Speedfight 100cc cuts out on full throttle?
stevie_
PostPosted: 19:59 - 15 Feb 2015    Post subject: Speedfight 100cc cuts out on full throttle? Reply with quote
Lately my Speedfight has been cutting out on full throttle, Once it cuts out it starts back up fine. I've been having a look around google and seems like it could be a Jet problem/Mixture problem.
Does anyone have any guides on the right settings for the carb, Also anyone no what the standard jet size is? i currently have a sports exhaust on i've been told i should increase jet size by 10% is this correct?
stevie_
PostPosted: 01:45 - 16 Feb 2015    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
Try looking for air leaks on the carb side and exhaust for starters
Sounds like a good shout, i'll have a look,
BMWilliams
PostPosted: 21:06 - 17 Feb 2015    Post subject: Reply with quote
Deffo sounds like the main jet if it bogs at full throttle
If you didn't upjet when you fitted the exhaust then yes upjet 10%
If that doesn't cure it then try a new plug and maybe a high performance coil
Start small and work your way up
A good long ride can clear your mind, restore your faith, and use up a lot of fuel.
Never ride faster than your guardian angel can fly.
Ride, eat, sleep...repeat.
BMWilliams
PostPosted: 21:12 - 17 Feb 2015    Post subject: Reply with quote
Iain.
PostPosted: 17:10 - 18 Feb 2015    Post subject: Reply with quote
I would check the vaccum feed to the fuel tap for cracks and leaks & test the tap operation, check the fuel line for blockages.
I'd check the fuel tank breather....and if after all of this checking out diddn't do anything I'd drain the fuel suspecting water contamination (put it in a clear container and let it settle to see)
If the plug is gammon'd then it'll not run at all. It'll just crank forever.
High performance coil? Factory ignition seems fine untill you're edging towards the 15hp mark on a 50cc bike, given the work required to get a 100 speedfight to that point, IMO a waste...
Unless its a seriously tuned pipe you can usually just adjust the mixture.
Nope, the mixture screw only adjusts the fuelling at tickover to maybe quarter throttle at best. You need to actually pull the carb apart and swap the main jet over to really adjust the fuelling as that affects a scooter between 1/4 throttle and full throttle, and a scoot you're mashed flat out all the time.
You are right however about the air filter. Piaggio 50cc engines go from requiring a 72 main with a sports exhaust to requiring a 115 main with a fancy air filter Laughing
The last post was made 11 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 53.57 Kb
