Gilera RCR 50 Won't Kick
lukehanham
PostPosted: 16:45 - 19 Feb 2015    Post subject: Gilera RCR 50 Won't Kick Reply with quote
So i have a gilera RCR 50,
It's been sat in the winter under-cover for a few months.
So i can bump start it fine, however kickstarting does not work.
What repairs can i try myself, without risking doing any more damage?
Estimated cost on other repairs?
Tips and advice?
many thanks!
RhynoCZ
PostPosted: 17:05 - 19 Feb 2015    Post subject: Reply with quote
Does it have a battery? If so, it's dead. Fresh battery should do the trick. My mates MZ is the same. Thumbs Up
One thing to try - bump start it and ride it for at least 30 miles, that might gonna be enough to charge up the battery.
Iain.
PostPosted: 18:08 - 19 Feb 2015    Post subject: Reply with quote
Definately don't do this.
If something in the kickstarter assembly has broken & jammed, and theres bits of metal flying round in the cases and you take it for a thirty mile ride then it's likely to cause quite a bit of damage.
When you try to kickstart it what actually happens?
Does the kickstarter spin the engine over and return correctly, does the kickstarter stick, any odd noises, does it feel different to normal?
I suspect it is likely just a dead battery, however I'd not run it till you're sure somethings not actually broken. Thumbs Up
316lad
PostPosted: 22:43 - 19 Feb 2015    Post subject: Re: Gilera RCR 50 Won't Kick Reply with quote
Tips and advice?
many thanks!
What happens when you DO try and kick start her?
e.g; Does it slip, grind, kick over okay but not start?
More information needed.
lukehanham
PostPosted: 14:40 - 23 Feb 2015    Post subject: Reply Reply with quote
The bike seems to kick over fine, but bare in mind this is one of my first bikes.
It sounds like it really wants to start, but just can't do it.
It can be bump started extremely easily too.
I measured the battery and it is 12.64 Volts, Which is around the right amount.
What else can i do / check?
Would a video of me trying to kick start help out?
RhynoCZ
PostPosted: 14:46 - 23 Feb 2015    Post subject: Reply with quote
Did you try fresh petrol? Check and clean the spark plug if necessary and also have a look at the air filter. 12.64v is enough, so the battery is alright, although you said the bike was sat for a few months. The battery must have enormous capacity or, it was not that long ago since it was used.
lukehanham
PostPosted: 15:00 - 23 Feb 2015    Post subject: Reply with quote
I put a new battery in very recently,
Surely the spark plug is fine as it bump starts?
And is the air filter hard to access?
RhynoCZ
PostPosted: 15:14 - 23 Feb 2015    Post subject: Reply with quote
The spark plug will tell you, if the mixture is alright.
The air filter should be easy to access, but I've no idea where it is on your bike. A clogged air filter acts like a choke and makes the mixture rich. Which, and especially with two strokes, is not good for the spark plug.
EDIT: You're gonna need a NGK BR9ES which is quite cheap since you've got only one cylinder.
There you go: https://www.wemoto.com/bikes/gilera/rcr_50_enduro/03-05/picture/spark_plug_ngk/ Thumbs Up
PostPosted: 15:16 - 23 Feb 2015    Post subject: Reply with quote
This happened on my NS125R when I was a kid. I tore my hair out for ages, and eventually replaced the spark plug out of frustration more than anything. It worked, and it fired up first time.
lukehanham
PostPosted: 15:52 - 23 Feb 2015    Post subject: Reply with quote
I've ordered a new spark plug, will see how that works out!
RhynoCZ
PostPosted: 15:54 - 23 Feb 2015    Post subject: Reply with quote
Well, I'd check the old one first, but since it's cheap, it is worth the change. Smile Thumbs Up
lukehanham
PostPosted: 22:10 - 23 Feb 2015    Post subject: Yay Reply with quote
Got it to kick start, tried putting in gear and that went ok.
I had put it in first, slowly letting out the clutch with no revs and it cut out, tried with a little rev, 2k? and it juddered a lot and then cut and came back to life and was able to ride a bit.
Anything worth looking into?
316lad
PostPosted: 22:27 - 23 Feb 2015    Post subject: Re: Yay Reply with quote
Choke cable - adjust it to take up any slack - if you don't have a cable and it's a plunger on the Carb then just play it so the thing has some revs on start up.
Just treat it like a 2-Stroke.
I suspect you giving it some exercise has got it more responsive - resulting in it going on a kick - nice one!
2-Strokes don't like ticking over - they tend to run lean - so - don't spend too much time on idle but do give it a minute or two to warm slightly before you rev it off them clock, then, get on, get your lid on and go!
Ride safe!
'Gis' some pics!
Iain.
PostPosted: 10:44 - 24 Feb 2015    Post subject: Reply with quote
Does sound like the kickstart itself is okay!
Perhaps the bikes just not keen on the cold - Possibly worth giving it a bit of a service. Air filter ought to be sponge, wash it out with petrol, pour around two tablespoons of EP80/90 gear oil on it & squeeze the filter to soak all the oil into it all over, fresh sparkplug and that's about it on these.
Other than that, as above, check choke cable isn't sticking and give it a minuite to warm up when it catches Mr. Green Thumbs Up
The last post was made 11 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.31 Sec - Server Load: 2.76 - MySQL Queries: 13 - Page Size: 83.89 Kb
