| NJD |
 NJD World Chat Champion
| smallfrowne |
 smallfrowne Scooby Slapper
| NJD |
| Robby |
 Robby Dirty Old Man
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:30 - 23 Mar 2015 Post subject: Re: Funky Clutch + Idol Speed.. |
| NJD wrote: | moving the biting point closer to the handlebar and increasing the overall free play.. |
I'd go for a minimum of free play. Just enough so that the actuator lever on the clutch housing definitely isn't being pulled until you pull the lever at the bars.
As in: slacken it off until the actuator on the clutch housing stops moving and there's clear slack in the mechanism. Tighten up to take the slack out. Continue to tighten and watch for the actuator lever just starting to move. Slacken off a touch until it relaxes. Done.
This takes about as long to do as to describe and it's very straightforward.
| NJD wrote: | shift down into 1st gear.. the bike jolts forward quite harshly.. go back into neutral and do the same again and it doesn't happen. |
Normal. This is the clutch plates unsticking. All bikes do it to some extent.
You could try (before starting it up) pulling in the clutch and kicking it to see if this unsticks the plates. This works on Enfields where the kick starter goes via the clutch, but I can't recall how the kick starter is plumbed on the CG. Worth a try.
| NJD wrote: | I've got the clutch lever pulled in attempted to go form 2nd to 1st sometimes the gear indicator goes blank or takes a couple of tries (only happened a couple of times). |
I'd tighten the cable, as above.
| NJD wrote: | Is it worth increasing the revs from 1,500rpm to 2,000rpm.. can't help but feel that the engine is running a little cold causing it be a little jerky in terms of power on some (not all) rides. |
I'd expect it to be fuelling rather than temperature.
Have you tried adjusting the idle mixture screw? It's the small brass screw at the front of the carb pointing downwards: you'll need a short screwdriver (or just use a screwdriver bit) to turn it.
Warm up, adjust the mixture screw in 1/4 turn increments in both directions until you've found the fastest idle speed.
I'd wind it all the way in first and count the number of turns so that you can put it back to where you started if you get lost.
I found that my HN was happier above 1500 rpm, although as it put miles on, it got happier idling more slowly. ____________________ Biking is 1/20th as dangerous as horse riding.
| NJD |
| Rogerborg |
 Rogerborg nimbA
 Posted: 18:23 - 23 Mar 2015 Post subject: Re: Funky Clutch + Idol Speed.. |
| NJD wrote: | just didn't happen before the adjustment so wondered if it was a result of to much free play. |
Could very well be. With more slack on the cable you're not pulling the plates apart as hard.
It takes seconds to adjust the cable tension. I've done it on the move (not a recommendation, an observation).
| NJD wrote: | | Rogerborg wrote: | Have you tried adjusting the idle mixture screw? |
Not yet, unless the dealership have adjusted on a service then it has stayed the same as factory set it to.. |
Don't assume that's ideal. Carbs are fairly crude and do benefit from tuning. I'd heard that these bikes come set lean to get through Euro 3 emissions, and mine did indeed benefit from richening.
It's another very simple, very quick job that you can perform easily yourself and you'll likely do a better job of it than a dealer who has no real vested interest in getting your bike running perfectly. ____________________ Biking is 1/20th as dangerous as horse riding.
| NJD |
| mentalboy |
 mentalboy World Chat Champion
The last post was made 11 years, 214 days ago. Instead of replying here, would creating a new thread be more useful? |
