brake light not working YBR *solved*
sutty86
PostPosted: 20:22 - 22 Mar 2015    Post subject: brake light not working YBR *solved* Reply with quote
anyone give me any advice on this, tailgate light is on but doesnt brighten when braking.
monkeybiker
PostPosted: 20:32 - 22 Mar 2015    Post subject: Reply with quote
Change the bulb
sutty86
PostPosted: 20:39 - 22 Mar 2015    Post subject: Reply with quote
done just changed it now no change its got two filaments also.
all other lights are fine also
PostPosted: 21:13 - 22 Mar 2015    Post subject: Reply with quote
The 2nd filament, does it come on:
Never.
When the front brake is applied.
When the rear brake is applied.
On closer examination, might it be on all the time?
sutty86
PostPosted: 21:33 - 22 Mar 2015    Post subject: Reply with quote
Just checked now both are lit and stay lit don't change if applying brakes
Blinded ATM
This bike just keeps getting better
WD Forte
PostPosted: 21:44 - 22 Mar 2015    Post subject: Reply with quote
One of your brakelight switches may be stuck on
if so, probly the rear one as these tend to get covered in shite
disconnect in turn to test
bikers smell of wee
Taught2BCauti...
PostPosted: 21:55 - 22 Mar 2015    Post subject: Reply with quote
Make sure the stop/tail bulb is in the right way round - sometimes it's possible to insert the bulb incorrectly by 180° so the brake light is on when the tail light should be lit, and when you apply the brake, it doesn't look any different.
Also, check your manual for adjustment of the rear brake light switch - most bikes have an adjustment on the back, but not the front.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
sutty86
PostPosted: 22:02 - 22 Mar 2015    Post subject: Reply with quote
Thanks all we try this right away
sutty86
PostPosted: 23:08 - 22 Mar 2015    Post subject: Reply with quote
WD you was right...hook wasnt connected right putting constant pressure on switch.
All sorted now.
Tried the bulb but only goes in one way ...
Thank you all!!!! Saved me a headache
Raffles
PostPosted: 23:19 - 22 Mar 2015    Post subject: Reply with quote
sutty86 wrote:
WD you was right
There's a first time for everything Wink
The last post was made 11 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 60.6 Kb
