Bandit 1200 wont start
simons48
PostPosted: 10:16 - 25 Feb 2015    Post subject: Bandit 1200 wont start Reply with quote
Hi All, I have read a few articles on this issue I have but would like your opinion please.
I have a Bandit 1200 2006 the bike was running fine last week, I had a week off so the bike wasnt ridden to work, went to start it monday morning and no go?
The engine didnt turn over, the head light went dim when I hit the starter button but nothing didnt even turn over.
I have bought a new battery and fully charged it put the new battery on but still the same issue.
I have tried to bump start it but this didnt work either.
I have read about the clutch switch and side stand switch, the side stand switch I believe will only cut the engine when the bike is put in gear so I dont think this is the issue.
Is there a way I can bypass these clutch / side stand controls to see if the starter moter is shot?
Thanks for your replies in advance.
Simon.
PostPosted: 10:34 - 25 Feb 2015    Post subject: Reply with quote
First off find the starter solenoid and bridge the heavy terminals. If the starter now turns it's not at fault.
Taught2BCauti...
PostPosted: 10:45 - 25 Feb 2015    Post subject: Reply with quote
Did the engine turn over when you tried to bump start it?
I think it sounds more like a starter motor problem, so can you feel the starter motor and the wire that goes between the starter solenoid and the starter motor - are they getting hot when you press the start button?
If you have a multi-meter, try checking the battery voltage before and after trying to start the bike, and let us know what readings you get.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
simons48
PostPosted: 12:56 - 25 Feb 2015    Post subject: Reply with quote
Excuse my ignorance but how would I bridge the solenoid? Positive from the battery to the positive on the solenoid?
Also it did sound like the motor turned over when I tried to bump it.
Someone did suggest if the float bowls are overflowing this will fill the barrels preventing it to start or temporarily locking the engine?
Thanks
Simon.
mudcow007
PostPosted: 14:16 - 25 Feb 2015    Post subject: Reply with quote
Thanks
Simon.
quick an dirty test for the fuel thing, is to sniff the oil - if it stinks of petrol it then you have an overflow
temeluchus
PostPosted: 20:56 - 25 Feb 2015    Post subject: Reply with quote
Use a jump lead, go direct from battery positive to the terminal on the starter motor.
If the starter still doesnt turn, give it a whack with a hammer and try again.
simons48
PostPosted: 23:47 - 25 Feb 2015    Post subject: Reply with quote
Well got home today tried to start my bike again started first time!?
I believe it was a loose connection on the clutch switch, pulled off the connectors gave them a clean and pushed back on started first time every time,
Really annoyed that I didn't read up on this first before having to commute to London on a train the last few days. Anyway back on the old girl in the morning Very Happy.
Thanks for your replies all.
Happy biking
Best regards.
The last post was made 11 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 52.51 Kb
