2006 Kawasaki Zx636 won't start please help
Rodneymacc
PostPosted: 17:33 - 20 Feb 2015    Post subject: 2006 Kawasaki Zx636 won't start please help Reply with quote
Hi everyone I have a 2006 Kawasaki zx636 and it won't start. It was fine until I put on a aftermarket exhaust and took off the cables from the exhaust servo and now it doesn't start when I turn the key I hear everything activating but once I hit the ignition switch it does nothing it doesn't make a noise. Any suggestions anyone
MAc-
PostPosted: 20:13 - 20 Feb 2015    Post subject: Reply with quote
No starter spinning?
If so, check your fuses/wiring, have you disturbed something when you were arsing about the can or cables?
Nemo
PostPosted: 20:39 - 20 Feb 2015    Post subject: Reply with quote
Have you got the engine management light staying on?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Musketeer
PostPosted: 22:17 - 20 Feb 2015    Post subject: Reply with quote
As above I would be checking fuses first.
evilzed
PostPosted: 22:48 - 20 Feb 2015    Post subject: Reply with quote
I'm pretty sure what you need is something called a "servo eliminator"/ "servo fix" for your bike.
MaybeGuy
PostPosted: 04:02 - 21 Feb 2015    Post subject: Reply with quote
it doesn't need the servo motor to run at all. You just get a little red light on the speedo.
Rodneymacc
PostPosted: 19:49 - 24 Feb 2015    Post subject: Reply with quote
Hi so I checked the fuses and nothing was blown I checked to see if all the wires leading from the ignition button was connected and they all are. But still no start
MAc-
RhynoCZ
PostPosted: 20:05 - 24 Feb 2015    Post subject: Reply with quote
Are you 100% sure, that the kill switch on the right handle bar is in the ON position?
Rodneymacc
PostPosted: 20:29 - 24 Feb 2015    Post subject: Reply with quote
Yes sure
MAc-
Nemo
PostPosted: 21:08 - 24 Feb 2015    Post subject: Reply with quote
Checked condition of the earths?
Is there power through the start button?
RhynoCZ
PostPosted: 21:18 - 24 Feb 2015    Post subject: Reply with quote
Alright then, I'm not being funny here, the kill switch thing happened to many of us, many times before. Smile
Does the starter relay do the clicking sound when you press the start button? Some relays do have its own fuse mounted on them. Thumbs Up
This is a pretty common starter relay, used on various modern bikes of various manufacturers and displacements. It's got rubber cover over it.
https://i.tfcdn.com/img2/CY4n6D8AY5r875BOcmJRMUNGSUmBlb5-anKFXmZuYnpqsW5ibmJVfp5ecn6uPkRE31PfxNA9383R3DEq3EcvqyAdAA**/fvUG-v8A.B
Nemo
PostPosted: 00:41 - 25 Feb 2015    Post subject: Reply with quote
To add to the the post above, if you bridge the terminals the starter should kick into life, if not give it a few taps then try again, still nothing happens get a new one.
Also if there is a fuse on the relay, it's usually a main fuse and if that blows nothing will work.
The last post was made 11 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 72.78 Kb
