Not starting
edb
PostPosted: 16:24 - 17 Feb 2015    Post subject: Not starting Reply with quote
Hi all,
Apologies for yet another thread about a bike not starting. I've searched on here and other forums but so far haven't had any luck with a solution Sad
My bike:
2004 Honda Hornet
My problem:
It wont start!
Bike hasn't really been sat over winter, just hardly ridden.
I took the tank off so that I could adjust the throttle return cable, and other than that (which started sticking out of the blue) I've only had a problem where it wasn't holding charge.
What I done tried:
- Took the tank back off, checked everything was plugged in to all the right places. No kinks in any hoses, tank wasn't resting on what I believe is the breather hose? I had forgotten to connect the electrics up from tank to bike before trying first time, could this cause a problem despite being reconnected now?
- I thought maybe I'd knocked the idle speed adjuster? Can't see how though now I look at it.
- Topped up with petrol thinking maybe I'd drained it all by trying to start it. No change.
- Drained the float bowls. Honestly no idea what this is for, but a total of about 10ml petrol drained out altogether.
- Had a go at checking the plugs. They look right according to Mr. Haynes. I could only check 1 and 4 because I can't reach 2 and 3, but they're sparking.
- Battery was fully charged and any attempts to start I've done whilst connected to a Datatool
So I'm stumped. I'd be really grateful of any help!
mentalboy
PostPosted: 16:37 - 17 Feb 2015    Post subject: Reply with quote
What do you mean when you say 'battery isn't holding charge'?
Despite all of your tinkerings the simplest answer is going to be a dead battery. A battery can hold a charge and even sound like it's turning the starter over, how old is the battery - on a bike used daily I'd expect about 4 years out of a battery, I've a mate with one that does very little for 8 months a year and he's replaced the battery every Spring for the last three years.
The reason you'd drain the floats is twofold - condensation can accumulate and make starting a beggar and fuel (especially modern ethanol fuels) go stale very quickly, I've had fuel sit in a bike for three months and it wouldn't start until it had a fresh tank.
Make mine a Corona.
edb
PostPosted: 16:45 - 17 Feb 2015    Post subject: Reply with quote
Thanks for the reply.
It's just what the RAC man said. The bike cut out whilst going through some traffic. Wouldn't even bump start. This followed on from a few months of occasionally having to bump it, then charging every night.
So when it did die, he put some charge in it and did some electrickery which he said shows it's "not holding charge". I've read that the reg/rec is a common Hornet problem, so it might be this?
I've had the bike for coming on 4 years, and not replaced the battery. I don't know if it has ever been replaced.
I'll give it a shot with a new battery then. I just thought that especially being fully charged (and connected to a charger) it wouldn't be a battery issue...
Thanks for the help
ETA - I forgot to mention that it sounds like it's turning over, and once it even sounded like it was briefly about to burst into life. Usually just ends up draining the battery though.
mentalboy
PostPosted: 16:51 - 17 Feb 2015    Post subject: Reply with quote
edb wrote:
... he said shows it's "not holding charge".
That is 'common speak' for 'your battery's f**ked'.
Make mine a Corona.
PostPosted: 17:06 - 17 Feb 2015    Post subject: Reply with quote
Got a car battery you can try using with jump leads? If she cranks and fires up, new battery time brah.
edb
PostPosted: 17:25 - 17 Feb 2015    Post subject: Reply with quote
Sorry to sound ignorant, electricals really aren't my thing, but would it still be the battery even though it's fully charged and connected to a charger?
edb
PostPosted: 17:27 - 17 Feb 2015    Post subject: Reply with quote
I'll have to give it a shot, mind you I haven't thought to try and bump start it...
mentalboy
PostPosted: 17:32 - 17 Feb 2015    Post subject: Reply with quote
Can I ask how long ago it was that the RAC man told you the battery was knackered?
Why would you think that you could start a machine with a battery charger - the clue is in it's name!
You can do whatever anyone else suggests but you've already been told by someone who's tested the battery that it's knackered, quit farting around and get a new battery.
Make mine a Corona.
PostPosted: 17:33 - 17 Feb 2015    Post subject: Reply with quote
Wouldn't attempt a bump start, I'd definitely start with the massive power from a car battery first. I am getting fat however. Laughing
edb
PostPosted: 17:35 - 17 Feb 2015    Post subject: Reply with quote
Haha fair enough. I just have it in my head that it's plugged in, it should work Shocked
It would have been some time around June I had the issue, but it was my only mode of transport so with it on charge every night I never had issues after that day.
mentalboy
PostPosted: 17:38 - 17 Feb 2015    Post subject: Reply with quote
Yup, then when that fails try a Transit van, then a lorry, then an earth-mover. Fuck it, why not just hook it up to the National Grid.
I'm out. Brick Wall Brick Wall Brick Wall
Make mine a Corona.
PostPosted: 18:46 - 17 Feb 2015    Post subject: Reply with quote
National grid said no Sad
Skudd
PostPosted: 21:34 - 17 Feb 2015    Post subject: Reply with quote
What people are trying to say is................. NEW BATTERY TIME.
Ariel Badger
PostPosted: 23:37 - 17 Feb 2015    Post subject: Reply with quote
If only 10ml of fuel came out of the carbs then you have a problem with fuel delivery.
And you need a new battery.
edb
PostPosted: 12:14 - 18 Feb 2015    Post subject: Reply with quote
So genuine ignorance and many lolz aside, I just thought it might hold the charge while I tried starting. Live and learn Smile
I'll get myself a new battery then. It had been mentioned to me that the reg/rec was the fault, could a new battery be damaged if it was the reg/rec?
Baffler186
PostPosted: 14:06 - 18 Feb 2015    Post subject: Reply with quote
Yes it can, you can check the reg/rec with a multi-meter, there are some Youtube videos on how to do it. Do that first, or you could fry your new battery. Also bulbs blowing are a sign of reg/rec failure, but that shouldn't be used as the test.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Skudd
PostPosted: 16:13 - 18 Feb 2015    Post subject: Reply with quote
EVERY time I have had a flat battery the expert in the corner says reg/rec. You know how many times over 30++++ years of riding that have needed one. a big fat ZERO. New battery time.
edb
PostPosted: 16:24 - 26 Feb 2015    Post subject: Reply with quote
Thanks so far guys. Unfortunately still no luck.
I've put in a new battery. One of the DIY acid ones, filled (tiny bit of brown trousers when I took the empty acid bottle off and spilt a bit), charged overnight with a Datatool and then left for 6 hours off charge.
After the 6 hours it was still at 13V. Installed with headlights on it drops to 12.2V, drops to 10.6V when pressing the starter.
So back to square one. Can a problem with the side stand switch cause it? I've had it on a maintenance stand, side stand up, in gear with clutch in. Nothing happens. I'm sure I can normally start it in gear but I might be misremembering.
mentalboy
PostPosted: 16:31 - 26 Feb 2015    Post subject: Reply with quote
Have you tried to start it in neutral?
Make mine a Corona.
edb
PostPosted: 16:33 - 26 Feb 2015    Post subject: Reply with quote
Yes. I only tried it in gear out of desperation that something might work
mentalboy
PostPosted: 16:43 - 26 Feb 2015    Post subject: Reply with quote
Back to what Ariel said:- fuel delivery issue.
Not familiar with the Hornet but you need to check that fuel is leaving the tank, if it has a vacuum operated tap then make sure that the vacuum hose is connected and not perished.
Check that the fuel pump is actually delivering
Check condition of all fuel delivery hoses - I'm not sure if yours will have upgraded hoses but ethanol fuel trashed the hoses on my '94 machine, they went all gooey.
Once you've done those checks if nothing is improved then you'll be needing to get into the carbs.
Make mine a Corona.
edb
PostPosted: 16:59 - 28 Feb 2015    Post subject: Reply with quote
It lives!
So it turned out to be a fuel delivery issue, as suggested. The issue being that I'm an idiot that it turns out hadn't plugged it all back in. The vacuum hose was loose Embarassed Embarassed
Thank for all the advice though guys, really appreciated Thumbs Up Karma
The last post was made 11 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 2.66 - MySQL Queries: 13 - Page Size: 116.13 Kb
