| DarkLightFX |
 DarkLightFX Two Stroke Sniffer
 Posted: 12:18 - 11 Mar 2015 Post subject: Honda NSR125 - Top End Rebuild - Performance Upgrades |
Right, So I've purchased an imported Honda NSR 125 with 16,000 miles on the clock. I Fear that it has not had any top end matience done so therefore I am going to do a completely top end rebuild.
I ordered all the parts from DavidSilver - Here is the breakdown:
2 Antifreeze / Coolant 1 litre £9.90
1 ***OEM*** OIL SEAL 9x18x7 £2.50
1 GASKET,CYLINDER H *A £9.95
1 GASKET,CYLINDER *A £2.25
2 CLIP,PISON,PIN *A £3.00
1 BRG.CON-ROD S-END *B £8.50
1 PIN,PISTON *A £9.25
1 RING SET, PISTON (ST*B £32.00
1 CYLINDER SET PISTON *B £155.00
£232.35
Delivery £5.85
inc VAT
(20.0%) £285.84
So anyway, I have read up as much as I possibly could and I think I'll be able to do it. I'm most likely over worrying and over complicating things. But considering I've never done it before any instructions/tips/advice would be highly appreciated.
My plan is to strip the motorbike down and drain the coolant. Once I have got access to the top end I will Remove the top end and dissemble. Then I will clean up any marks/carbon using carburettor cleaner.
I will also remove the old gaskets from the cylinder head e.c.t
Once all clean, I will reassemble the new barrel,piston,rings,clips and small end bearings ensuring to lube up with 2 Stroke Oil. Last of all I will then put on new gaskets and put back together. Last of all, before running I will fill up with new coolant and top up the 2 Stroke Oil.
On the first run I will just let her idle for about 10 minutes then turn off and cool down and repeat two/three times. As for the breaking in I guess I will ride gently with the odd burst of power here and there until I clock some miles up.
In addition to the engine rebuild I will be de-coking my exhaust and upgrading the jets as well as new carbon reeds in the intake.
As I mentioned previously, any feedback or advice would be much appreciated. |
| salem1987 |
 salem1987 Scooby Slapper
| DarkLightFX |
 Posted: 12:35 - 11 Mar 2015 Post subject: |
Awesome, I'll have a look through it.
From your experience with your rebuilt, did I miss anything vital from my procedure? Any help from experience would be great  |
| salem1987 |
| DarkLightFX |
| chris-red |
| DarkLightFX |
| stirlinggaz |
 Posted: 14:46 - 11 Mar 2015 Post subject: |
hi,
why did you go & spend all that cash on parts you might not need?
like i said in your other post, heres is the service intervals straight from the owners manual :
7500 miles (12000 kms) change rings
15000 miles (24000 kms) change piston & rings
22500 miles (36000 kms) new cylinder/top end kit including small end bearing,gaskets etc
you might just likely need a piston kit & gaskets, no cylinder. however the bike will feel like a new engine has been fitted when you've replaced all that stuff.
so take it easy for 1st few hundred miles to "break it in"
well if you've paid for it, you might as well do the job.
its a fairly easy job, just make sure you have all the right tools, including a spanner that will get that 1 nightmare cylinder nut off
theres a few guides available on line, so theres no reason why you couldnt do it.
just be methodical, put all nuts,bolts & other parts in tubs so you dont lose them or get them mixed up. (i use 1L ice cream tubs for this very purpose & label with masking tape & marker)
take some pics every so often, in case you forget which way parts go.
have you even done a compression test? compression tester imho is one of the most useful tools when you own a 2 stroke.
i have a few & use the same gunson compression tester i got years ago
just dont drop anything into the crank case, its a good idea to stuff a rag around conrod/crank case.
cheers,
GAZ |
| chris-red |
| DarkLightFX |
 Posted: 14:57 - 11 Mar 2015 Post subject: |
You are correct but if I'm going to the trouble to change the rings and gaskets then I might as well just do the whole lot. It's not cheap, but it'll be worth it because I'm going to be riding the NSR for 2 Years. I rely on my motorbike as transport and I don't really want the hassle of engine problems when I'm going to be relying on it.
I have no documents to prove that any top end engine work has been done what so ever. However in saying this, I could open the top and it may be pristine. I really have no clue.
But If it's in good condition I will have spare parts or could potentially sell them to repay the £300 cost.
I guess the advantages is I will have a reliable engine and better performance. But feel free to let me know your opinions  |
| stirlinggaz |
| DarkLightFX |
| DarkLightFX |
| chris-red |
| DarkLightFX |
| stirlinggaz |
| stevo as b4 |
 Posted: 18:43 - 11 Mar 2015 Post subject: |
Sorry Chris but have a think about what you said about a piston does not wear?
Then think about the temperature gradient across the piston, the hotter running two stroke cycle and what happens to the piston if the engine ever gets too hot, runs a bit lean or detonates.
It's my preference if doing replacing nothing else after measuring the bore of a 2stroke motor, to change pistons with the rings together every single time!
Did you think about ring locating peg issues, rings fretting in the port windows, and the effects on the ring lands of blow by etc?
A Piston is not expensive, and I've had bad experiences (should have known better) from putting new rings onto an old piston with worn ring grooves.
Change the top end as a set, do it properly, and it'll be long lived and you won't be back in there for another 8000mile+ on the bike mentioned in thread. |
| stirlinggaz |
| salem1987 |
| DarkLightFX |
| DarkLightFX |
| DarkLightFX |
| Fidge |
 Fidge Banned
| DarkLightFX |
 Posted: 09:58 - 12 Mar 2015 Post subject: |
Okay - so far example my piston maybe be a (B) and the cylinder will match (B). Therefore I should purchase another B?
Thanks matey  |
| salem1987 |
The last post was made 11 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
