| Irn-Bru |
 Irn-Bru World Chat Champion
| Ste |
 Ste Not Work Safe
| Irn-Bru |
| Ste |
 Ste Not Work Safe
 Posted: 10:02 - 12 Oct 2014 Post subject: |
I expect those are basic flat pedals, in which case greasing the bearings and replacing the bearings if necessary is fairly straight forward.
https://www.youtube.com/watch?v=W2HvLpCzpAo
| chris-red |
 Posted: 10:36 - 12 Oct 2014 Post subject: |
I've never known bearings needing replacing, they have to be proper fucked and used for a while before that happens even then I would expect the axle to wear first. Sorting them out is easy. In the last lot I did each peddle had 13 on each side, undo the axle and pull it out make sure you have a tray or something to catch all the bearings pull it out of one side first and count the bearings. Clean all the old grease off with a solvent, (off bearings, peddle and axle) then dry them. Put a large blob of grease in each end of the peddle then half put the axle through and put the appropriate amount of bearings into the peddle and make sure they are seated right and push the axle all the way through, more grease more bearings then tighten till there is no slop but it spins freely. It can be fiddly but is easy enough, biggest thing I'd say is make sure the bearings are seated properly, cause then can look like they are but aren't if you get what I mean. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| Irn-Bru |
| stinkwheel |
| Irn-Bru |
| stinkwheel |
 Posted: 21:33 - 01 Mar 2015 Post subject: |
Most of the ones I've seen are just loose ball bearings. They work. They've worked for over a hundred years.
I've seen ones with a grease nipple. Seemed like unecessary.
Grease them once a year, make sure the dust cap is in place and it's a non-issue.
Spinning totally freely is probably a sign that the bearings are a tad loose and running out of grease. There shouldn't be any side to side play but the grease will give a degree of "stickiness" when they are well lubed. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Irn-Bru |
 Posted: 17:18 - 04 Mar 2015 Post subject: |
Got the new pedals today, they are much more comfy for my big feet. Went for chavvy red (white frame bike) Heavy as you say but my bike is out of it's element already, just a mountain bike with road tyres a lot like my motorbike in a way. ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| Irn-Bru |
 Posted: 20:48 - 01 Jul 2015 Post subject: |
Another update. Still happy with pedals but one thing I've noticed is the pins are making a run for it. Lost about 3 on each pedal now. Went over the remaining ones today and they were all quite loose, something to watch out for  ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| Ste |
 Ste Not Work Safe
 Posted: 20:49 - 01 Jul 2015 Post subject: |
Remove the pins and put them back in with a drop of red thread lock.  |
The last post was made 11 years, 77 days ago. Instead of replying here, would creating a new thread be more useful? |
