Refilling empty brake lines
PostPosted: 13:06 - 29 Jan 2005    Post subject: Refilling empty brake lines Reply with quote
Hi Dudes (and Dudettes),
on my TT600 I currently have a completely empty front brake system. This is because the breakers drained the lines after the pipe that connects into the master cylinder split in 'the accident'.
Does anyone have any specific advice on refilling brake lines from empty? The bike has braided hoses as standard, and so those of you with low spec jap bikes ( Wink ) who have upgraded to braided hoses would have particularly useful input to this.
Arrow Anything I need to look out for?
Arrow Any way of filling the lines with the minimum amount of air getting in?
Arrow Any issues I need to worry about related to fluid absorbing moisture?
Any help appreciated! Thumbs Up Smile
Big Pete
PostPosted: 13:26 - 29 Jan 2005    Post subject: Reply with quote
pour some fluid into the calipers first, then assemble the lines. Fill the master cylinder reservoir, open the bleed screws. Get cup of tea, by the time you return the lines should almost be full. Close the bleed screws. shake the hoses while slowly moving the brake lever, you should start getting bubbles out into the M/cyl reservior. When the bubbles stop, bleed as normal from the calipers. HTH
Trust me, I`m an engineer
GarageOfPower.co.uk
PostPosted: 13:28 - 29 Jan 2005    Post subject: Reply with quote
But the lines are assembled... Confused
Damn.
Big Pete
PostPosted: 13:31 - 29 Jan 2005    Post subject: Reply with quote
doesnt really matter, just take longer at the cup of tea stage, the calipers will fill by gravity, but it take longer. Alternatively, unscrew the caliper banjoes and fill the calipers, then screw them back in again.
GarageOfPower.co.uk
PostPosted: 13:37 - 29 Jan 2005    Post subject: Reply with quote
Some people reccomend filling from the bleed nipple.
I have a fork oil syringe that has been used for this before, if you wanna borrow it I can probably dig it out.
Robby
Dirty Old Man
PostPosted: 17:31 - 29 Jan 2005    Post subject: Reply with quote
I do it by having something applying suction at the bottom end - my trusty squeezy bottle is always useful here.
I have also done it by forcing fluid in at the bottom using a syringe. The syringe method is more effective, but the squeezy bottle way is generally cleaner.
Important thing is to remember that the air will rise in the lines, but slowly. Brake fluid is thicker than water.
mr.z
PostPosted: 17:48 - 29 Jan 2005    Post subject: Reply with quote
The easyest way (i know of) is with a one way valve (motrax do one).
Put your pipe with valve on the bleed nipple, get a pipe long enough to reach back up to your resivoir (secureing it carefully, cable ties and whatever) open the bleed nipple, feed fluid into the resivoir while pumping and wait till the fluid has made it to the pipe going up to the resivoir, when its at the correct level then keep pumping for a while untill theres no bubbles makeing their way up.
Close nipple, take pipes off, use a cable tie to hold the lever down, check in the morning, top up if need.
The last post was made 21 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 53.76 Kb
