Fazer 600 2001 air filter replacement.
Matt B
PostPosted: 13:27 - 17 Mar 2015    Post subject: Reply with quote
Probably would feel 'strangled' after an R6 Thumbs Up
Ben90
PostPosted: 13:49 - 17 Mar 2015    Post subject: Reply with quote
Y U No buy Haynes manual yet?
I remember reading an article that tested various air filters comparing them to stock. Short answer is aftermarket ones flow slightly better but allow more dust through. Can't go wrong with an OE filter as it was designed for the engine.
https://www.nicoclub.com/archives/kn-vs-oem-filter.html
Yamaha FZ6 S2
Amber Phoenix
PostPosted: 13:53 - 17 Mar 2015    Post subject: Reply with quote
You could watch my rather dodgy video on how to do this job.
https://www.youtube.com/watch?v=EnDPwJxfN00
Apologies in advanced, it's not the best video.
Eitherway, to answer your questions:-
Yes, tank needs to come off completely.
Tank hinges needs to be removed.
Remove side panels for access.
Remove awkward rubber cover over air filter.
Unscrew top off air box.
Swap filter.
Reverse the above.
Put a K&N in mine. Didn't notice much, but then I just pootle along in London.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
Thorn This post is not being displayed because the poster is banned. Unhide this post / all posts.
davebike
PostPosted: 15:32 - 17 Mar 2015    Post subject: Reply with quote
You will struggle to get the filter out without removing the tank
The rubber cover over the air filter is held by the bolts that hold the tank hinge
You also need to remove both side panels slip the rubber bit of the fram pegs and it will come out but not easily
I like EIX plugs but they make most difference at low revs
So not much help with peek power
While the tank is off check the fuel filter in the pipe between the tap and fuel pump
Dave
NC750Xdct + others at work !
[email protected]
Andy_Pagin
PostPosted: 16:22 - 17 Mar 2015    Post subject: Reply with quote
The tank's very easy to remove, undo the front bolt, prop it up as high as you can to get at the fuel line clip and wiring harness. Undo them then remove the tank. Refitting is the reverse. The rubber cover over the air filter is the sod to get off.
The last post was made 11 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 66.92 Kb
