My chain needs tightening, help?
KM85
PostPosted: 14:33 - 17 Feb 2015    Post subject: My chain needs tightening, help? Reply with quote
Hi guys,
I ride Honda CBF125
I just took my bike out the shed from Winter, its been about 3 months since ive last been on it. Actually, its been since my auntie came off of hers and broke her hand.
Doing an inspection before going out on it, i noticed that the chain was quite "droopy".
I watched Youtube tutorial but i didnt feel confident going ahead and trying it myself. Any other ideas? Id preferably like to take it somewhere and watch them do it so i can see how its done then do it myself.
Any input would be great, thanks in advance.
Kyle
Dcwhite1984
PostPosted: 14:38 - 17 Feb 2015    Post subject: Reply with quote
It's not difficult, just loosen the rear axle bolt, then you should have an adjuster each side of the swingarm, make sure you wind these equally, i normally do half a turn or quarter of a turn at a time untill i get the required play in the chain.
Once your chain is sorted then tighten the axle bolt to the correct torque.
Im sure if theres someone on here near you then they'll pop round and show you Smile
Or if you know a local garage im sure they wouldnt mind you popping it down there but could be a bit dodgy to ride it if its really loose.
The trick to life is to not get too attached to it.........
Itchy
Seriously it is a case of 3 bolts. The spindle and the adjusters.
Undo the spindle, give the adjusters on both sides 1/4 of a turn with an 8 spanner check the tension too slack do it again. Do not over tighten as when you sit on it and do up the spindle/axle it will tighten up.
The only side effects if you get it wrong are accelerated and asymmetric wear. Unless you've got it so badly adjusted that your wheels are way out of alignment.
PostPosted: 14:42 - 17 Feb 2015    Post subject: Re: My chain needs tightening, help? Reply with quote
Feel confident. Believe in yourself. Ride the rainbow.
It requires basic tools and methodology.
There are all sorts of ways of measuring alignment, but you won't need them if it's already aligned. Just adjust by the same amount each side.
Don't forget to tighten everything up, job's a good 'un.
Maybe a nearby BCFer can give you a han - fu​ck, he's in Glasgow - give you some more specific advice. Whistle
Itchy
PostPosted: 14:47 - 17 Feb 2015    Post subject: Reply with quote
Ahh a bit OT but does anybody remember the old days?
We'd have a crack at it ourselves and when we messed it up THEN we'd take it to a mechanic who would subsequently tut and moan at us for our ineptitude... but more often than not what we did worked.
Itchy
PostPosted: 14:48 - 17 Feb 2015    Post subject: Re: My chain needs tightening, help? Reply with quote
Rogerborg wrote:
in Glasgow[/i] - give you some more specific advice. Whistle
https://www.youtube.com/watch?v=K5lYXaVkA0U
KM85
PostPosted: 14:55 - 17 Feb 2015    Post subject: Reply with quote
Cheers guys!
Just new to riding so I didnt really wanna go ahead and fuck it up for myself. I'll wait till a sunny Sunday and get out and try it myself!
There's nothing wrong with Glasgow, I'll maybe try and punch you but that's pretty much our way of saying thanks!
Also, should i tighten the bolts up to the point of which they are at just now?
PostPosted: 15:09 - 17 Feb 2015    Post subject: Reply with quote
Good plan....
... but the first sunny Sunday will be in June. Whistle
https://cbf125rider.files.wordpress.com/2011/10/cbf125_chassis_torques.pdf
Rear wheel spindle nut = 54Nm
That's a good grunt, maybe a grunt-and-a-half, while hauling on about 10" of spanner or socket bar.
Actually, while you're at it, it'd be a good opportunity to take the nut off, clean up the spindle and apply some copper anti-seize.
316lad
PostPosted: 20:01 - 17 Feb 2015    Post subject: Reply with quote
If you have a nice metal ruler - or tape measure - use it to measure the amount of bolt exposed outside of the nut on each side chain tensioner to ensure you're keeping the back wheel straight on the swinging arm.
Chain should have about 20mm up and down at mid-way along it's bottom length.
Then, tighten the axle back up (to Grunt and a half as specified above) and you're good to go.
1198
PostPosted: 21:21 - 17 Feb 2015    Post subject: Reply with quote
If you have a reasonably straight edge (I use a wooden stick) use it against first the left then right hand sides of the rear wheel then measure the gap to see the two wheels are lined up true. It'll make little if any difference to the ride or handling but it'll stop an ultra keen (ultra anal?) mot tester failing it on wheel alignment.
316lad
PostPosted: 21:56 - 17 Feb 2015    Post subject: Reply with quote
I think this is an irresponsible post.
Bad wheel alignment can cause - at the least - excessive uneven tyre wear - and at worse - fundamentally and detrimentally effect the riding characteristics of the bike to an unsafe degree.
Just measure it as best you can with a straight edge; be as accurate as you can.
Forget MOT testers - you're doing this for you, your ride and your safety.
The last post was made 11 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 74.82 Kb
