| Pol Anorl |
 Pol Anorl Banned
| mudcow007 |
 mudcow007 World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
| Rogerborg |
 Rogerborg nimbA
 Posted: 01:40 - 26 Feb 2015 Post subject: |
<We're-All-Doomed>Cable is separating and will snap soon.</We're-All-Doomed> ____________________ Biking is 1/20th as dangerous as horse riding.
| Pol Anorl |
 Pol Anorl Banned
| Taught2BCauti... |
 Posted: 09:42 - 26 Feb 2015 Post subject: |
Just to make sure it's not something internal, what is the angle between the cable and the clutch release lever?
It should be less than 90°, like this: ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| 316lad |
 316lad Borekit Bruiser
| Skudd |
 Skudd Super Spammer
| Taught2BCauti... |
 Posted: 10:23 - 26 Feb 2015 Post subject: |
I always think that the adjuster at the lever-end is the weakest part of the system, so I prefer to screw mine all the way in so there are no threads showing, and make adjustments at the clutch end.
Your problem might have been caused by the ferrule on the end of the outer cable not seating properly in the adjuster, then suddenly snapping into place, causing the slack to appear.
Someone on here recently had a clutch push-rod snap in half - but that would show-up in the angle between the release lever and the cable, as per my pic - but like Skudd said, better to buy a spare cable and keep it handy - just in case. ____________________ Honda Varadero XL125(V8)
| 316lad |
| Pol Anorl |
 Pol Anorl Banned
| Andy_Pagin |
 Andy_Pagin World Chat Champion
 Posted: 14:10 - 26 Feb 2015 Post subject: |
I'd take the sprocket cover off and take a look at the clutch cam lever, it's held onto the cover by a couple of little screws, they might have come loose for example.
It's easy enough to do, slack off the adjuster at the handlebar, unbolt the sprocket cover. To refit scrape off any gasket bits, squidg a line of instant gasket in its' place and re-fit. IIRC the bolts aren't all the same length (or was that the Vity?, can't remember). ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
| chris-red |
 Posted: 16:42 - 26 Feb 2015 Post subject: |
Cable is about to snap. Mine always break at the lever end and my TDM probably uses the same lever set up so yours may be doing exactly the same. have a look don't leave it, it will snap soon. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Pol Anorl |
 Pol Anorl Banned
The last post was made 11 years, 244 days ago. Instead of replying here, would creating a new thread be more useful? |
