1996 bandit 600 mystery problem
Guilby94
PostPosted: 23:23 - 14 Mar 2015    Post subject: 1996 bandit 600 mystery problem Reply with quote
I have recently acquired a bandit 600 1996 but the problem the old owner was having was that every few weeks the bike would stop working because the plugs were fouled but after a clean it would run again. Anyway I spoke to him and he says he checked the plugs but there was a weak spark on all 4 but he also says he has changed the chi unit and checked the coils but I have spoken to two mechanics and neither have a clue does anyone have any experience?
yen_powell
PostPosted: 08:44 - 15 Mar 2015    Post subject: Reply with quote
Assuming carbs, is the choke stuck on or is he riding with it on?
XT1200Z and a DR350 in bits
Guilby94
PostPosted: 08:57 - 15 Mar 2015    Post subject: Reply with quote
Nope he never rode with the choke on but I have been told it could be using too much fuel and not burning enough because of the weak spark sounds plausible to me
yen_powell
PostPosted: 10:29 - 15 Mar 2015    Post subject: Reply with quote
When you say the plugs are fouled, are they sooty black or oily?
Guilby94
PostPosted: 11:27 - 15 Mar 2015    Post subject: Reply with quote
Sort of an oily mess
Guilby94
PostPosted: 13:25 - 15 Mar 2015    Post subject: Reply with quote
It really has me confused
Taught2BCauti...
PostPosted: 13:29 - 15 Mar 2015    Post subject: Reply with quote
Try doing a compression test, and check the spark plug gaps.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Guilby94
PostPosted: 14:10 - 15 Mar 2015    Post subject: Reply with quote
Ok will have a chat with the mechanic who has it now and will keep everyone updated Smile
sickpup
Old Timer
PostPosted: 17:06 - 15 Mar 2015    Post subject: Reply with quote
I would clean up all the earths on the coils, trim back the HT leads and change the air filter.
If that doesn't work I would check for a badly fitted Dyno-Jet kit.
Also does it have the standard can on it?
Val
PostPosted: 18:08 - 15 Mar 2015    Post subject: Reply with quote
Have you checked for rotten/dirty contacts in the multi-plug both the coils and the ignition unit side?
Try Halfords electrical contacts cleaner on both then try with spark plug tester
https://www.ebay.co.uk/itm/like/261571595007?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0
Guilby94
PostPosted: 19:28 - 15 Mar 2015    Post subject: Reply with quote
I am gonna check tomorrow all of these things and it has an ART end can on it and the carbs have already been balanced by the Suzuki dealer over here in Guernsey but I will definitely try and test everything
sickpup
Old Timer
PostPosted: 19:32 - 15 Mar 2015    Post subject: Reply with quote
Was the fueling corrected for the end can?
Guilby94
PostPosted: 21:16 - 15 Mar 2015    Post subject: Reply with quote
Apparently so but I have ordered the spark plug tester in the link above and will check the jetting and the earths when I get some time
sickpup
Old Timer
PostPosted: 23:12 - 15 Mar 2015    Post subject: Reply with quote
Well if it was it evidently wasn't done properly.
Guilby94
PostPosted: 12:16 - 16 Mar 2015    Post subject: Reply with quote
Just spoken to the mechanic who says it is a carb issue and that they have done a compression test and nothing is wrong and he said they have checked the spark plug gaps and other bits like the earths on the frame where it has been painted and ruled out the ignition system he reckons it is a poorly fitted jet kit or a problem with one of the actual carbs so does anyone know if gsxr 600 carbs will fit?
PostPosted: 14:24 - 16 Mar 2015    Post subject: Reply with quote
Short answer, no, get the carbs set up properly I very much doubt they need replacing.
Iain.
PostPosted: 15:15 - 16 Mar 2015    Post subject: Reply with quote
Stupid question, have you changed the plugs rather than cleaned them?
My Bandit fouled the plugs, refused to start. Clean plugs it'd run for a bit then foul up again. Bought new plugs, fired up and ran perfectly for the entire time I owned the bike.
Guilby94
PostPosted: 17:11 - 16 Mar 2015    Post subject: Reply with quote
Will have to rebuild them and the previous owner changed them when he first started getting this problem will probably try a new set soon
PostPosted: 17:44 - 16 Mar 2015    Post subject: Reply with quote
Carbs have lots of adjustments inside and to all intents and purposes do not wear out. I doubt they need replacing.
Check they are clean and set them up properly. If you have the standard parts put the standard air filter and exhaust on then set the carbs to factory spec and go from there.
Guilby94
PostPosted: 18:09 - 16 Mar 2015    Post subject: Reply with quote
Unfortunately I don't have the original parts
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
misscrabstick
PostPosted: 18:41 - 16 Mar 2015    Post subject: Reply with quote
Bits do wear out, i just had to order a set of needles and seats for my kawasaki as one carbs getting a bit floody when it's left standing, I blame stupid ethanol for eating the tips of the needles.
Guilby94
PostPosted: 11:44 - 17 Mar 2015    Post subject: Reply with quote
Where would everybody recommend getting the parts from?
Iain.
PostPosted: 12:32 - 17 Mar 2015    Post subject: Reply with quote
Bike shop? Confused
PostPosted: 13:16 - 17 Mar 2015    Post subject: Reply with quote
Soylent Blue wrote:
I don't think this is the issue but it's naive to claim carbs don't wear out. Needles and emulsion tubes wear out as do slides with elevated mileage.
I know, I didn't want to confuse the OP. My point carbs aren't a part of the bike where buying a second hand set and lobbing them is a decent solution, barring damage obviously. Every part in the carb you can replace easily and cheaply enough.
The last post was made 10 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 124.58 Kb
