| Suntan Sid |
 Posted: 14:09 - 19 Feb 2015 Post subject: PJ1 Fast Black engine & case paint? |
Has anyone used PJ1 Fast Black engine & case paint?
I want to repaint the outer crankcases of my XL125.
A few questions:-
Not sure how many coats are required, will one can be enough to do two smallish crankcases?
The parts I want to paint will have to go back to bare metal, there are already a couple of layers of "repair" paint on there. After a bit of googling, there seems to be no concensus on whether a primer is needed or not, have you done this, did you prime or not and what were the results like? ____________________ "Everybody needs money, that's why they call it money!"  |
| chris-red |
| Suntan Sid |
| chris-red |
 Posted: 16:36 - 19 Feb 2015 Post subject: |
| Suntan Sid wrote: | | chris-red wrote: | I'd get it powder coated, if you just want them black and they can lump it in with other stuff they'll probably do it for ~£20. They'll blast it and you'll get a better finish. |
I could have them powder coated, but I'm not after a concours finish, cheap n cheerful will do. Just a thought, would powder coating affect engine cooling?
Wouldn't had thought so people do it all the time, plus it's an XL125, hardly a machine that would be affected by a few degrees.
Personally I think ~£20 for you to drop it off as is and a get better finish (not just looking but lasting) is much preferable to £13 for a tin of rattle paint, then time spent cleaning it up and actually painting it not to mention the chance is goes tits up because you ain't used lacqueror because the weather is shit for spraying atm. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| 316lad |
 316lad Borekit Bruiser
 Posted: 23:06 - 19 Feb 2015 Post subject: |
I wouldn't go the powder coat way either. It'll play havoc with your gasket seals of the crankcase covers on both sides - be them wet or dry!
I've had very good results with Halfrauds Engine Satin Black.
Build the coats up slowly (four to six with a gentle rub down between) allowing a good hour at room temperature between.
https://s28.postimg.org/8spuoa3st/IMG_2425_copy.jpg |
| Suntan Sid |
| 316lad |
| Teflon-Mike |
 Posted: 17:29 - 20 Feb 2015 Post subject: Re: PJ1 Fast Black engine & case paint? |
| Suntan Sid wrote: | Has anyone used PJ1 Fast Black engine & case paint? | Yes, a number of times.
| Suntan Sid wrote: | Not sure how many coats are required, will one can be enough to do two smallish crankcases? | Should be but wont be very thick.I'd do three on a cover like to get rubbed.
| Suntan Sid wrote: | The parts I want to paint will have to go back to bare metal, there are already a couple of layers of "repair" paint on there. | It's so 'thin' it will leave any sanding marks in the alloy... you may want to add a layer or too dependng how polished t is by the time its cleaned up.
| Suntan Sid wrote: | there seems to be no concensus on whether a primer is needed or not, have you done this, did you prime or not and what were the results like? | No Prime. But multi coats.ANd 'trick' BAKE'EM. Especially 'cool' parts like cases. Running, they wont get hot enough to self cure like finning will.
Where I have't been able to fit a whole engine in the oven... I've used a decorators paint stripper heat gun.
Results? Fair to Reasonable. To my eyes its a fair aproximation of a 'factory' black finish; not over shiney, while not the black-board-paint matt of BBQ black or old 'pot-blacking'. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| chris-red |
| Iain. |
 Iain. Could Be A Chat Bot
The last post was made 11 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
