| Tritey |
 Tritey Banned
 ........................ Spanner Monkey
| Bikeless |
 Bikeless World Chat Champion
| finchy95 |
 finchy95 Scooby Slapper
| finchy95 |
| haroman666 |
 haroman666 World Chat Champion
 Posted: 20:20 - 15 Feb 2015 Post subject: |
Carbs can seem daunting but in reality aren't too bad (unless you're going for the full pull apart and retune)
Cleaning will be a piece of piss.
You could probably get away with getting the carbs off, cleaning out the float bowls and spraying carb cleaner up the main jets and see if it makes a difference.
Here's a video I made of me pulling apart my Bandit 400 carbs, may be of help: https://www.youtube.com/watch?v=JcE3h4Mats8
I do apologise for any shit jokes and monotone voice! ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 20:41 - 15 Feb 2015 Post subject: |
If you don't want to do it, take them out yourself and find someone with an ultra sonic cleaner?
Maybe cheaper than getting a garage to take them out, strip, clean and put back in ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| andym |
 andym World Chat Champion
| kramdra |
 kramdra World Chat Champion
 Posted: 22:01 - 15 Feb 2015 Post subject: |
Nope, best to strip and clean the insides. Toolstation carb cleaner is only 2 quid a can, as is brake cleaner (useful but wont work on carbs). Leave the linkages and everything external alone, doesnt matter that much. Do not remove the plastic fuel T peices, I'm told they are fragile and expensive. Make sure carb intake rubbers dont leak.
Diaphragms on the top, get them out, inspect, and keep well away from carb cleaner. They are expensive bastards and it eats rubber
Buy a couple of aluminium pill bottles from ebay. They have quite a good seal. This means you can put your jets in, spray a shit ton of carb cleaner, and it wont evaporate, allowing them to soak. 24 hours is quite effective. Copper wire is soft, wont damage brass jets. Its quite good for removing the stubbon bits that carb cleaner has softened.
Then the choke and idle systems need a good spray. Use a foot pump to check they are not blocked. Make a note of turns on pilot screws, compare with manual.
Old float bowl gaskets probably need replacing. NBR rubber cord and superglue worked for me, but most dont like that idea. Carb kits are expensive.
Before reassembly, rub the metal part of float needles with aluminium foil to prevent them from sticking. It works very well.
JIS screwdriver is a good idea, or replace with allen head. |
| Paddy Blake |
 Paddy Blake World Chat Champion
| Tritey |
 Tritey Banned
| cb1rocket |
 cb1rocket World Chat Champion
The last post was made 11 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
