what are the factors that affect brake locking?
NeolWhyt
PostPosted: 14:00 - 22 Mar 2015    Post subject: what are the factors that affect brake locking? Reply with quote
Hey guys, I'm new here. I just wanted to know what are the qualities that causes disc brakes to lock up. Because I used Bajaj Pulsar 200 ns. And its brakes are super sensitive which is sort of annoying cuz, just jamming the rare brakes at around 80kmph causes the brakes to lock up. But when I do the same speed on an R15 and jam the brakes it doesn't lock up but provides equally efficient braking. So what exactly do I need to notice about brake specs to know if they lock up easily?
Thanks in advance.
Islander
PostPosted: 14:09 - 22 Mar 2015    Post subject: Reply with quote
Simple answer? The friction between the tyre and the road surface is the main factor decent tyres are the obvious thing here but keeping an eye on the road surface is important too. Progressive braking makes a difference as well - i.e. not snatching at the brakes but applying them firmly and progressively.
NeolWhyt
PostPosted: 14:24 - 22 Mar 2015    Post subject: Reply with quote
Well yeah, the 2 bikes have different tyres. So is that all that matters? If I change the tyres to a better pair, It'll avoid locking up? I expected brake pressure to do more than tyre quality.
c_dug
PostPosted: 14:40 - 22 Mar 2015    Post subject: Reply with quote
The biggest factor of all is rider technique, "jamming" on the brakes will cause them to lock.
PostPosted: 15:12 - 22 Mar 2015    Post subject: Reply with quote
So, you've cleaned your caliper and pistons, and ensured that the M/C piston isn't being held in by the brake lever?
NeolWhyt
PostPosted: 15:29 - 22 Mar 2015    Post subject: Reply with quote
Lol yah, I only jam when I don't have an option. But then realised even though I jammed on the R15 it didn't lock up. Tried it again n again. Same results
NeolWhyt
PostPosted: 15:32 - 22 Mar 2015    Post subject: Reply with quote
yeah the callipers are clean, BTW what's "M/C piston"?.. And its not just my bike. Generally the 200 ns brakes lock up easier than the R15. Both use Byber.
RhynoCZ
PostPosted: 15:57 - 22 Mar 2015    Post subject: Reply with quote
Yamaha, a rather respected motorcycle manufacturer vs. Bajaj. Rolling Eyes
I'm not sure what brakes do these come with, but I am sure Yamaha wouldn't sell a dangerous piece of crap with their brand on it. Thumbs Up
MC = Master cylinder, the pump that's on your right handlebar and you operate it with the brake lever.
Brake pads, the suspension, frame geometry... are also very important Thumbs Up
EDIT: Tyres are not as important as people would think, when being o dry tar on smaller/light motorcycle. I've done some miles on my mates 150 ETZ and there's a very hard compound front tyre, that's, at a guess, 10+ years old. I got into trouble a couple of times, and grabbed the front brake, the wheel never blocked. I wouldn't ride it fast in wet, but on dry tar, it's alright. And that my friend, is a disc front brake made in the wrong part of the Germany 30 years ago. Thumbs Up
PostPosted: 16:35 - 22 Mar 2015    Post subject: Reply with quote
And the pistons? They're clean, and you can push them back in easily with finger pressure?
Do you have aftermarket levers?
NeolWhyt
PostPosted: 01:49 - 23 Mar 2015    Post subject: Reply with quote
Like i said bro... Both come with byber...
NeolWhyt
PostPosted: 01:54 - 23 Mar 2015    Post subject: Reply with quote
yeah everything is supposedly how it should be.. I had specified the service centre to take a look at the brakes.. And no, everything is stock...
RhynoCZ
PostPosted: 07:48 - 23 Mar 2015    Post subject: Reply with quote
Well, they did nothing, rebuild the master cylinder and bleed the system.
Just because they both come with the same stuff, does not mean that it was fitted properly. The factory checkout/quality control is just not the same.
PostPosted: 09:06 - 23 Mar 2015    Post subject: Reply with quote
And what exactly did they do?
Unless you watched them do it, I'd get those calipers off and see for yourself.
misscrabstick
PostPosted: 10:37 - 23 Mar 2015    Post subject: Reply with quote
Did the Yamaha have ABS?
Taught2BCauti...
PostPosted: 13:28 - 23 Mar 2015    Post subject: Reply with quote
Brakes work by converting the energy of motion into heat, through the friction created between the disc pad and the disc, which is then dissipated into the air by the rotation of the disc.
When the brake locks, this process stops working, so the only thing slowing you down is the friction between the tyre and the road - which is usually not as efficient, because weight is being shifted forwards, and the contact surface between rubber and tarmac is reduced.
If the 2 bikes have the same weight distribution, and too much pressure is applied to the 'rare' or rear brake on the Pulsar, that would cause it to lock up.
One thing to look at here, would be the relationship between the diameters of the pistons in the master cylinder and the caliper, and the length of the brake pedal either side of the pivot point on both bikes, as this would determine the amount of pressure applied to the pads for the same amount of foot pressure.
On the other hand, if you know this to be a problem, simply get used to using a little less pressure on the rear brake, and perhaps a little more on the front.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 14:07 - 23 Mar 2015    Post subject: Reply with quote
Aaaaaaah. Thanks for the English translation. Idea
OP: use the front brake. Laughing
c_dug
PostPosted: 14:26 - 23 Mar 2015    Post subject: Reply with quote
One other thing, if you can't deliberately lock the Yamaha rear break, even by slamming it on suddenly, it would suggest to me a problem there too.
Most bikes, especially Ultra-uber-epic-sports bikes such as the R125 should lock the rear up with ease.
Taught2BCauti...
PostPosted: 14:38 - 23 Mar 2015    Post subject: Reply with quote
If you break your brake, will it be bracken?
Acemastr
PostPosted: 15:01 - 23 Mar 2015    Post subject: Reply with quote
Tires make ALL the difference with brakes that lock the tire... the wheel will be significantly harder to lock if you have decent tires making good contact with the road... I don't even understand why you said that. Brakes, 99% of the time, are limited by the traction of the front tire...
OP, don't jam on your brake... you should NEVER need to do this as it will simply spit you off the bike.
2016 Toyota Tacoma Limited
RhynoCZ
PostPosted: 15:56 - 23 Mar 2015    Post subject: Reply with quote
My own experience, as I was saying. Also, if you think that the front tyre makes 99% of your braking power possible, you should get medical examination this instant. Smile
By your idea of physics, if I buy a 'murican custom chopper with very long front end and put a 200 quid tyre on it, it will brake like a superbike. Razz
salem1987
PostPosted: 16:05 - 23 Mar 2015    Post subject: Reply with quote
a yammy with blue spot callipers an decent pads or whatever (something decent) is going to lock a 15 year old rock hard tyre quicker than a brand new super soft and sticky sc0 supercorsa tyre no?
Acemastr
PostPosted: 17:24 - 23 Mar 2015    Post subject: Reply with quote
I think you're being a bit pedantic as we aren't speaking about a chopper...
How hard you can brake is related to tire traction nowadays, brakes have gotten to the point they aren't the limiting factor anymore
Carvel
PostPosted: 17:38 - 23 Mar 2015    Post subject: Reply with quote
No
You completely missed the point.
RhynoCZ
PostPosted: 18:07 - 23 Mar 2015    Post subject: Reply with quote
What are we talking about? I said a small = LIGHT, motorcycle on dry tar. You then went to 200kg+ 1000cc superbikes. Confused
I did what I did on a '88 150 ETZ equipped with 10+, my mate says 19, years old front tyre, hard as rock and I'm still here. OP is talking about R15 and some Bajaj 200.
I say tyres are not the answer to every question you have, and that's it.
Acemastr
PostPosted: 18:27 - 23 Mar 2015    Post subject: Reply with quote
It clearly is the tires if they are locking... that shows there's plenty of bite from the brakes and it overcomes the traction of the tire...
The last post was made 11 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 133.73 Kb
