Honda Hornet 600- can battery run heated grips & Waistco
Meerka Mouse
PostPosted: 19:57 - 26 Feb 2015    Post subject: Honda Hornet 600- can battery run heated grips & Waistco Reply with quote
Hello
Returning rider after some years child-centred absence (it's a bitch to ride with a Bump).
My poor neglected Hornet 600 is finally getting some attention. Due to the extraordinary price of getting bikes maintained in a workshop in the NL, looking at fitting new heated grips and waistcoat with the help of a friend.
(I'm a soft as hell rider and we've book a weekend long distance travel, could be 8 - 10 hours' riding depending on the weather)
Technical question:
The battery is 12V - 6Ah according to the Owner's Handbook.
The Oxford premium grips "draw under 4A" according to the specs on the brochure.
The Oxford heated waistcoat is for 12V vehicles. 4 heat settings (I assume the warmer it is, the greater the drain).
I can't find any more detailed information than that.
Is the battery going to be able to cope with those two drains?
1) will it cope with both on, all the time, without draining?
2) could it cope with one or the other? (ie can I swap between the two, use the grips for a while then the waistcoat).
If anyone has any ideas I'd be very grateful!
(the bike shop told me that it can't be done which I *know* is untrue as I've had both attached to my previous Hornet for long distance frequent winter commuting, many years in the past. My wonderful then-mechanic worked it out carefully that the total drain was less than the battery could provide and it worked perfectly).
Thanks Smile
cb1rocket
PostPosted: 20:08 - 26 Feb 2015    Post subject: Reply with quote
Simple answer yes it will cope, just make sure it's only being used when the engine is running.
PostPosted: 20:27 - 26 Feb 2015    Post subject: Reply with quote
I'd go with this.
None of the figures you have provided are useful.
It's not to do with the battery, but the charging system.
Think of the battery like a jug of water. You wouldn't ask "can this jug of water pour enough water for all the people eating at the restaurant" - you'd just fill it up again.
We'd need to know the ratings for the charging system on the bike and the items you want to add; but providing you're not using lots of other things, it should be fine.
doggone
PostPosted: 21:36 - 26 Feb 2015    Post subject: Reply with quote
With the headlight presumably always on too, the charging capacity will be barely coping if both are on for long.
PostPosted: 21:41 - 26 Feb 2015    Post subject: Re: Honda Hornet 600- can battery run heated grips & Wai Reply with quote
A quick google shows one Hornet 600 can produce 333w at 5k rpm.
Lights should be well under 100w for all of them.
4a max for heated grips gives us another 50w or so.
Seems like plenty of spare room to me? (Not sure how much average background stuff takes - would expect fuel pump won't be much as usually they've just got short cycles, of course there's spark plugs, ECU etc too).
Meerka Mouse
PostPosted: 21:57 - 26 Feb 2015    Post subject: Reply with quote
Hmm thanks for the explanation and clarification.
Sounds like I can have both but it's wiser to alternate them or only have both on at once for short periods. Usually leave the bike on tricklecharge at home but when we're going for the weekend away, that won't be an option.
Many thanks Smile
PostPosted: 22:02 - 26 Feb 2015    Post subject: Reply with quote
With normal use the battery will be fully charged all the time.
I strongly suspect you can have both running with no problems - as your bike has one headlight, it'd probably be like having just one running on a bike with dual headlights where both lights come on together.
andys675
PostPosted: 22:59 - 26 Feb 2015    Post subject: Reply with quote
move up to a newer generation of battery?
you've got a ytx7l-bs, as batteries have developed since then you may be able to fit a newer / better generation of battery in it, a ytz10s perhaps?
you'll need to check the size, but the Ah will be better as will the cca
cb1rocket
PostPosted: 23:39 - 26 Feb 2015    Post subject: Reply with quote
As G has said pretty well; a battery is a jug of water.....bigger capacity isn't going to solve the problem. Its the bike's generator output that matters here.
ECU and background stuff uses very little
cb1rocket
PostPosted: 23:44 - 26 Feb 2015    Post subject: Reply with quote
the other option is if you do go away disconnect or turn off your heated stuff 20 mins before your arrival to give the battery a chance to charge up fully.
I did have to do this on my ex's scooter in order to get a charge in the battery as the output of the genny was insufficient.
Contrary to what I said in the first paragraph against my second, this is only going to be a problem IF the genny is insufficient
Meerka Mouse
PostPosted: 08:39 - 27 Feb 2015    Post subject: Reply with quote
mmm I'll turn them off 20 mins before arrival then. It won't be so bad when a journey ends at home as I can trickle charge it then (though is draining the battery that much bad for it?)
It's the sort of thing I can find out by experience as long as I'm careful to end up at home, maybe.
Really looking forward to the new trip, it'll be so good to be on the bike again.
sickpup
Old Timer
PostPosted: 08:46 - 27 Feb 2015    Post subject: Reply with quote
Yes the hornet 'should' be able to cope but there will be virtually no spare capacity in the battery or charging system.
The way around this is to change the rear bulb for an LED one along with the pilot light and all the idiot lights in the clocks. This will give you a little extra overhead.
PostPosted: 09:42 - 27 Feb 2015    Post subject: Reply with quote
It'll save about 4W per bulb, which quickly adds up.
For context, I run 4A / 48W heated grips on my Enfield, with LED instrument, tail, side/running (x5) and indicator bulbs. With the headlight on and grips on full, it holds charge at fast idle and provides a surplus while riding (ammeter FTW).
I'd be astonished if your Hornet provides less, and it'll already be dumping the surplus through the reg/rec - you might as well use it to heat yourself.
Matt B
PostPosted: 10:22 - 27 Feb 2015    Post subject: Reply with quote
We are all looking at the grips/vest running at maximum load here. When I use mine they don't stay up at the max setting for long, maybe about 10 minutes. After that, once the grips and my gloves have warmed through they get turned down to about a quarter. Same will probably apply with a heated vest, quick blast then turn it down.
Should be fine Thumbs Up
The last post was made 11 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 82.9 Kb
