Rear Shock mk1 Bandit 600
SQL
PostPosted: 00:39 - 24 Mar 2015    Post subject: Rear Shock mk1 Bandit 600 Reply with quote
Right, rear shock shat itself on the way home destroying the bottom bump stop.
What rear shock will fit in relatively easy and be decent for 2up work.
I have read GSXR 1000 K7/8, CBR600RR, R6 08 (with mod to fit bushes which I cant do at home)
Can't afford a new shock and MOT is due 11th of April
Doesn't seem to be much on eBay that I have seen
inb4repost
CR_CBR
PostPosted: 09:05 - 24 Mar 2015    Post subject: Reply with quote
I've fitted Gsxr1000 K7-K8 shocks to all my bandits so far. Can be had for around £60-£90 on ebay US. You just need to space the dog bones out by 2mm on each side, as the spring is wider. And cut away some of the plastic under the battery box.
The one I put on my 600 2 years ago was a vast improvement over standard and is still going strong now. As a side note the gsxr shock jacks the back end up by around 35mm so it's works best with standard dog bones.
SQL
PostPosted: 17:13 - 24 Mar 2015    Post subject: Reply with quote
Having difficulty finding one this side of the pond.. that is my prefered shock as it will jack it up slightly and make it handle my fatarse better
Nemo
PostPosted: 19:04 - 24 Mar 2015    Post subject: Reply with quote
https://www.ebay.co.uk/itm/SUZUKI-GSF-600-BANDIT-REAR-SHOCK-DAMPER-PLUS-LINKAGE-MK1-/111613599398?pt=UK_Motorcycle_Parts_13&hash=item19fcb05ea6
I know it's tatty, but cheap enough until you find something else and get you through MOT?
Edit:
https://www.ebay.co.uk/itm/Suzuki-gsf600-mk1-shock-suspension-/281634481201?pt=UK_Motorcycle_Parts_13&hash=item4192b92431
Another one, cheaps
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
SQL
PostPosted: 19:20 - 24 Mar 2015    Post subject: Reply with quote
Nemo wrote:
Cheers a K7/8 shock has just come up £75 with postage
Iain.
PostPosted: 19:25 - 24 Mar 2015    Post subject: Reply with quote
I have a shit mk1 bandit shock in my pile of parts. It's a bit spongey and scabby but it might get you by for a while and is yours for free if you want it.
R6 shock fits nicely, you just need to find a bit of pipe to make two spacers from. I paid £45 for one from someone on here & it was still on my Mk1 600 when sold.
The last post was made 10 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 49.33 Kb
