Mineral oil vs Fully synthetic, what is there to be gained?
simon1221
PostPosted: 19:48 - 29 Jan 2005    Post subject: Mineral oil vs Fully synthetic, what is there to be gained? Reply with quote
Mineral oil : Castrol Super TT £5
Fully Synth : Castrol TTS £10
I have been up to know using mineral oil, (without me knowing, Castrol Super TT), but then found that they also do Castrol TTS (fully synthetic, twice the price).I brought some and I am about to drain the tank to replace it with TTS, but is there much to be gained over mineral oil (apart from more protection), i mean things like power acceleration etc?
It was run previously on Fully Synth oil so i dont reckon it has done much damage.
PostPosted: 20:44 - 29 Jan 2005    Post subject: Reply with quote
The fully synthetic is better , but depending on the bike I would not bother. Never did when we had a TZR125.
Also, very rarely will there be a reaction between fully and mineral oil. As they are both Castrol oils I would not worry at all.
Scotsman37
PostPosted: 20:48 - 29 Jan 2005    Post subject: Reply with quote
This is what is noted on Castrol's homepage in regards to your Yamaha TZR125;
Which oil should I use?
Print this page
Steps:
Category : Retail
Sub-category : Motorcycles
Manufacturer : YAMAHA
Model : TZR 125R
Year : 1992-
Engine : 2 str.
Climate : ALL
Change Selection
Your Recommendations
recommendations are
EngineTTS
R2 RACING BIKE
Fork: SYNTHETIC FORK OIL 5W
Gearbox: MTX
Coolant: MOTORCYCLE COOLANT
Grease Points: LM GREASE
Brake and clutch fluid: RESPONSE DOT 4
Technical data sheet for TTS;
TTS
________________________________________________________________________________
Applications
Castrol TTS is a fully synthetic 2-stroke engine oil that has been designed to maintain a tough replenishing layer of protection on critical engine parts. It reacts to changes in engine operating temperature which frequently occur in highly powered 2-stroke engines, releasing extra protection as it's needed. Castrol TTS will provide maximum and sustained engine performance, even at wide open throttle and high engine speed conditions. It delivers unbeatable protection against thermal and mechanical breakdown.
High output motorcycle engines require a high performance lubricant that will provide extreme protection at maximum engine speed, load and temperature. Castrol TTS outperforms competitor oils when tested to the limit at high revs and at very high temperatures.
Castrol TTS is designed for use with all the highest powered 2-strokeJapanese and European road and off-road motorcycles. Castrol TTS is designed for both oil injection and pre-mix lubrication, as per manufacturers' recommendations, up to a fuel/oil ratio of 50:1. Castrol TTS is fully compatible with both leaded and unleaded petrol.
Features / Benefits
Fully synthetic 2-stroke engine oil
Generates a tough, heat resistant layer of protection
Designed for both oil injection and pre-mix use
Extreme protection even at maximum rpm
Protection against thermal and mechanical breakdown
Protection against ring sticking and engine seizure
Engine cleanliness
Visibly low exhaust smoke
Specifications / Performance
ISO L E-GD
JASO FC
API TC
Scotsman37
PostPosted: 20:52 - 29 Jan 2005    Post subject: Reply with quote
Technical data sheet for Super TT;
Super TT
Applications
Castrol Super TT is a quality 2-stroke engine oil, specially formulated to provide long term engine protection. It also prevents ring sticking throughout the life of the engine whilst minimising smoke emissions to an acceptable level.
Castrol Super TT is suitable for both oil injection and pre-mix lubrication and can be used up to a fuel/oil ratio of 50:1 or ratios recommended by engine manufacturers.
Castrol Super TT is recommended for on-road motorcycles and mopeds
Features / Benefits
a mineral based 2-stroke engine oil
designed for both oil injection and pre-mix lubrication up to a ratio of 50:1
durable protection against piston ring sticking
internal engine cleanliness
minimises smoke emissions
JASO FB
cagiva gezzer
PostPosted: 21:03 - 29 Jan 2005    Post subject: Reply with quote
Power differences only come into play when you start changing mixing ratios and from normal oil to castor oil.
There are a few pages in THIS book.
I've found that the cheaper the oil the less well it burns off and the more likely you are to have ring and power valve issues.
The last post was made 21 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 47.25 Kb
