My Bandit.....
mudcow007
PostPosted: 14:17 - 13 Feb 2015    Post subject: My Bandit..... Reply with quote
Now, some of you may be aware i bought, well basically got given a Bandit 2 years ago, i fiddled with it an got it going all for about 400 miles to then have it cough & fart an basically stop working.
The symptoms the bike had when i put it away last year were.
a misfire on 4th cylinder an occasionally on 2nd cylinder, sooty plugs etc with erratic idling
This year i aim to get the beast working like a "normal" bike.
i have already....
refitted factory exhaust, new coils, plugs & caps, air filter, inlet o rings, new tank, valve clearances and....
...cleaned the carbs - god knows how many times using compressor & following pete's guide an reset to factory spec
Now there's nothing to say something i have done isnt causing it, but i dont want to shell out more wonger on a dead horse.
Any ideas where i should be attacking first?
fanks
PostPosted: 15:00 - 13 Feb 2015    Post subject: Reply with quote
Have you done a compression test?
mudcow007
PostPosted: 15:02 - 13 Feb 2015    Post subject: Reply with quote
not yet, but i did buy a compression tester, will have a go at that
just unscrew a plug, put the adapter in an crank?
Matt B
PostPosted: 15:38 - 13 Feb 2015    Post subject: Reply with quote
Generally accepted practice is to remove all of the plugs and crank.
Would be good if you could stop fuel and sparks too.
mudcow007
PostPosted: 16:25 - 13 Feb 2015    Post subject: Reply with quote
cheers, findings to follow.....
Nobby the Bastard
Harley Gaydar
PostPosted: 17:18 - 13 Feb 2015    Post subject: Reply with quote
Put some fuel in.
Triumph Sprint ST 1050
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
pdg
PostPosted: 18:02 - 13 Feb 2015    Post subject: Reply with quote
Soylent Blue wrote:
I bet it's not a compression issue. In fact i would bet my house on it.
Is it a nice house?
Also, a compression test tells you everything these days, even why your headlight bulb keeps blowing.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
PostPosted: 18:18 - 13 Feb 2015    Post subject: Reply with quote
cleaning carbs with just compressed air is not going to work. You need some sort of solvent to get to work on the jets.
pdg
PostPosted: 18:50 - 13 Feb 2015    Post subject: Reply with quote
Or, you could poke a bit of wire through the jets to clear them out....
Don't do that
Nemo
PostPosted: 19:59 - 13 Feb 2015    Post subject: Reply with quote
If you do the compression test, do it with the throttle fully open.
Did you do anything with the mixtures?
Did you check the condition of the diaphragms in the carbs end condition of the needles?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
mudcow007
PostPosted: 22:22 - 13 Feb 2015    Post subject: Reply with quote
carbs were cleaned with carb cleaner, then ended up using 100% acetone (get it from work), they were squeaky clean
will try an do a compression test tomorrow
cheers chaps
PostPosted: 11:16 - 14 Feb 2015    Post subject: Reply with quote
Clean the carbs properly.
My Bandit ran similar. It has some silly problem where it just leaked from the cylinders...
The last post was made 11 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 75.86 Kb
