scarred when I got it, and since then has fallen off twice as described above and survived a few careless falls and a rear ending that bent or scraped most of the shiny bits on the bike.
Bandit. does. everything.
PostPosted: 11:07 - 14 Feb 2015    Post subject: Reply with quote
And if it doesn't behave, just bolt it onto the mounting plate unless you have a pressing need to keep removing it.
Taught2BCauti...
PostPosted: 11:43 - 14 Feb 2015    Post subject: Reply with quote
You should feel a noticeable difference when you push in the bottom button, when the key is in the 'Lock' and 'Unlock' position.
If not, there is a possible fault with the internal locking cam. It's plastic, so it can break - but they are easy to take apart and repair or replace parts.
Have a look at This Website for spare parts available, or search on Google / eBay for "Givi Spares".
You might have to buy a set of parts to get what you want, but you can always re-sell the bits you don't use - it would be cheaper than a new box.
captain_ramshackle
PostPosted: 13:22 - 14 Feb 2015    Post subject: Reply with quote
That's sort of what I was thinking.
ScaredyCat
PostPosted: 13:42 - 14 Feb 2015    Post subject: Re: Top Boxes - Questions Reply with quote
Limited sales.
Relatively low numbers of riders, not all riders will buy them and those that do will take the panniers and topbox with them for their next bike, meaning they only have to buy the frames next time.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
talkToTheHat
PostPosted: 01:38 - 16 Feb 2015    Post subject: Reply with quote
Compared to the cheap ebay topboxes I've seen, my e45 is built like a tank. I have some Kappa branded E21/K21 boxes on they way that came in at about £80 for the pair, which is dirt cheap for givi/kappa. Will no doubt comment on the quality or lack of.
I suspect a large fraction of the price is transport and dealer floorspace consumption. They're significantly cheaper than Hepco & Becker or Metal Mule. I think Krauser have been resurrected but i'm not convinced by recent online offerings.
What other competition is there that isn't a frangible box and some meccano?
mentalboy
PostPosted: 04:55 - 16 Feb 2015    Post subject: Reply with quote
Kappa are basically a budget version of the Givi brand, produced in the same factory that makes Givi boxes (IIRC) by the daughter of the Givi owners and I believe constructed in exactly the same way as the Givi boxes!!
Make mine a Corona.
weasley
PostPosted: 08:32 - 16 Feb 2015    Post subject: Reply with quote
Well there's Nonfango, if you can find it.
The last post was made 11 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.72 - MySQL Queries: 13 - Page Size: 133.03 Kb
