O-Ring Problem
EasyGoingPat
PostPosted: 10:43 - 17 Mar 2015    Post subject: O-Ring Problem Reply with quote
Hi,
I have just removed the fuel tank from my BMW R1100S. Around the fuel-filler is a circular recess in which there is an O-ring. A thin metal plate then goes on top of this, followed by the plastic-and-metal panel that forms the visible centre-section of the tank. The whole thing is held in place by 6 Allen bolts that pass through the exterior, visible rim of the fuel filler, then through the concealed plate, and finally tighten into screw holes in the the tank itself.
I am having a huge amount of trouble reassembling this. The problem is that the O-ring seems to have been deliberately engineered to be slightly too large for the recess in which it sits. I presume this is so that, as the steel plate above is tightened down, the ring compresses, forming an air-tight seal. The problem is that, while putting in the Allen bolts that hold the whole thing together, it is impossible to get fingers or anything else close to the O-ring, to nudge it into the recess. The result, after many attempts, is that the ring is always bulging somewhere, and I doubt it is forming a good seal.
Can anyone think how to tackle this? I was thinking of some kind of glue, to hold the ring in place while I tighten it down. Any suggestions? It doesn't need necessarily to be petrol resistant, because, once the plate is tightened, this will hold the O-ring firmly in place (though obviously I don't want a glue that will dissolve and contaminate the petrol).
Any suggestions would be very much appreciated.
Kind wishes ~ Patrick
Confused
Thank you to anyone taking the time to read my posts.
PostPosted: 10:47 - 17 Mar 2015    Post subject: Reply with quote
I'm not clear exactly what you have there from your description. Post pics?
Might be the o-ring has stretched/deformed and you need a new one.
In terms of adhesive. A little smear of RTV gasket sealant woudl seem the logical thing to seal a gasket.
PostPosted: 10:51 - 17 Mar 2015    Post subject: Reply with quote
Did you clean everything? O-rings expand with certain solvents.
EasyGoingPat
PostPosted: 11:09 - 17 Mar 2015    Post subject: Reply with quote
Might be difficult to get useful pictures, but I'll give it a go if the gasket sealant doesn't work out.
I haven't cleaned the O-ring in anything. It appears to be in very good condition, and - though I accept the point about O-rings deforming - it looks to me like it had been deliberately over-sized. Guess it wouldn't hurt to order a new one though. It's good practise anyway.
- Patrick
PostPosted: 11:15 - 17 Mar 2015    Post subject: Reply with quote
It's a common occurrence. You'll find that a new o-ring will fit perfectly.
Do you not have any bearing/seal/o-ring shops nearby? If not you might find one online. O-rings are sized by internal diameter (ID) and cross-sectional diameter (CS), so measure the ID and width of the groove and that's your size.
raesewell
PostPosted: 11:16 - 17 Mar 2015    Post subject: Reply with quote
you need some red rubber grease to hold it in place, assuming the O ring is in good shape
Yamaha FJR 1300 Normanton West Yorkshire
EasyGoingPat
PostPosted: 11:19 - 17 Mar 2015    Post subject: Reply with quote
Thank you all very much for the advice. Lots for me to try there. I will try to remember to pop back and report what worked out.
- Patrick
PostPosted: 16:36 - 22 Mar 2015    Post subject: Reply with quote
I stumbled across this advice when doing a search for something else - boil the o-ring to shrink it back to (near) it's normal size:
https://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/568177-black-kadork-thing-fuel-tank-2.html
EasyGoingPat
PostPosted: 17:16 - 22 Mar 2015    Post subject: Reply with quote
Maybe worth a go. Though, if I do have a real problem with it, I am inclined to take the advice of my Haynes manual and fit a new one. Being a motorbike part, it can't be more than £100 for an O-ring. Wink
Thanks.
- Patrick
temeluchus
PostPosted: 17:38 - 22 Mar 2015    Post subject: Reply with quote
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=30&Ct=GA&SbCt=BA_15_30_GA_25
Last item in the list. Cripplingly expensive!
EasyGoingPat
PostPosted: 17:56 - 22 Mar 2015    Post subject: Reply with quote
Just ordered. Thank you. (Now I feel like such a lazy arse, for not looking it up myself.)
Embarassed
The last post was made 11 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 72.21 Kb
