YBR 125 stalled now not starting.
zark
PostPosted: 09:30 - 20 Feb 2015    Post subject: YBR 125 stalled now not starting. Reply with quote
So this morning, started the YBR (07 plate, FI) to warm it up a bit. (I always use the kick start as the electric one seems to drain the battery)
Was on the side stand, running quite happily. I hop on, kick stand up - engage 1st gear and it cuts out.
Thinking i've stalled it, i kick it to start it, and it starts and runs quite happily.
Get 1 mile up the road, and slowing on the approach to a junction, revs die to nothing. While i'm rolling, i let the clutch out to see if i can 'bump it' while still moving... Nothing. Slowly roll to a silent stop... Crying or Very sad
Many attempts to start at roadside on the kick - but nothing at all. Occasionally it might burble as if to start, but then dies straight away.
Lights still work and can hear the injector whirring if i turn key off and then on, just won't fire up on the kickstart.
Pushed it home, wiggled spark plug cap, seemed fine. Sprayed liberally with WD40 on the electric bits (it was raining). Still wouldn't start.
Running late for work, so leave it and get in the car.
So - as it was running beautifully last night, it's got to be either 'rain related' or something stopping the engine firing?
Is this how the side stand switch works? I never normally use the side stand. If the switch is buggered, would it stop the bike from starting even in neutral?
It was dark, raining and i was now late - so haven't looked at anything else yet - just wondered if this was an easy diagnosis?!
/TL:DR - was running - cut out - now won't start. Could it be side stand switch?
monkeybiker
PostPosted: 10:00 - 20 Feb 2015    Post subject: Reply with quote
Has it got any petrol
zark
PostPosted: 10:21 - 20 Feb 2015    Post subject: Reply with quote
Yarp... virtually full...
i did try releasing the filler cap, in case there was some sort of vapour lock - made no difference. Filled it up about 50 miles ago.
The only things different today (that i can think of) i used the side stand (i never normally do) and it was raining...
(But it was raining when i rode it home yesterday...
Which made me think - would a faulty sidestand switch stop it from starting, even in neutral with the clutch pulled in? (got into the habit of always pulling in the clutch to start, even if neutral light is on)
Not withstanding the possibility of a broken wire etc - but i got no flashing yellow 'engine' light...
Got me scratching my head a bit...
flikers
PostPosted: 11:25 - 20 Feb 2015    Post subject: Reply with quote
Yes, if the side stand switch is faulty and it thinks the stand is down it will make your bike cutout and then not restart.
Taught2BCauti...
PostPosted: 11:35 - 20 Feb 2015    Post subject: Reply with quote
The side stand switch would normally kill the engine if you select a gear and the side stand is down, but it shouldn't stop the bike from starting in neutral.
Sometimes, the clutch switch, neutral switch and side stand switch are electronically related, so you will need to get hold of a wiring diagram to work out what would happen if there's a fault somewhere.
My bike has a couple of diodes in the circuit, but yours might be different.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 12:12 - 20 Feb 2015    Post subject: Reply with quote
Are you talking from specific knowledge of the YBR 125, or are you making an ass-u-me?
Fully charge battery, get a multimeter on it. Older bikes can run with a duff battery or it completely out of the circuit, but with new fangled FI, I'd suspect electrical.
You're going to want a multimeter in any case.
Spark plug colour is...?
Taught2BCauti...
PostPosted: 12:51 - 20 Feb 2015    Post subject: Reply with quote
Just going by what it says on page 23 of the YBR 125 user manual - it explains what the side-stand switch does, and what happens if it is in the wrong position - but not what happens if it is faulty, or how to to diagnose it.
Also, page 19 explains the operation of the clutch switch - but like you say, you would need a multi-meter to check them out.
Sorry, can't help with a wiring diagram Sad
PostPosted: 13:04 - 20 Feb 2015    Post subject: Reply with quote
Battery I bet. Charge/replace.
zark
PostPosted: 15:29 - 20 Feb 2015    Post subject: Reply with quote
Whaddayaknow? Found a wiring diagram in the "Wiring Diagram Thread"!
But can't see the sidestand switch on it... i'll have a look in the Haynes manual when i get home.
Thanks for all the suggestions.. Knowing my luck it'll start fine later - and i'll be paranoid the sodding thing is going to do it again in the morning...
bikertomm
PostPosted: 15:32 - 20 Feb 2015    Post subject: Reply with quote
Errrr... you have checked you haven't knocked the kill switch right? Idea
PostPosted: 16:26 - 20 Feb 2015    Post subject: Reply with quote
They were quite famous for not having one; I'm not sure when they started fitting them.
First thing I did on my bike-in-a-box was to remove the switch. My Enfield came with the sidestand switch disconnected and the kill switch wires physically cut, because (as the seller quite openly said) stuff diagnosing those issues.
Taught2BCauti...
PostPosted: 17:58 - 20 Feb 2015    Post subject: Reply with quote
Mentioned in the 2007 & 2008 manuals..
Ignition circuit cut-off system
The ignition circuit cut-off system (com-
prising the sidestand switch, clutch
switch and neutral switch) has the fol-
lowing functions.
● It prevents starting when the trans-
mission is in gear and the side-
stand is up, but the clutch lever is
not pulled.
mission is in gear and the clutch le-
ver is pulled, but the sidestand is
still down.
● It cuts the running engine when the
transmission is in gear and the sid-
estand is moved down.
...but not 2006 or earlier.
There are some wiring diagrams online - one claims to be for the 2007 model, but doesn't show anything other than the neutral switch, but the others are such poor quality, I can't tell if the side stand switch is there or not.
It would help to know if the switch should be open or closed when the side stand is up - then you could eliminate it by either disconnecting the wires, or by shorting them together.
I would start by checking that the neutral light still works, then checking the clutch switch and side stand switch with a meter.
PostPosted: 18:10 - 20 Feb 2015    Post subject: Reply with quote
Woah, before you dig out wiring diagrams and go checking components charge the Battery.
Fuel injection can't run without power thats why it cuts out especially at low revs. You already said you battery won't turn the bike over.
https://www.zyracuze.com/wp-content/uploads/2014/04/062112_kiss.png
zark
PostPosted: 19:17 - 20 Feb 2015    Post subject: Reply with quote
So... Came home.
Battery showed 12.4 V. Spare battery on, measured 13.5 V.
Turned key. Kicked it, roared into life.
Fussakes...
Put lid on, went for a 20min spin, perfect. Got 10 yards from home, cut out.
Restarted on the start button. Went home. Left it idling. Cut out.
Panels off. WD40 everywhere. Spark plug out, seems OK. Not wet(?)
Plugged hole with spare plug. Held connected plug on frame and turned over... Spark seemed a weedy orange colour, but that might be my choice of earth? Deffo not fat and blue, if its supposed to be.
Went for another spin after putting it back together, no problems at all... I've either unwittingly fixed it, or its going to let me down big time in the morning!
Incidentally, I cleaned and lubed the side stand switch, but not convinced that's anything to do with it after it cut out this afternoon?
Fingers crossed, and thanks again for all the help guys Thumbs Up
sutty86
PostPosted: 01:31 - 24 Feb 2015    Post subject: Reply with quote
Has the bike been okay since.
Mines playing up slightly like this
Dying whilst idling after a few minutes etc
Taught2BCauti...
PostPosted: 10:45 - 24 Feb 2015    Post subject: Reply with quote
I would suggest you start a new thread Smile
zark
PostPosted: 13:34 - 24 Feb 2015    Post subject: Reply with quote
but in the meantime...
Yup - fresh battery and a liberal WD40 -ing has drowned whatever gremlins were lurking...
(I did remove seat and lift edge of tank up to get to the CDi, so i could wiggle and then spray it)
Since then - ridden without missing a beat through several downpours...
All is good again. Thumbs Up
The last post was made 11 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 98.29 Kb
