Honda cbr Indicator is not working
rockerpapaz
PostPosted: 10:42 - 24 Mar 2015    Post subject: Honda cbr Indicator is not working Reply with quote
Hii i have Honda Cbr 125 2013. Basically all of sudden my bikes front left indicator stopped working. I ve noticed is indicator light stays on it doesn't blink and rear indicator stays on it doesn't flashes... and today suddenly it started to work by itself and then stopped working again. Checked the indicator connectors seems fine( as they are wrapped in transparent rubber). What problem could it be..any help full advice is most welcome.
Taught2BCauti...
PostPosted: 10:58 - 24 Mar 2015    Post subject: Reply with quote
Try removing the bulbs and making sure the contacts are clean - both on the base of the bulb, and inside the bulb holder itself.
Check the wiring that connects to the switch to make sure nothing is loose or frayed.
Follow the wiring from the switch to where it joins the main wiring harness. Disconnect and clean the connector block contacts.
It could be a faulty or failing flasher relay, but that would normally affect both sides.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 11 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 31.7 Kb
