heated grips
mbknitrof1
PostPosted: 23:08 - 26 Jan 2005    Post subject: heated grips Reply with quote
hi all i have fitted my heated grips today to my 50 moped but it makes your battery go flat,
would i be able to fit another battery to my moped but connect it up to the battrey i got already,will that make it 24v and blow everythin? and will the engine be ok with chargin both up,
thanks again,
better check before i do it
PostPosted: 00:56 - 27 Jan 2005    Post subject: Reply with quote
If you connected them in series you would get 24v and make a mess of things.
If it is flattening the battery from the grips with the engine running then an extra battery (wired in parallel) would keep them going for longer but would still go flat.
The problem is probably that the charging system has insufficient power to supply the bikes electrical needs as well as those of the heated grips. Without some expensive parts (if available) there is not much you can do about that. Changing to LED indicator and tail light bulbs might save a bit of power and help a little though.
simon1221
PostPosted: 23:23 - 27 Jan 2005    Post subject: Reply with quote
Nifty fifties hardly have enough power to use the lights, you would have no chance of having heated grips on a 50 im afraid, simple really.
The last post was made 21 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 35.77 Kb
