| spannermonkey... |
 spannermonkey... Renault 5 Driver
 Posted: 16:14 - 20 Mar 2015 Post subject: Kawasaki ZX7r 2001 Lumpy and rough. Help/ideas please. |
Hi all brain teaser.
Day 35 in the garage post rebuild.
I carried out a piston ring change as it sounded rough and carb balancing couldn't sort it and only two valves were tight. So I was low on compression after a wet check. I checked the bores as per the book and honed with new rings, head is flat with valves lapped in with correct clearance and timing. All new parts used if near tolerances.
No fancy mods all standard except for a motad headers.
First start after a rebuild and it ran really sweet. It ran for 5 minutes, while I was purging air from the water system. Then when I restarted it ran like a twin or triple
So I checked and cleaned the carbs again, fuel level spot on (I've done both tests), pilot air screw clean and set to 1 3/4 out (UK) diaphragms good as was everything else.
Also tried timing 180 over but kind of pointless when it has a wasted spark.
Fuel pump was iffy and was bleeding internally so no pressure at the carb so changed that for a Kawasaki one as fed up with pattern part rubbish.
Carbs balanced or close as cant run it long enough to get a good value but really close on the gauges.
I have resistance checked the CDI, pump relay, pick up all good as per the book.
I had DYNA coils and what rubbish lasted less than a year. Supposed to be 3 ohm but now measure 5 ohms with secondary windings around 14000. So I brought a pair off fleabay at 20 each, just worth a punt, they put out 2.8 ohms and 18000 ohms. Meaning the amp of the spark is bigger than so called performance parts so don't waste your money on dyna coils.
New leads and caps.
So now the engine starts and runs even idles but sounds like a triple or twin, header pipes are all hot at same temp.
It coughs out of the carbs intermittently with air box fitted with standard air filter. Lean? so played with pilot air screw no change, check valves again and within tolerance and timing is good.
So I popped the new plugs out, one was slightly sooty but dry, the other three were wet, top of pistons are wet also.
Oil/Fuel? possibly.
Can the float needles cause this, leaking past the seat, could it be the rings? I've honed them in but with hardly any run time they are still new so compression would be low still - 7.3-8 bar across all 4.
could the head of lifted after first run?
What do you all think?
I have con/volt checked wiring, switches, ran it in the dark looking for sparks from the ignition system.
I'm aware of fuel passing the rings and filling the sump. it will be changed once it behaves.
By book I mean Kawasaki service manual and Haynes.
any help would be great. |
| spannermonkey... |
| misscrabstick |
 misscrabstick Crazy Courier
| spannermonkey... |
| spannermonkey... |
| misscrabstick |
| spannermonkey... |
| evoboy |
 evoboy World Chat Champion
 Posted: 22:47 - 22 Mar 2015 Post subject: |
Are all the pipes for the carbs in good condition?
The zx7 uses pressurised float bowls. When mine had issues like this ( one of many I might add) it was due to a split vac pipe. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| misscrabstick |
| spannermonkey... |
| mentalboy |
 mentalboy World Chat Champion
| spannermonkey... |
| spannermonkey... |
| Zx7rSWFC |
 Zx7rSWFC L Plate Warrior
| spannermonkey... |
| spannermonkey... |
The last post was made 11 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
