Changing gear when pushing on?
FlightRisk
PostPosted: 20:04 - 27 Feb 2015    Post subject: Changing gear when pushing on? Reply with quote
I ride a CB500, now there's some giggles to be had but obviously it needs many revs to keep it up in the GiggleZone. I keep over-revving between upshifts from WOT or coming off the throttle too early and loosing momentum with the engine braking.
Is there some trick to smooth upshifting from wide open throttle?
Honda CB500S
Fisty
PostPosted: 20:05 - 27 Feb 2015    Post subject: Reply with quote
Clutchless gear change.
Fatter and faster than Fret
SQL
PostPosted: 20:07 - 27 Feb 2015    Post subject: Reply with quote
No clutch.
Put pressure on the gear lever upwards, when pinning it then shut the throttle for not even a second then it will change up seamlessly
/Thread
FlightRisk
PostPosted: 20:23 - 27 Feb 2015    Post subject: Reply with quote
Really!?
I'm scared to smash my gearbox. Embarassed
Honda CB500S
FretGrinder
PostPosted: 20:26 - 27 Feb 2015    Post subject: Reply with quote
Celt500 wrote:
Really!?
Many people do clutchless gear changes without any problems at all.
I have an 80 mile commute every day. I've been changing gears without the clutch daily, for a couple of years.
Yamaha MT-09
ಠ_ಠ
Blue_SV650S
PostPosted: 20:40 - 27 Feb 2015    Post subject: Reply with quote
You need good throttle control to do clutchless shifting, from your original post, it sound like this is something you do not possess!
Just keep practising the clutched shifts - or buy a quickshifter ...
SQL
PostPosted: 20:44 - 27 Feb 2015    Post subject: Reply with quote
It will be fine.
FlightRisk
PostPosted: 20:56 - 27 Feb 2015    Post subject: Reply with quote
I'm quite smooth flicking up and down through the gears in normal riding, it's just when I try to really wind it up that it goes a bit pear shaped.
I confess it was the thing I most struggled with starting off but it's come on in leaps and bounds since I bought the CB.
Honda CB500S
Irn-Bru
PostPosted: 20:58 - 27 Feb 2015    Post subject: Reply with quote
I only use the clutch for changing up at low speeds, otherwise it feels a lot more natural to not use it, especially at full belt. Has to be 0% throttle otherwise you risk damage, it's all about the timing but one of those things when you do it right you will never ever do it wrong. I suppose being on a thumper I get an awful lot of practise with it, I'm up and down the box all day long when I'm out in the countryside but I love it.
Got a short little video of me doing it on my DRZ a few weeks back:
https://instagram.com/p/y5NOAKkylz/?modal=true
pdg
PostPosted: 21:28 - 27 Feb 2015    Post subject: Reply with quote
If you don't kick the buggery out of the shift lever then it won't damage anything not closing the throttle completely.
If there is any load on the gearbox then the lever won't move. You only need to back off enough to unload the 'box, then it will shift. You don't need 'good throttle control' in the least.
Slight pressure on lever, flick the throttle closed a bit then open it again, maintain pressure on the shift lever so it shifts fully - job done.
All the 'quick' shifters I've seen (including air or nitrous powered button shifters) achieve the same goal of unloading the gearbox by cutting the ignition while the lever is moving - that way you can keep on WOT and shift in the same clutchless manner.
Generally I would use the clutch going from 1st to 2nd (because neutral, but it's easily possible anyway), and clutchless above that.
If I can do it on a BMW gearbox without hurting it, you really should be able to do it on a CB.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
wristjob
PostPosted: 21:48 - 27 Feb 2015    Post subject: Reply with quote
utter rubbish.
as has been said in other posts ,put pressure on the lever(not enough pressure to force a shift) while hard on the power when you want it to change up just roll off the throttle a little and the bike does the rest.as it changes get back on the power.
its simple.
its actually less effort and skill than a clutched change.
however a quick shifter does make it even easier.
Nick 50
PostPosted: 22:34 - 27 Feb 2015    Post subject: Reply with quote
Was that Stanhope heading up to the nutty sheep area?
Fladdem
PostPosted: 22:44 - 27 Feb 2015    Post subject: Reply with quote
I clutch-less change up and down the box, the only time I touch the clutch is when I'm pulling away, wheelieing, and changing from 1->2 and 2->1.
I even tried to change without the clutch in my car a few times, but it's harder, so I just use the clutch now, I can't rev match at all, I'm practising for when I steal my dads 1958 Landy, no synchro-mesh in that box! Thumbs Up Laughing
dodsi
Dirty Carny
PostPosted: 22:46 - 27 Feb 2015    Post subject: Reply with quote
Those micro seconds you save, cherish them.
Irn-Bru
PostPosted: 09:34 - 28 Feb 2015    Post subject: Reply with quote
Aye Smile
davebike
PostPosted: 09:51 - 28 Feb 2015    Post subject: Reply with quote
Really pushing on on the CB500 hold wide open into red Zone at 11k750 the rev limiter cuts Left pot lift lever up it changes
DON"T do 1st to second as it will pull a Huge wheelie yes I done it you lose lots of speed time getting it under control
Te CB500 trives on revs just keep I spinning
I do clutch less up and down if in a hurry
at first just work into clutch less don't do it at full chat until you mastered it as lower pace
Dave
NC750Xdct + others at work !
[email protected]
XBIKER
PostPosted: 15:36 - 28 Feb 2015    Post subject: Reply with quote
Simple to do, just rev up as normal then kill the throttle and kick up simultaneously. You may find it easier to practice doing it with low revs at first
Had to do clutchless changes for a few days while I waited for a new clutch cable for my Suzuki GS850G. To get moving I held on tight and hit the electric start then to change gear as previously mentioned, kill the throttle and kick up.
Gets more interesting when slowing down with no clutch cable as you do not want any load on the engine (cue locked up rear wheel Shocked ) so have to let the revs drop right down before shifting down.
orac
PostPosted: 17:27 - 28 Feb 2015    Post subject: Reply with quote
I think the correct term for changing without the clutch is crash changing - I tried googling it but it just came up with loads of stuff about crashing and nothing about changing gear.
and yeh changing without the clutch is fine, down can be tricky to master and some bike don't like it at all but will accept it in a pinch.
FlightRisk
PostPosted: 19:30 - 09 Mar 2015    Post subject: Reply with quote
Oh yeah, that does work. (Clutchless)
And it's FUN! Twisted Evil
Now I really need to work on my braking + downshifting into turns before I do much more of that.
Honda CB500S
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
stevo as b4
PostPosted: 20:20 - 09 Mar 2015    Post subject: Reply with quote
Isn't the limiter on a sports 400cc about 2000rpm past peak power though?
I've been told that the 15500rpm red line and then change gear is a pretty slow way to ride an R6, seeing as maximum power is at 13k tops. I've never ridden one or tried it, but does going back down the torque curve before changing up save you more time than a quick change at peak power rpms?
I never as far as I can remember ever needed the 14500rpm red line line that my old ZX6R had, but for going really quickly in terms of making real progress in road riding, would keep it between say 7000-11000rpm most of the time.
Was I doing it wrong?
Also 12000rpm in 3rd was circa 90-95mph, and in the overtaking only speed range, as I didn't call 90-100mph making progess on the road and never sustained those speeds on an average ride out.
Acemastr
PostPosted: 20:33 - 09 Mar 2015    Post subject: Reply with quote
I always do clutchless upshift, habit now.
Tried a downshift the other day on the R6 but it didn't sound terribly wonderful, plus I like blipping on downshift too much Very Happy
It's just practice, I still struggle with clutching from 1st to 2nd at 14k rpm, it takes me a bit longer than other gears and the front goes light when I do it :p
2016 Toyota Tacoma Limited
evoboy
PostPosted: 21:10 - 09 Mar 2015    Post subject: Reply with quote
Never bother doing it down the box.
Normally use the clutch as a rear brake to slow the wheel down when entering a corner.
Drop it down a couple of gears and feed the clutch out, letting the revs come back up but without engaging full drive to the rear wheel. Itll just lock up else.
Why you would want to even change down a gear without the clutch is beyond me.
APT Motorcycles
monkeybiker
PostPosted: 23:31 - 09 Mar 2015    Post subject: Reply with quote
It's not really about saving time just that it's easier and smoother.
The last post was made 11 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 128.68 Kb
