Sticking carbon on, without the gap
bEN_
PostPosted: 11:48 - 15 Mar 2015    Post subject: Sticking carbon on, without the gap Reply with quote
I made my own carbon tank protectors ( copied from other parts, which i just used as a mold ) and the fit is fine on a dry fit until it comes to actually sticking them on, i've tried various types of bonding tape, even the really thin stuff in small strips but i can't get rid of the gap it creates which just makes it look completely naff ( more so than having the carbon on there in the first place, but i don't want to pay to have the tank repaired and painted )
I want to have them on as the tank has quite a few bad marks on it from my last crash a few years ago.
What other options do i have? i'm thinking of just using some form of glue and thinking fuck it, to hell with the paint underneath Laughing
https://www.imageupload.co.uk/images/2015/03/15/unnamed83a41.jpg
this is actually a bad picture, it doesn't look to bad from this angle, but from the front and the side, you can see the gap and the tape underneath, so you get the idea
2010 Ducati 848 Dark
Lamp Post Enthusiast
mysterious_rider
PostPosted: 11:55 - 15 Mar 2015    Post subject: Reply with quote
Glue gun? Would that hurt the paint? If not liquid gasket definitely wouldn't and would stick it fine
KAWASAKIIIII
bEN_
PostPosted: 11:57 - 15 Mar 2015    Post subject: Reply with quote
Liquid gasket sounds interesting Thinking i know alot of glues can be quite aggressive so that sounds like an option, i hope i have some in my shed Laughing
mysterious_rider
PostPosted: 12:00 - 15 Mar 2015    Post subject: Reply with quote
With the liquid gasket if you get the black one you can seal around it and wipe off excess. Would look perfect. Kind of like how you would seal a bath.
KAWASAKIIIII
bEN_
PostPosted: 12:04 - 15 Mar 2015    Post subject: Reply with quote
Does it dry quick? i might have to tape it in place and then do the 'sealing' later on, thanks for the idea Thumbs Up
oouche
PostPosted: 12:37 - 15 Mar 2015    Post subject: Reply with quote
if you are 100% happy with how it looks i would use tiger seal (pu adhesive ) you can buy generic form from tool station for a few quid
if the tank is damaged make sure that its rust proofed before fitting
as you may be creating a moisture trap
any adhesive that sticks to fibreglass will stick to a painted surface
maybe try evo stick if you really want it to be temporary although
as has been said before need a filler to fill the gap to stop it looking stuck on
mysterious_rider
PostPosted: 12:41 - 15 Mar 2015    Post subject: Reply with quote
Yeah hold in place with masking tape. In a, large quantity maybe 40 minutes
KAWASAKIIIII
bugeye_bob
PostPosted: 12:48 - 15 Mar 2015    Post subject: Reply with quote
remake your carbon bits but remove too much material so the pad fits the excess removed so when it is on your pad it is flat,
Id guess you could sand down the ones you have to do this,
It is only the thickness of the sticky pad, and just leave the last 2/3 mm with no sticky around the edge to keep it invisible.
bEN_
PostPosted: 13:28 - 15 Mar 2015    Post subject: Reply with quote
I only used 2 layers of carbon to begin with, any less and it would be too brittle and you would be able to see through the weave making it look crap
Nemo
PostPosted: 14:05 - 15 Mar 2015    Post subject: Reply with quote
Make another but compensate for the gaps?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
bEN_
PostPosted: 17:05 - 15 Mar 2015    Post subject: Reply with quote
So i ended up using some standard black sealant and put some tape on to hopefully hold it in place while it sets, i think i'll add a bead around it later to tidy it up
https://www.imageupload.co.uk/images/2015/03/15/2445b7.jpg
The last post was made 11 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 68.33 Kb
