Install tomtom cable charger in Honda CBF600
dablak
PostPosted: 22:41 - 24 Mar 2015    Post subject: Install tomtom cable charger in Honda CBF600 Reply with quote
Hi,
I've got a tomtom rider and it comes with a cable battery charger. I want to connect it in my Honda CBF600.
I don't think that it's a good idea to connect it directly to the battery. I think that the best way is to connect it somewhere that will give electricity only once I turn on the key. What is the best way to connect the cable? Are there any spare connectors for accessories?
https://i459.photobucket.com/albums/qq319/macutan/TomTom-BatteryCable.jpg
Thanks
Nemo
PostPosted: 22:47 - 24 Mar 2015    Post subject: Reply with quote
If I were you, and if you're confident, I'd take the power from either the ignition or killswitch, and the earth to, well... an earth.
Since it's going to be at the front of the bike that makes sense to me, unless you want to feed it across the length of the bike.
Does the headlight of your model come on automatically with the key? If so you could plumb into the sidelight for power, then grab the earth off the headlight or sidelight.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
davebike
PostPosted: 07:41 - 25 Mar 2015    Post subject: Reply with quote
I often fit those pick op power from any black switched power inside the head light on a earth is a green wire
Or power feed to front brake light switch and a tag end to a frame bolt for the earth connexion
Dave
NC750Xdct + others at work !
davebike1@gmail.com
Robby
Dirty Old Man
PostPosted: 09:28 - 25 Mar 2015    Post subject: Reply with quote
Have a look on this forum for a guide on wiring up an auxiliary wiring circuit written by Stinkwheel. It tells you have to wiring in to a switched live properly.
Alternatively, wire it right to the battery. I assume you're only going to have the GPS plugged in while the bike is in use - you're not going to leave it parked up for days with the GPS attached - so it won't be draining the battery. The cable doesn't appear to have anything which will draw power itself, at most it might have an LED where the parasitic draw is negligible.
The advantage is wiring to the battery is that you don't have to know what you're doing, and removal is easy.
raesewell
PostPosted: 10:21 - 25 Mar 2015    Post subject: Reply with quote
Are you mounting the Tomtom unit on an Active Mount? If so you can wire it to a switched connection. I you are using a passive of any other mount you need to convert the bikes 12v to 5v.
Yamaha FJR 1300 Normanton West Yorkshire
davebike
PostPosted: 11:10 - 25 Mar 2015    Post subject: Reply with quote
The lead is for the active mount
Seen enough of them !
Dave
davebike1@gmail.com
raesewell
PostPosted: 18:28 - 25 Mar 2015    Post subject: Reply with quote
OK good to wire straight to the mount then.
raesewell
PostPosted: 18:30 - 25 Mar 2015    Post subject: Reply with quote
The last post was made 11 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 54.71 Kb
