| evilzed |
 evilzed Scooby Slapper
 Posted: 21:26 - 23 Mar 2015 Post subject: Weird start up issue (Video) |
Anyone know why this happens on a second start up from cold? It always happens when I start the bike from cold once it's warmed up it starts up fine every time. My guess it's something to do with the oil being spread across the engine but it should be making things easier not harder to run (Castrol motorcycle 10w30 btw)
https://youtu.be/i0Z-9Qa-JQM
And on a side note on the image attached can somone tell me what these pipes are?
https://i.imgur.com/ALWoY0J.jpg?1
Thanks! |
| Jiving Joe |
 Jiving Joe Two Stroke Sniffer
 Posted: 21:37 - 23 Mar 2015 Post subject: |
They are overflow/air vent pipes, completely normal
Engine .. sounds fine to me but I always use 10w40 ..
Some one else might be able to hear an issue thou  ____________________ ZX6R B1H |
| evilzed |
| mentalboy |
 mentalboy World Chat Champion
| misscrabstick |
 misscrabstick Crazy Courier
| evilzed |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 00:20 - 24 Mar 2015 Post subject: |
Well, being cold is the problem I guess. How's the outside temp there 10°C or below? It's pretty normal for bike to ''hesitate'' when it's cold. Fresh spark plugs would help actually.
By the way, why did you put 10W30 in it? 10W40 does the same thing, but can be used in temps above 30°C, which you will experience during the summer.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| evilzed |
| RhynoCZ |
 Posted: 11:14 - 24 Mar 2015 Post subject: |
It is what you call it, overflow hoses. When there's too much of petrol somewhere, it'll overflow via these onto the ground. These are quite small diameter, so they could easily be mounted onto the bowls of the carbs, so when you drain them, the fuel doesn't pour onto the engine.
Fuel tanks also have overflow, so when you overfill it, you don't have to suck the petrol out of the tank yourself.
The easiest thing for you would be to take the tank off, a look where the hoses go. OR, just read the manual.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful? |
