| CBRMAN94 |
 CBRMAN94 Nitrous Nuisance
| stinkwheel |
 Posted: 12:11 - 15 Feb 2015 Post subject: |
Wheel alignment and symmetry. Pretty much has to be. The forks are rigidly clamped in there and have to move together.
Even if you took the damper entirely out of one fork leg, it would be equally bad in both directions. Some forks have compression damping in one leg and rebound in the other. Mountain bike forks sometimes have the spring in one leg and the damper in the other.
Check alignment again. Make sure you also have the front wheel in the middle of the bike (sapcers in correctly? Nipped up in the correct order?). Check the stanchions are dropped the same distance through the forks. Make sure both finished forks have landed up the same length.
Remember to loosen the mudguard bolts too when centering the wheel.
If you're still unsure, get the bike propped vertically (use a plumb line) on a level floor (use a spirit level), chalk out the centre line (runs between a line plumb from the centre of the steering and the centre of the swingarm) and check the wheels land up on the same line and vertical. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Skudd |
 Skudd Super Spammer
| CBRMAN94 |
 Posted: 13:59 - 15 Feb 2015 Post subject: |
It may well be that they aren't aligned because i didn't loosen the mudguard off Tires were fine last year so i can't see it being that ____________________ Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR |
| Skudd |
 Skudd Super Spammer
| CBRMAN94 |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 22:52 - 15 Feb 2015 Post subject: |
If everything's aligned ok then check cable routing and fork oil,jus a little extra fork oil can feckup the whole plot......except on cg s of course. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| CBRMAN94 |
| Fizzer Thou |
 Posted: 22:54 - 16 Feb 2015 Post subject: |
The amount of oil in the forks will mainly determine the air gap.This is usually specified in the workshop manual and is more important than the amount.There is usually an upper and lower limit.
I use a hand pump from a soap dispenser,with an extension tube cut to the right length for the air gap depth
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture485.jpg
This makes for a quick and easy method of removing any excess oil from the forks.
Check also that the preload,compression and rebound clickers are set the same number out on each leg  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| stinkwheel |
 Posted: 13:28 - 17 Feb 2015 Post subject: |
I'd suggest (again) not focusing on the settings OR the oil.
Different amounts of oil in each fork leg isn't going to make it steer better one way than the other, it'll just screw up your damping which would affect the bike going either direction.
When everything is bolted up tight, the forks have to move together as a single unit regardless of their damping, oil content or spring rate. Unless we're suggesting one fork leg can move a shorter distance than the other with all the clamps done up?
So. If you are getting handling problems only to one side, it is down to the physical symmetry of the bike, not the amount of oil in the forks or the suspension settings.
Once again, many bikes deal with the rebound damping in one fork leg and the compression damping in the other.
EDIT: Are your handlebars straight? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| 316lad |
 316lad Borekit Bruiser
| CBRMAN94 |
 Posted: 20:55 - 17 Feb 2015 Post subject: |
Bars have never been straight from previous owners dropping it (and me ) As far as i can tell they are as good as they can be. I'll have another so on Saturday loosening everything off below the top yoke as i only loosened the bottom yoke and mudguard last time  ____________________ Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR |
The last post was made 11 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
