| Quirky |
 Quirky Scooby Slapper
| Fisty |
 Fisty Super Spammer
| Quirky |
| Ariel Badger |
 Ariel Badger Super Spammer
| andys675 |
 andys675 World Chat Champion
| STONEY! |
 STONEY! Brolly Dolly
| STONEY! |
| Quirky |
| Ariel Badger |
| Quirky |
| c_dug |
 c_dug Super Spammer
| Quirky |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 08:39 - 18 Mar 2015 Post subject: |
If the pads are binding, as long as the roller is not depressing the plunger when at rest, I think the problem is more likely to be with the seals in the caliper. If they are not allowing the pistons to retract, try stripping and cleaning the caliper, and fit new seals.
You should be able to tell in less than a mile if the pads are binding. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Quirky |
| jjdugen |
 jjdugen World Chat Champion
| Quirky |
| Pete. |
 Pete. Super Spammer
 Posted: 08:56 - 18 Mar 2015 Post subject: |
Yes what Ariel Badger says is correct. If the piston is held in a tiny bit the return port is closed off. Mine was an extreme case since I was shoving the bike along with 400hp so it got very hot indeed and it was 20 minutes before you could even wheel the bike. After it cooled you would not have known there was a problem at all.
Un-wind the span adjuster to pull the lever in towards the bar, then adjust it back out. See if adjusting it pushes the plunger in any at all. ____________________ a.k.a 'Geri'
| Quirky |
| Pete. |
 Pete. Super Spammer
 Posted: 09:18 - 18 Mar 2015 Post subject: |
There you go, you've found the problem. Now to find the cure.
BTW you could have the wheel turning immediately by cracking a brake pipe union and letting out a little brake fluid. ____________________ a.k.a 'Geri'
| Quirky |
 Posted: 09:25 - 18 Mar 2015 Post subject: |
But if it was a problem with the caliper generating heat, would the same symptoms not occur, ie 20 minutes later its cooled down and returned to normal.
I'll have a look at the lever to see if I can see anything but I am far from technical so could you tell me what I'm looking for as if you were talking to a child?
Out of interest, how far had you gone before the wheel locked up? |
| Pete. |
 Pete. Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 09:30 - 18 Mar 2015 Post subject: |
I just found this page with google images search. It explains the problem and the reason:
https://www.trialspartsusa.com/diagrams/AJP.jpg ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 09:37 - 18 Mar 2015 Post subject: |
Your problem could be nothing more than the lever hinge bolt done up too tight. This would cause the span adjuster to push on the plunger rather than opening the span.
Squeeze the brakes then let them go. Push the lever away and watch the plunger. If it moves, loosen the locknut on the underside of the lever hinge and un-do the allen bolt a fraction of a turn to loosen the hinge. ____________________ a.k.a 'Geri'
| Quirky |
| Quirky |
The last post was made 10 years, 315 days ago. Instead of replying here, would creating a new thread be more useful? |
