Which Socket Set?
-bandit
PostPosted: 22:10 - 14 Mar 2015    Post subject: Which Socket Set? Reply with quote
Probably been asked a million times.
Just bought a Bandit, don't have any proper tools and need to do some simple maintenance like clean the brake callipers.
Which socket set will do pretty much everything on my bike and at a reasonable price? Looking to spend around £50. Halfords have their 'half price' sale on their sets. Would any of these do the trick?
Thanks for any help.
PostPosted: 22:25 - 14 Mar 2015    Post subject: Re: Which Socket Set? Reply with quote
Yep and this is the answer I give every time...
You won't get that comprehensive a socket set from Halfords for £50. For the record, it's not half price at Halfords - for some periods they have it at double the correct price, for marketing purposes.
These aren't quite as good quality, but cost less and have more useful tools covering more stuff:
www.ebay.co.uk/itm/380885568668
If you need spanners, the price of this silverline set has gone up a little, but still excellent value for pretty decent tools:
www.ebay.co.uk/itm/130787145446
wodge
PostPosted: 22:39 - 14 Mar 2015    Post subject: Reply with quote
Ive had one of these for a couple of years.. Its used daily at work with no complaints. You might want a couple of larger sockets but for general maintenance it hits the spot..
https://www.halfords.com/motoring/garage-equipment/socket-sets/halfords-advanced-professional-36-piece-socket-set-1-4
nolidge iz pouwur.
Yamaha RXS100 RS100
-bandit
PostPosted: 23:08 - 14 Mar 2015    Post subject: Reply with quote
Thanks for the replies.
I will only be doing a few bits and bobs on the bike, as I'm pretty clueless when it comes to this sort of stuff. The £25 Halfords set looks OK, I know they are always on "half price" too.
If I need any other sockets that aren't in the pack then I can buy them separately can't I?
Cheers.
PostPosted: 23:11 - 14 Mar 2015    Post subject: Reply with quote
And spend massively more.
You will need other sockets, which is why I suggest the considerably more comprehensive one I linked to - some bikes take a 36 for the rear wheel and possibly a large socket for the head stock - but it will cover the vast majority of tasks on the majority of bikes.
A 1/4" only socket set will be considerably more limited; partly because it's not a drive intended to handle much torque.
Ed Case
PostPosted: 23:15 - 14 Mar 2015    Post subject: Re: Which Socket Set? Reply with quote
If you're just like most of us, not a mechanic but a weekend tinkerer these recommended jobbies should do just fine, you'll not wear them out !.
-bandit
PostPosted: 23:19 - 14 Mar 2015    Post subject: Reply with quote
OK cheers guys. I'll pick up the eBay set as they won't see much use, just the odd job here and there.
I'll get spanners if I come across the need for them.
Thanks!
PostPosted: 23:24 - 14 Mar 2015    Post subject: Reply with quote
I'll note that only problem I had with the set I got was breaking the 1/4" drive ratchet - probably the halfords one wouldn't have broken in that situation. BUT in reality, I should have been using the 1/2" ratchet, will handle way more than the small Halfords one.
(And, saying that - my last Halfords 3/8" ratchet broke on the day I got it.)
Also - it's usually better to have tools BEFORE you need them Smile.
binge
Emo Kiddy
PostPosted: 23:28 - 14 Mar 2015    Post subject: Reply with quote
Unless you are looking to undo rusty or extremely tight nuts and bolts, sockets are sockets.
Just like spanners, are spanners. Regardless of the brand.
High end tools, like the Snap-On and MAC flank drive range come into a league of their own when you're working with damaged or difficult nuts/bolts.
Buy cheap sockets by all means. But spend the money on a decent ratchet. Thumbs Up
Facom and Britool are good alternatives if you don't want to spend Snap-On or MAC money.
The Halfords Advanced range isn't too bad also.
Be warned. Tool buying can, and does get addictive.
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xfa1/v/t1.0-9/581919_10151494658615606_1683696771_n.jpg?oh=acbd966489d15250dc8325fa19e80af7&oe=55823DFD&__gda__=1434173682_147c5b438d75e6adb30d053f4df2c570
https://scontent-lhr.xx.fbcdn.net/hphotos-xpa1/v/l/t1.0-9/526628_10151530425655606_1948991454_n.jpg?oh=3e20af69febe75e9a5fccc0a8a0883b5&oe=55BA929B
-bandit
PostPosted: 23:35 - 14 Mar 2015    Post subject: Reply with quote
Thanks for the help binge, that's an impressive set Shocked Very Happy
Thanks also G. I found this set on eBay which seems to be the exact same as you linked but a couple of quid cheaper.
https://www.ebay.co.uk/itm/94PC-1-2-1-4-SOCKET-SET-SCREWDRIVER-BIT-TORX-RATCHET-DRIVER-CASE-TOOL-KIT-/380443833734?pt=LH_DefaultDomain_3&hash=item5894383586
PostPosted: 23:44 - 14 Mar 2015    Post subject: Reply with quote
I just went for the first one.
I've looked at a few of these and the quality seems pretty similar - as per Binge's comments, for most stuff and 'home use' it's fine.
If you pay a bit more you nicer ratchets with curved handles, but I think the mechamism is pretty similar. Some also come with nicer finishes, but usually paying a chunk more.
I wouldn't buy the wall drive set of these - I did and the tolerances weren't as good as they could have been.
For what it's worth, if I were to buy some sockets they would be the draper wall drive ones like these - www.ebay.co.uk/itm/120642376740 .
However, for your budget, you won't get a comprehensive set, while you will with the cheaper ones.
(The wall drive ones will generally manage to remove rusted/already rounded fasteners where others may not.)
-bandit
PostPosted: 23:57 - 14 Mar 2015    Post subject: Reply with quote
I have seen those draper ones, a review said that it does most the bolts on their bike.
As it's an old bandit, some of the bolts are rusty and might be a task to get off. Might as well give the cheap set a go and see if it gets them off...
cheeseman
PostPosted: 00:05 - 15 Mar 2015    Post subject: Reply with quote
The one thing I would add is that you should steer away from using those horrible multiple point type sockets and only get a set of sockets with hex cutouts that match the hex heads on nuts and bolts (sorry don't know the correct terminology for them Sad ) The former seem to be excellent at rounding off when confronted with seized bolts.
XJ600S->Sprint ST 955i * ; Now ST1100 + W650
PostPosted: 00:38 - 15 Mar 2015    Post subject: Reply with quote
First off, that's often a bad method - as you can't 'undo' rounding a rusted bolt.
However, it's normally when it's REALLY bad or when people have reused an already knackered fastener, so hopefully you should be ok.
While the draper one I linked to does 6-24mm, which is a decent coverage, it doesn't do an allen, trx or screw fittings - all of which are covered by the 94 piece set.
(Note - choosing the right screw driver style head is also important in not rounding fittings, something far too often ignored.)
FlightRisk
PostPosted: 06:31 - 15 Mar 2015    Post subject: Reply with quote
I'm very happy with the Halfords 120 piece set that I bought after getting advice on here last year.
It's more than decent enough for my occasional use and I was swung by the fact that if anything breaks I can walk into any Halfords for a replacement - the lifetime warranty on the 'Advanced Professional' stuff.
I've had to add one big socket for the headstock which was about a fiver extra.
Honda CB500S
1198
PostPosted: 07:36 - 15 Mar 2015    Post subject: Reply with quote
I bought a Advanced set from Halfords as well, it's doing well. I have needed a odd size for the spindle on the Monster, buts that's all.
wr6133
PostPosted: 08:14 - 15 Mar 2015    Post subject: Reply with quote
I bought a Halfords advanced 120 piece a while back. I'd recommend to anyone, the tools are good enough but the deal maker for me was the ability to ride 8 miles to instantly exchange anything that may break. It's not comprehensive I've had to buy over time the occasional larger sockets, circlip pliers, etc but for basic maintenance it is ok. Box it comes in is shit though.
GaryJM
PostPosted: 09:57 - 15 Mar 2015    Post subject: Reply with quote
Another vote for the Halfords advanced/pro socket sets.
I bought the 150 one and it contains nearly everything I need.
Doesn't have a 32 mm socket thou which you need for the front sprocket on the bandit.
Does have a 24mm for the rear axle nut.
Buy cheap buy twice.
PostPosted: 11:00 - 15 Mar 2015    Post subject: Reply with quote
Yea, I was thinking that when my halfords ratchet broke on the first day of using it Razz.
GaryJM
PostPosted: 11:21 - 15 Mar 2015    Post subject: Reply with quote
Life time quarentee is great isn't it Smile
First I've heard of one breaking.
PostPosted: 11:30 - 15 Mar 2015    Post subject: Reply with quote
Not really, because it couldn't be used that day, which was the exact day I *needed* it to be used. Wink As it goes, it was also the day I bought it, so any shop should have replaced regardless of extra gaurentee if I'd had the time to get back to them.
Some years ago I had to have some stuff fixed on a bike and had quite a fight to get it sorted - however they may be better for tools.
Is convenient to have them more likely close by.
Plenty of people have said that ratchets are now covered, but they never used to be and a quick check shows the Q&A on their website confirming this; but all the questions are a good few years old.
Also, they always used to ask to see the receipt, which fades, but apparently don't now.
binge
Emo Kiddy
PostPosted: 21:29 - 15 Mar 2015    Post subject: Reply with quote
Commonly known as 12 side and 6 side sockets.
On a bandit, you wont come across anything that requires a 12 side socket (Like the cut-out in a cheap ring-spanner), so 6-siders would be the safe option.
On cars I work on, 12-siders are needed a lot more than you think. Thumbs Up
The last post was made 11 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 116.58 Kb
