new foam sheet Air filter element - cut to size query
316lad
PostPosted: 10:45 - 14 Feb 2015    Post subject: new foam sheet Air filter element - cut to size query Reply with quote
Hi,
I ordered a flat sheet of air filter element to cut to size on the filter frame in the air box - it's cone shaped and easy to do.
My foam element sheet is grey foam one side with a thin denser more fibrous material on the other side.
Question is; does it matter which side faces in or out once I've made it into a cone; i.e; denser side in towards carbs, etc?
Cheers lads,
WD Forte
PostPosted: 10:53 - 14 Feb 2015    Post subject: Reply with quote
It may not matter but I think I'd go coarse filtration outer,
finer filtration inner ( carb side) as a general rule.
bikers smell of wee
The Artist
PostPosted: 11:06 - 14 Feb 2015    Post subject: Reply with quote
I mean in reality it isn't going to make much of a difference but the finer stuff is more likely to clog so put that facing inwards.
316lad
PostPosted: 11:29 - 14 Feb 2015    Post subject: Reply with quote
Cheers for this...and oil up as usual?
lozzypop1
Certified MILF!
PostPosted: 13:05 - 14 Feb 2015    Post subject: Reply with quote
Agreed, Course outer.
Reason being, the more open cell structure catches larger pieces first, then the more dense material catches the smaller bits. If it was the other way around it would be more likely to block up quicker as the foam would be absorbing everything in the same place.
316lad
PostPosted: 22:00 - 14 Feb 2015    Post subject: Reply with quote
Thanks for this. Cheers.
Do you think the oiling of the element is now unnecessary as a result of this thicker skin on the inside?
PostPosted: 22:04 - 14 Feb 2015    Post subject: Reply with quote
Coarse outer, foam inner is the way Thumbs Up
sickpup
Old Timer
PostPosted: 23:08 - 14 Feb 2015    Post subject: Reply with quote
Always oil foam filters, helps trap smaller particles than the foam alone and means you can wash the foam and the oil carries any particles out of the foam.
316lad
PostPosted: 01:28 - 15 Feb 2015    Post subject: Reply with quote
Nice one Sickpup,
Cheers. Will do.
ws4936
PostPosted: 02:59 - 15 Feb 2015    Post subject: Reply with quote
This has just reminded me to wash-dry-oil my spare filter.
Looks like a wrecked fly cemetery.
If everything seems under control, you're just not going fast enough.
The last post was made 11 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 64.39 Kb
