Recommend a discreet cheap fixed camera
koolio
PostPosted: 12:58 - 24 Mar 2015    Post subject: Recommend a discreet cheap fixed camera Reply with quote
Spent hours sifting through threads and still can't make heads or tails of it.
I'd like a cheap camera fixed discreetly onto my lower yoke or headlight (bike is a CB500T) that will begin recording from the moment I turn the bike on.
Something that will record let's say 12 hours of rolling footage (so it will be deleting footage older than 12 hours old).
Anyone have any good ideas of how I can go about this?
TheArchitect
PostPosted: 13:05 - 24 Mar 2015    Post subject: Reply with quote
This guy does reviews of action/dash cams for all budgets..
https://www.techmoan.com/
GSXR 600 K6 - Stolen
MT09 - Almost stolen
stonesie
PostPosted: 13:40 - 24 Mar 2015    Post subject: Reply with quote
The best stealth cameras will be wired bullet cameras, just the small lens unit visible and the main box with the memory card can be put under the seat for easy access and less chance of water getting at it.
Rigging up a power supply from the bike should be easy, there's no end of 5 volt converters on ebay.
Amber Phoenix
PostPosted: 13:45 - 24 Mar 2015    Post subject: Reply with quote
The RoadHawk Ride is supposed to fit this requirement. However I've had little success with it in such an installation, stuck to underside of my front fairing. It loops indefinitely, it starts/stop on receiving/losing power, has a datetime burnt into vid, and has reasonably 720p recording capability.
But... mine keeps cutting out. Rather than several hours of looped footage, I get several 5-30sec clips from random intervals of my journey. I don't know if it's the vibration causing this, which is certainly noticeable. Or maybe the an unclean power feed (tapped off sidelights), that is varying too much. In what video is does happen to grab, there is a lot of horizontal interference lines and the audio is terrible, horribly raspy.
Works grand on helmet though, albeit with just 30-80min of battery life (heavily dependant upon ambient temperature).
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
Ben90
PostPosted: 13:59 - 24 Mar 2015    Post subject: Reply with quote
Recently spotted the INNOVV C3.
https://www.innovv.com/#!the-c3/c18kr
Small remote waterproof lens and you can hardwire it into the bike with automatic loop record when the ignition is switched on.
Depends how you define cheap.
Yamaha FZ6 S2
stonesie
PostPosted: 14:10 - 24 Mar 2015    Post subject: Reply with quote
https://youtu.be/aObCaFWvDzs Thumbs Up
It's got me thinking, that lens would fit between the headlights of the STR... No vlogging though.
Gazza M
PostPosted: 15:15 - 24 Mar 2015    Post subject: Reply with quote
I've posted it before but I rigged up my own version of this. Used a mini DVR off ebay wired in under the seat and a cctv bullet cam, powered from a relay that switched off of the rear brake light (I think). This was fed through a rectifier board to keep everything at 12V, and the camera positioned under the headlight at the front.
Everything records 640x480 to a mini SD card when the ignition is on - 2gb card gives around 3 hrs footage but this can always be bumped up.
https://i1125.photobucket.com/albums/l598/gazzam1/DSC03755_zps41bd1af3.jpg
Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike
WimbleHJR
PostPosted: 16:21 - 24 Mar 2015    Post subject: Reply with quote
I have the Roadhawk ride. I had some initial problems with the first one, but sent it back under warranty and got a replacement quickly.
Since then I invested in a better quality SD card and it's been good since. Mine sits under the front fairing on my fazer, discreet but captures everything I need *well, to the extent that a front facing camera can.
They have a new version out now which might be worth looking at as well.
https://www.youtube.com/watch?v=KkXKHF5a2-I should work if you want to see the quality. Though the standard is better than youtube tends to show (could be my pants internet at work),.
YBR125, FZS600, FZ6 S2 F800ST
Amber Phoenix
PostPosted: 16:41 - 24 Mar 2015    Post subject: Reply with quote
WimbleHJR: Interesting, my RoadHawk is hooked up to Fazer as well. How do you feed it power and what from? Mine's using 12V leads to tap into sidelights.
Ever have issues with it randomly stop recording? Or does it always record all of your journey everytime?
FWIW, I've used my cam in car from fag lighter socket and it worked faultlessly for hours on end.
Yamaha FZ6 S2 2007
defblade
PostPosted: 20:40 - 24 Mar 2015    Post subject: Reply with quote
Posted the following on the Geek thread on a similar topic (my solution not geeky enough though Wink ):
Mobius camera, waterproof case , drill back of case and chemical metal/epoxy/whatever usb power lead in so when you push the camera in, it pushes onto the usb plug, connect to 5v usb adaptor in dry location of your choice.
Mobius not only works very well, it's one of the only (or possibly the only) cameras where the power-in location works with the w/p case design to let you mod it for a permanent (or, rather, ignition switched) power lead.
stevo as b4
PostPosted: 20:56 - 24 Mar 2015    Post subject: Reply with quote
Is this said cam for recording commuting trips and any incidents/providing evidence in the case of accidents etc?
I assume it's not a cam that's going to be used to record epic hooning around town/country, as surely a helmet cam, tank mounted, or rear facing cam would be better for making incriminating vids with?
Amber Phoenix
PostPosted: 10:55 - 25 Mar 2015    Post subject: Reply with quote
This is the use case I certainly had in mind. A bike mounted, fit and forget solution. Sits there recording whenever the ignition is on, always looping so always has last 4-5hrs of ride time on it with time stamp burnt into video. You'd only pull the SD card out of it when some twat has just done a SMIDSY on you and is now contesting to the insurance crew you were doing a zillion mph on one wheel squashing kittens left, right and centre, after you finally tracked them down using the reg plate this camera caught...
Yamaha FZ6 S2 2007
stirlinggaz
PostPosted: 18:31 - 26 Mar 2015    Post subject: Reply with quote
hi,
thats looks interesting, along the lines of what i THINK looking for.
fancy doing a wee idiots guide/how to?
would be most appreciated. it would probably take me ages to figure it out myself & end up still being in the boxes this time next year.
i really fancy a simple device that starts recording when i set off. & stop....well when the bike stops if i forget to manually switch it off.
those bullet cams, i suppose the size of thing doesnt really matter, but the lense is the important bit, right?
i'd like to be able to drill a hole, in between headlights for example, cut a hole, the size of a 10p max & shove a camera in there & seal it all up, with only the lense visible from the outside,
cheers,
GAZ
Gazza M
PostPosted: 21:53 - 26 Mar 2015    Post subject: Reply with quote
What you'll need:
Arrow mini-dvr
Arrow 12v cctv bullet cam
Arrow BNC male coupler
Arrow 12v regulator
Arrow 4 pin relay
Arrow in-line fuse holder
Arrow box to put everything in
Basic circuit diagram to work off:
https://i1125.photobucket.com/albums/l598/gazzam1/diag_zpsorlzw4md.png
First thing I did was make sure I had somewhere to mount the camera - ended up bending up a piece of acrylic that I cut out at work and bolts to the bottom of the headlight mount on the bike. To be fair this could be anything, I was just lucky! Camera slots through the hole at the front (facing left) and a bolt holds it in at the back side through the smaller hole. (It'll see if I can get a better pic of it on the bike later)
https://i1125.photobucket.com/albums/l598/gazzam1/Capture_zpslcmsxjkl.png
Once I had that sorted I made up some cables to run 12v to the dvr and camera. Conveniently they both used the same 2.1x5.5mm dc plug which made things easier - soldered those on to some wire I had making sure I got the polarity of the pins the right way round with the outside barrel of the plug being neg-, pin inside pos+. The video connection was done using the BNC cable provided with the dvr - there was just enough space to run the cables direct together with a BNC male coupler between them.
Next was to sort out the regulator - this means that a constant 12V is supplied to the camera/dvr rather than the 14-ish V you get when the bike is running which could fry the dvr. I wired it through a fuse and relay to the battery (check out Stinkwheel's relay thread). I got the bike running and measured the output across the 'out' side of the regulator. This can be adjusted by turning the little screw on top of the blue unit on the board. Once this was set to 12V I put it inside a small ABS box I had kicking about and bolted the DVR to the top of that. I then put the whole thing under the seat out of the way and voila! Video quality isn't fantastic but it does the job.
https://i1125.photobucket.com/albums/l598/gazzam1/DSC03758_zps56cd9f35.jpg
koolio
PostPosted: 22:04 - 02 Apr 2015    Post subject: Reply with quote
Everyone and Gazza especially. Thank you so much.
I'm going to follow your procedure and see how I get on. Thanks again.
Quick question is it rolling (so deletes the older data automatically)
anthony_r6
PostPosted: 11:25 - 03 Apr 2015    Post subject: Reply with quote
You can get a chain under your seat? I'd be lucky to get my wallet under mine Shocked
WimbleHJR
PostPosted: 11:43 - 03 Apr 2015    Post subject: Reply with quote
Arfa, sorry for the delay. I got mine fitted by a local mechanic while he did some other work as at the time I thought it would be difficult... I'm a bit less of a noob now!
He's wired it to the horn. Had problems similar to yours but changed SD card and it seems OK. It's worth contacting road hawk. They've been helpful a couple of times with my issues. They're pretty small so you can probably just speak to their engineer, think his name is Martin.
Gazza M
PostPosted: 14:40 - 03 Apr 2015    Post subject: Reply with quote
Yep Thumbs Up
The last post was made 11 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.92 - MySQL Queries: 14 - Page Size: 106.82 Kb
