Average mileage for a 125 before it goes bang?
Dave70
PostPosted: 21:28 - 21 Mar 2015    Post subject: Average mileage for a 125 before it goes bang? Reply with quote
Partly out of curiosity and partly out of needing to have some idea, what is the general ballpark area that you can expect a decent brand 125 to last, mileage wise?
It's just that I'm getting a little concerned after looking at a lot of bigger bikes that are 10-15+ years older than my 125, yet have roughly the same or quite often less mileage than my R125 and I'm getting a little concerned (possibly wrongly so but, it doesn't help when some folks mention that it's got a high mileage at times) that some day soon, while giving it full throttle miles away from home, that the engine is going to blow up and die. Shocked
A brief history of my bike. As already mentioned, its a Yamaha R125, bought from new (stop laughing Tut Tut ) in August 2012. It has had a full Yammy dealership service history at the appropriate intervals (actually it's had a couple more than recommended ) for the first two years, mainly for warranty purposes but, also I trusted the mechanic back in the IoM and their prices were a lot lower than local Yammy dealerships in the UK.
The bike has around 26,000 miles on the clock and apart from regular oil and air filter changes, the only other thing that has been replaced are its chain and sprockets (and tyres, obviously).
Should I have any reason for worrying a little or, if looked after, should it still keep going for another 25,000 miles?
Also, are there any specific parts of the bike that I should have thoroughly checked over at this point, that may be a cause for concern?
Apologies if the post sounds a bit daft but, I am not mechanically minded in any way but, I hope some on here who are could give me a heads up if needed or inform me that I shouldn't have any concerns for a while yet.
Supermoto_Fan
PostPosted: 21:32 - 21 Mar 2015    Post subject: Reply with quote
There have been more than a few cases of the R125 motor going bang but I would say if you've reached 26k without any issues your good for another 26k.. Keep an eye out on oil level. They only hold a litre so burning off 200ml can be more of a problem than a bike that holds 2.3 litres of oil.
The swingarm and wheel bearings will probably give up before the motor does
Nemo
PostPosted: 21:36 - 21 Mar 2015    Post subject: Reply with quote
I think one of the problems with 125s is that the engine works harder, because you have to rag them to go anywhere.
If you keep doing what you're doing with the servicing you should be good engine wise. Keep the bike clean to prevent corrosion in the wrong places.
Change the air filter and spark plug every three services or so. Also remember coolant change every 3 years, brake fluid every 2 years.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
PostPosted: 21:57 - 21 Mar 2015    Post subject: Reply with quote
Looked after, most engines should outlive the bike.
Abused, then you are in trouble.
Regular oil changes in my opinion are the only thing that gave my Vara the strength to get where it got Laughing
Dave70
PostPosted: 21:58 - 21 Mar 2015    Post subject: Reply with quote
It's on full throttle 90% of the time tbh Laughing
Spark plug was changed about 6 months back, though I'd never had any issue, it seemed the right thing to do.
Aye, it gets a regular cleaning, except winter but, is covered in ACF 50 during that time.
Cheers for the brake fluid advice Thumbs Up I'll get that sorted, as it'll be overdue by now. Coolant has been changed a couple of times already. Thumbs Up
XBIKER
PostPosted: 22:05 - 21 Mar 2015    Post subject: Reply with quote
Honda Varaderro 125 was still going strong after 79,000 miles from new and that was being pushed hard from morning to night. Another one reached 68,000 miles before being traded in.
Several Honda CG 125's also reached well into the 60,000's which as previously mentioned is all down to regular oil changes and generally looking after them although I must admit that sometimes those CG 125's came in for servicing with just a dribble of oil left Shocked
Probably testament to how tough those little bikes are.
Dave70
PostPosted: 22:15 - 21 Mar 2015    Post subject: Reply with quote
Cheers for the info guys Thumbs Up
I think one of the things that had been playing on my mind a little also, was that a while ago, I saw another R125 for sale that had around 22,000 miles on the clock and it said that it had a total engine rebuild. That, along with so many much older bikes out there with far less miles than mine, started me thinking that I'm going to kill mine.
Anyways, all being well on the financial front, I hope to move up to something bigger soon. Would still like to get a reasonable amount for mine though. So glad to hear it's not nearly deaded. It's one less thing to worry about. Very Happy
DrSnoosnoo
PostPosted: 22:35 - 21 Mar 2015    Post subject: Reply with quote
Dave. It'll be fine. You look after your bike. The bike is designed to be ragged and they designed their service schedule to reflect that. IMO you change the oil regularly, check valves when they're due and the engine should be fine.
As has been mentioned, bearings will start to go before the engine and they're replaceable. Obviously the longer you keep it, the more likely you'll need to fork out for replacements.
I love bikes how people see 30k as high mileage, I bought my car with 72k and that was considered low miles. Providing the bike hasn't been owned by total spaz who has never changed the oil, surely it should be ok, that and they don't ham fistedly attempt wheelies every second traffic light.
PS, if you ever want to attempt any work on your bike, give me a shout and I can come and drink your tea and observe your failures, I'm hardly a master but I've not broke mine yet.
Dave70
PostPosted: 23:19 - 21 Mar 2015    Post subject: Reply with quote
Cheers Sam. Thumbs Up
As for valves, I probably shouldn't admit this here but, I'm merrily drunk, so fk it. I don't know what a valve is Laughing not on a bike anyway. Never mind how to check one. Laughing
If I was closer, I'd take you up on your offer but, it's a hell of a long way to ride to and couldn't possibly expect you to ride all this way, just to show some mechanical noob what things are and do.
However, if you feel the need for another Wales trip anytime, I'm sure we could work something out. Thumbs Up
Oh shit! That sounded a bit gay Shocked Just to clarify, there are no gay offerings in this post. Thumbs Up Laughing
DrSnoosnoo
PostPosted: 23:31 - 21 Mar 2015    Post subject: Reply with quote
Honestly, Dave, I didn't know what valves where until I decided I'd take up the challenge on my bike!
Do you have a Haynes for your bike? I managed to get one off the net for mine. At first, everything seems complicated but when you read through and see the pictures it becomes clearer When you read it a few times. And on yours, it's one cylinder so very few valves as opposed to the 16 on my bike!!
My technique is to take pictures of everything as you go and then it can all go back together easily enough.
I've got a new job nearby to Burnley and will be moving this year so I'll be closer to lend a hand in the future.
Ed Case
PostPosted: 23:51 - 21 Mar 2015    Post subject: Reply with quote
Frequent oil changes (four strokes) every 1000 miles or so, wont break the bank + good basic maintenance and they should last for the life of the bike no matter how they're ragged.
PostPosted: 23:56 - 21 Mar 2015    Post subject: Reply with quote
Dave70 wrote:
Coolant has all leaked out a couple of times already. Thumbs Up
We do keep notes here.
You're doing all you can, but you've very likely got one of the highest mileage examples around. Here be dragons.
Dave70
PostPosted: 00:50 - 22 Mar 2015    Post subject: Reply with quote
I've had intermittent issues with overheating but, the only report I've had that it had lost any coolant, was from a mechanic. Of whose report I have since been doubtful of. Mainly, as I had kept a close eye on it prior and since his verdict and have never found this to be the case personally. Although, the overheating issue continues from time to time, yet it appears to inexplicably resolve itself Eh?
The only other possible explanation for it overheating was for was an airlock, caused by a small dent in the radiator but, after posting photos up on here, everyone on here who replied in the mechanical section, poo pooed this as the cause, as the dent seemed insignificant and it still remains a mystery to this day. Neutral
Basically, after much checking by various mechanics, much observation and checking of hoses for leaks by myself and posting pics of the radiator on here, as well as seeking advice, no-one is any the wiser on this issue.
Dave70
PostPosted: 01:17 - 22 Mar 2015    Post subject: Reply with quote
Give us a shout when you've moved. Burnley is only up the road from here. Thumbs Up
kestrel
PostPosted: 08:49 - 22 Mar 2015    Post subject: Re: Average mileage for a 125 before it goes bang? Reply with quote
In order to absolutely guarantee the longevity of your bike it should be returned to the Isle of Man during the first week in June each year. Once there it should have it's neck mercilessly wrung around the TT course and thrashed to within an inch of it's life several times daily for the entire week. Laughing
On a more serious note, how are things going back on the 'Adjacent Isle' Dave?
Isle of Man.........Road Racing Capital Of The World
PostPosted: 10:27 - 22 Mar 2015    Post subject: Reply with quote
Keeping accurate notes would be pedantic.
Dave70
PostPosted: 00:39 - 23 Mar 2015    Post subject: Re: Average mileage for a 125 before it goes bang? Reply with quote
I'll no doubt make it back for a TT sometime. Mr. Green
Things are generally going quite well tbh and glad I made the move thanks Thumbs Up
Being able to travel further afield on the bike is much easier when you don't have the Irish Sea to contend with Laughing
Like everything, there's pros and cons to living anywhere and as much as I loved living on the IoM, 14 years was long enough for me and all my family and good friends are here in Liverpool. I do miss having the course to ride around whenever I want, which was most days tbh Laughing but have been doing a bit of touring around the UK with a group of bikers. A euro trip will be on the cards in the not too distant future, all being well.
My job's a lot better here too, nowhere near as many assholes. Very Happy I do miss the proper Manx folk though, they're a great bunch of people. Thumbs Up
The last post was made 11 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 103.04 Kb
