Bike wont start. Something I have missed?
Gazz
PostPosted: 16:03 - 22 Mar 2015    Post subject: Bike wont start. Something I have missed? Reply with quote
Trying to get the Deauville back on the road after been sat up over winter, but it wont start.
Put in new fresh fuel, checked the fuel switch, battery is fine (was on charger over winter), and checked side stand sensor (cleaned it). The bike is turning over but wont kick into life....
Anything else you can suggest?
RhynoCZ
PostPosted: 16:22 - 22 Mar 2015    Post subject: Reply with quote
Have you drained the carburetors? Is the choke working? Do you happen to own ether (starter spray)?
Gazz
PostPosted: 16:34 - 22 Mar 2015    Post subject: Reply with quote
Didn't drain carbs. Choke is fine. Not sure - all my fluids are at the back of the garage which I cannot get to at the moment because the garage is a fucking tip. Luckily the Deauville was at the front door, albeit covered in sawdust and looking sorry for itself.
waffles
PostPosted: 16:43 - 22 Mar 2015    Post subject: Reply with quote
Pull some fresh fuel through the carbs and then give it a go.
PostPosted: 16:51 - 22 Mar 2015    Post subject: Reply with quote
Pull plugs. Quick clean and drop of fuel down bore, try again.
RhynoCZ
PostPosted: 17:07 - 22 Mar 2015    Post subject: Reply with quote
This is an alternative to ether. Thumbs Up Smile
red5
PostPosted: 17:32 - 22 Mar 2015    Post subject: Reply with quote
Same problem on my gsx750,
Changed the fuel in the tank but didn't drain the carbs.
Put the choke on full, fully opened the throttle then cranked the engine a few times. This obviously flooded it so gave it a few mins then put the choke on again left the throttle alone pushed the starter and away it went.
Sounded a bit rough for a min or two but soon cleared and runs fine now. Thumbs Up
The last post was made 11 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 51.28 Kb
