cbr600 FX q's
Villers
PostPosted: 12:45 - 29 Jan 2005    Post subject: cbr600 FX q's Reply with quote
Since my bike has little or no history Ive decided its time for some home servicing! Now I know some of you have fx's so I'd just like some advice to be honest.
What kind of oil do you prefer
Which spark plugs do you reccomend
Should I replace the standard airbox filter with an aftermarket one or stick with the original
As im unsure if the bike has had an oil change recently would it be worth running some sort of cleaner through the bike before I change the oil?
Last question, and this sounds stupid but im stumped, if I were to grease the pistons on the calipers what type of grease should I use?
cheers guys
Bendy
Mrs Sensible
PostPosted: 18:24 - 29 Jan 2005    Post subject: Reply with quote
Spark plugs - NGK/CR9EH-9
Oil - Castrol GPS
Wouldn't worry about the filter particularly.
Dunno about the grease tho Smile
NickD
PostPosted: 18:26 - 29 Jan 2005    Post subject: Reply with quote
Can't usually go wrong with Coppaslip grease, I use it for pretty much everything.
I was only doing what it said on my licence officer....
Tear along the dotted line!
Villers
PostPosted: 19:22 - 29 Jan 2005    Post subject: Reply with quote
Will coppaslip not start to grind eventually?
what grade bendy?
cheers you two!
NickD
PostPosted: 19:26 - 29 Jan 2005    Post subject: Reply with quote
No.
Bendy
Mrs Sensible
PostPosted: 19:33 - 29 Jan 2005    Post subject: Reply with quote
Villers wrote:
what grade bendy?
It's 10W40, I think it only comes in that grade tho.
Just buy the stuff with the bike engine on the front. Wink
slowarse
PostPosted: 21:10 - 29 Jan 2005    Post subject: Reply with quote
any good 10w40 motorbike oil will do, probably better sticking with an original airfilter, if you get an aftermarket one that lets more air in it could make your bike run lean,
i've read a few times not to use copaslip on pistons because it can damage the seals?
Villers
PostPosted: 13:44 - 30 Jan 2005    Post subject: Reply with quote
cheers bendy I like your style!!
The last post was made 21 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 55.31 Kb
