| BillyJ |
 BillyJ Nearly there...
| bikenut |
 bikenut World Chat Champion
| mysterious_rider |
 mysterious_rider World Chat Champion
| stinkwheel |
 Posted: 13:36 - 19 Mar 2015 Post subject: |
I wouldn't use gasket goo INSTEAD of a gasket, I'd only use it where a gasket was sealing in a questionable manner due to slight warping/scratching and needed a little backup.
I use Permabond A136 for most things. It is liquid and can be applied very thinly with a spreader or paintbrush and smells of red liquorice. It only sets when compressed. so you can apply it then wipe it away from the inside edge of the casing with a rag.
I use wellseal for cylinder heads which can also be painted on and stinks of heavy duty, highly toxic industrial solvents (for good reason).
I only use either sparingly and only if I have to.
So if you can no longer buy gaskets, you're going to need to make them for yourself.
Engine cover gaskets are usually paper.
So cut a new one out using the cover as a template, take care not to miss any holes corresponding with oilways. A paper hole punch is handy.
You can buy proper gasket paper or, like me and many others, use some stiff card like the back of a cornflakes packet.
You can also buy viton rubber or silicone sheet to make rubber gaskets and copper sheet to make head gaskets. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stinkwheel |
| sickpup |
 sickpup Old Timer
| Islander |
 Islander World Chat Champion
| BillyJ |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 16:15 - 19 Mar 2015 Post subject: |
Place the gasket paper on a smooth soft surface - I use an ironing board covered with a cloth.
Press the part you are making the gasket for, firmly onto the paper to get an impression of the outline, which you can then cut out with scissors (I find nail scissors best for small items like carburettor gaskets).
For 'instant gasket' silicone, I would apply a thin bead to one part only, then align and press both parts together firmly for a couple of seconds, then pull them apart to remove the surplus - checking that you have continuity on both parts.
Leave them to dry partially for a few minutes before re-assembly. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Vincent |
 Vincent Banned
 Posted: 17:23 - 19 Mar 2015 Post subject: |
I had to use a cornflake packet on an alternator once as an emergency repair. Even the small difference in thickness caused the end of the crank to run too close to the inside of the casing and they welded themselves together...so ja....not a good idea to miss the gasket out completely on some applications  ____________________ Space Is Deep |
| temeluchus |
| mysterious_rider |
| Nobby the Bastard |
| stinkwheel |
 Posted: 19:37 - 19 Mar 2015 Post subject: |
The main thing with any gasket compound in a motorcycle engine is not to get any in the engine.
That means a thin application, keeping away from the inside edge of the gasket surface and well away from any oilways.
Some gasket compounds should be allowed to dry before fitting, some should not, some don't set at all. As such, you'd need to follow the manufacturers instructions in that respect.
Keep in mind that the stuff tends to squeeze and spread out when you tighten the part down. Might even be an interesting exercise to see how far it moves by applying some to a small section, fitting it, then removing it and seeing if any squeezed out on the inside.
When I use my permabond stuff as a sealant (so round my carb gasket last time I used it), I apply a very thin line of it all round the casing about 1/3 of the way in from the outside edge. I'm aiming to just see a line of the stuff around the edge when it's all tightened down but not enough to wipe away with a cloth.
Here's how not to do it (the orange stuff is instant gasket). The cam is fuxored due to oil starvation due to instant gasket in the oilways.
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image028.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
 WD Forte World Chat Champion
 Posted: 01:24 - 20 Mar 2015 Post subject: |
If you're allowed to play with sharp things
making your own is easy enough
You need tea buns fags soothing music and other stuff
like gasket paper, scissors and craft knives.
The screwdrivers with tapered shafts are for pushing down the
bolt holes to lock it in place especially before cutting the inner and outer profiles
I prefer to use the scalpel type knives and use an up down sawing motion rather than drag a blade along this helps keeps the paper flat
https://oi62.tinypic.com/vik5z4.jpg ____________________ bikers smell of wee |
| stevo as b4 |
| Iain. |
 Iain. Could Be A Chat Bot
| bikenut |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 13:22 - 20 Mar 2015 Post subject: |
It always pisses me off, when someone uses a sealant instead of proper seals/gaskets. I've seen things and they did not make me happy.
Carburetors full of that crap, engine heads completely messed up with it, exhaust pipes ''glued'' together with it and so on. Just say no to Ollie McBotcher and his mates from Botchertown, South Botchington.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| A100man |
 A100man World Chat Champion
 Posted: 13:40 - 20 Mar 2015 Post subject: |
Cut my fingers slicing a carrot the other day - still, look like a recipe for a decent night in.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Islander |
 Posted: 16:55 - 20 Mar 2015 Post subject: |
A mild case of potato there, Iain - no LH crankcase cover gasket in that kit. It's a top end set.  |
| BillyJ |
 Posted: 21:45 - 22 Mar 2015 Post subject: |
Woops sorry for late reply, BCF mail has stopped telling me I have replies to posts...
Yep, thanks iain but I have seen those (you wouldn't believe I ebay/google/wemoto'ed it before posting )and they only make top end gasket sets so no use to me, I need crankcase gasket.
I am slowly not liking the idea of using instant stuff, I was going to apply some, close it up, wait 24h, remove the cover and see it I did it right...then do it again. I would rather just make a paper one.
Is the best way of doing it without taking the engine off the bike to somehow mark the sealing surface and press the paper onto there so you know where to cut? ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser" |
| Islander |
 Posted: 22:08 - 22 Mar 2015 Post subject: |
I've just done this on my M900 after changing the ignition pickups. I used the Ducati badged 3 Bond (this is what they use in the factory) cleaned both mating faces with some brake cleaner (excellent degreaser and it removes the old sealant a treat with a bit of a scrub with an old toothbrush) and ran a thin bead of the sealant inside of the bolt holes and down the middle of the rest of the cover. Refitted the cover and am leaving it a full 24 hours to cure before I refill with oil.
Remember that the crankshaft end float will be based on the use of 3 Bond and using a paper gasket might throw this out.
Ducati stopped using paper gaskets for this sort of thing a while ago which is why you can't find any. 3 Bond is the correct stuff to use.  |
| BillyJ |
| Islander |
The last post was made 11 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
