Kawasaki GT550 not running on all cylinders
tstwebdesign
PostPosted: 20:37 - 17 Mar 2015    Post subject: Kawasaki GT550 not running on all cylinders Reply with quote
Hey guys,
I'm having a problem with my Kawasaki GT550. Initially it was running really lumpy, then it started leaking fuel on the left side when it was set to prime. so got the carbs off, only managed to get two apart to take a look but everything looked pretty spotless. Put them back on and was running fine for a couple of days.
Now, whilst I was out and stopped at a light, it noticeably started only firing on 2 cylinders and had a loss of power. Managed to nurse it home to take a look.
The two inner spark plugs aren't firing at all, far left one has a strong spark and the far right has a weaker spark. I replaced the battery and spark plugs and it fired on all four at first then almost immediately went back to 2 and would go back to four. I swapped the caps on the left side to swap the spark around and it just backfired. I've now ordered 2 new coils as these are supposedly notoriously temperamental.
Hopefully the coils will fix this but if not I'm stumped.
Oh, I just fired it up after letting it stand for a few hours and it fired on all four then went back to 2 again.
Is there anything I'm missing? It's done a fair few miles so if it's more than likely dead I'd rather find out rather than spend a fortune.
Honda CG 125 & Kawasaki GT550
moonzoomer
PostPosted: 20:58 - 17 Mar 2015    Post subject: Re: Kawasaki GT550 not running on all cylinders Reply with quote
tstwebdesign wrote:
Hey guys,
I would be looking at coils for sure, to test the suspect coil switch the input wires around with the other coil and check if the non sparking plugs are sparking after the bike has warmed up.
sickpup
Old Timer
PostPosted: 20:58 - 17 Mar 2015    Post subject: Reply with quote
More than likely the coils. I've known couriers who used these to carry spare coils.
tstwebdesign
PostPosted: 21:07 - 17 Mar 2015    Post subject: Reply with quote
Thanks sickpup, they should be arriving this week so I'll put an update up as soon as I know! If there's anything I should check for in the meantime I'd be grateful.
PostPosted: 21:31 - 17 Mar 2015    Post subject: Reply with quote
Ratty old plug caps are another thing to consider. Kawasakis coil earthing (if needed) is often a bit slapdash at best.
Sounds like you had sticky floats or leaky needle valves in the carbs. Worth checking it hasn't overspilled a load of fuel into the oil or airbox.
temeluchus
PostPosted: 04:09 - 18 Mar 2015    Post subject: Reply with quote
Try bypassing the sidestand switch (short the wires) and see if it runs better.
As stinkers says, leaking fuel on prime is a good indicator of fucked float needles, pop the needles out and make sure the tips dont have notches worn in them. If they are knackered they can cause running issues similar to what you describe.
Its quite possibly a bit of both, particularly on an older bike.
bikenut
PostPosted: 10:43 - 18 Mar 2015    Post subject: Reply with quote
as above.....does your have the small filter screens above the float needle valves........cmnsl will confirm.....
nuts about bikes
tstwebdesign
PostPosted: 16:21 - 24 Mar 2015    Post subject: Reply with quote
Ok, so the firing issues were to do with the coils, ordered new ones with replacement HT leads and now firing perfectly (The timing is still off but one step at a time...)
Once I had done this a few days later it started leaking again so this time I took the carbs off and gave them a proper clean and it seems to be working fine again. If it happens again I'll give it a full refurb.
bikenut
PostPosted: 17:26 - 24 Mar 2015    Post subject: carbs Reply with quote
did you check the filters above the needle valve bodies??
nuts about bikes
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.41 Sec - Server Load: 3.11 - MySQL Queries: 13 - Page Size: 63.52 Kb
