stabilising 12v dc (fixed)
salty21
PostPosted: 00:10 - 26 Mar 2015    Post subject: stabilising 12v dc (fixed) Reply with quote
hi all.
This is a very long story but the short version is i have a gremlin in my bikes electrics that doesnt show up on any tests or diagnostics, but it is enough to kill quickshifter control units. I've spoken extensively to HM quickshifters and after weeks of headscratching and me trying different parts and tests we have hit a dead end. Ive had the bike down at a honda dealer today for full diagnostics test and it showed no faults. The bike runs absolutely fine on its own but there is something happening that kills quickshifters.
I was doing a bit of brainstorming with the honda mechanic whilst i was there and we figured it must be some kind of power spike that happens too quickly for the testers to pick up on but enough to damage the circuits in the quickshifter.
When i got home i decided to run the bike with the 3 yellow genertor wires unplugged so the bikes electrics were running purely off the battery. I plugged the quickshifter back in and went for a quick ride and the quickshifter worked perfectly.
Ive tested the resistance of the 3 yellow stator wires and they all read 0 ohms resistance which i thought was strange as there is normally a bit of resistance there but it generates good power so must be working?. I also tested the reg/rec which is all good.
So what i want to do as an easy fix is to try and eliminate this power spike if that is what is happening by further stabilising the current from the red wire on the reg/rec somehow but dont really know the best way to go about this?.
WD Forte
PostPosted: 00:52 - 26 Mar 2015    Post subject: Reply with quote
Has anyone inspected the failed quickshifter?
If I was HM, I'd want to know what killed it and how to make it more rugged.
( but then I wouldn't be flogging you so many Laughing )
You can add various types of filters, chokes, opto isolators, sheilding etc to the supply to the thing, but I'd start simply by checking and beefing up the grounding.
bikers smell of wee
Val
PostPosted: 01:29 - 26 Mar 2015    Post subject: Reply with quote
Honestly I find it hard to beleive this alien high voltage peaks that can't be detected by mere humans.
Looks to me your voltage regulator is faulty.
Have you measured the voltage at all there? My educated guess it is 16V Smile
salty21
PostPosted: 07:50 - 26 Mar 2015    Post subject: Reply with quote
The voltage never goes above 14.3v according to both my multimeter and hondas diagnostics machine. I honestly cant think of any other explanation.
the HM unit I had didnt actually break because it had a watchdog circuit to protect itself. I have since sold the unit to a friend and it works perfectly on his bike.
salem1987
PostPosted: 08:03 - 26 Mar 2015    Post subject: Reply with quote
Try checking if any AC voltage is leaking through to the battery with the multimeter, that i think would be undetectable at DC. And would definitely have a go at frying anything on the loom!
BillyJ
PostPosted: 09:16 - 26 Mar 2015    Post subject: Reply with quote
Get/buy/borrow a multimeter with a bargraph that can show changes quicker than the display updates.
To answer your questions, capacitors can remove high voltage spikes.
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
salty21
PostPosted: 09:17 - 26 Mar 2015    Post subject: Reply with quote
Would I just set the meter to ac and check across the battery for that?
PostPosted: 09:19 - 26 Mar 2015    Post subject: Reply with quote
Run the shifter off an auxiliary battery?
PostPosted: 09:29 - 26 Mar 2015    Post subject: Reply with quote
Or a capacitor to smooth the supply?
Islander
PostPosted: 09:46 - 26 Mar 2015    Post subject: Reply with quote
The low internal impedance of the battery does the same.
Taught2BCauti...
PostPosted: 10:47 - 26 Mar 2015    Post subject: Reply with quote
With the battery connected, it will act like a capacitor to suppress high-voltage spikes to some extent, and they probably won't show up on a digital voltmeter.
You would need to connect an oscilloscope across the battery to see what's really going on - but I suspect the reg/rec is at fault.
You could regulate the voltage going to the shifter by first taking the live feed through a blocking diode, and using a 7812 regulator to keep the supply at a steady 12v dc.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 11:45 - 26 Mar 2015    Post subject: Reply with quote
Does a 2005 CBR600RR have a mosfet voltage regulator?
Look at the serial number printed on it. It will start with either SH or FH. If it's SH, it's a zennor type, if it's FH, it's a mosfet.
If it's a zennor, replacing it with a mosfet ought to keep a tight lid on the voltage.
salty21
PostPosted: 12:41 - 26 Mar 2015    Post subject: Reply with quote
An auxiliary power supply isnt an option as the unit takes its 12v feed from the coils and cuts this feed when performing a shift if that makes sense?
The bike is a 2008 cbr600rr and has a mosfet reg rec as standard. The bike has only covered 8000 miles and never been used in any weather. All the electrical connections throughout the bike are in tip top condition.
The capacitor idea sounds like its worth a try. Do I just fit that to the 12v feed wire just before the quickshifter? What type of capacitor would I need?
Islander
PostPosted: 13:22 - 26 Mar 2015    Post subject: Reply with quote
One of these between +12v and gnd as close to the unit as you can manage.
https://www.maplin.co.uk/p/decoupling-ceramic-disc-01uf-capacitor-n43cj
Taught2BCauti...
PostPosted: 13:25 - 26 Mar 2015    Post subject: Reply with quote
I would use a 1uf electrolytic rated at 25v, as close to the shifter as possible.
A MosFET Reg/Rec doesn't guarantee there will be no spikes or transients - they are just impossible to detect without an oscilloscope.
salty21
PostPosted: 16:16 - 26 Mar 2015    Post subject: Reply with quote
Cheers guys.
so to be clear, I just solder one leg to the 12v feed right next to the unit and the second leg to the ground wire next to it?
Taught2BCauti...
PostPosted: 16:20 - 26 Mar 2015    Post subject: Reply with quote
salty21 wrote:
Cheers guys.
Yes - the capacitor is polarised, so + to + and - to -
salty21
PostPosted: 16:21 - 26 Mar 2015    Post subject: Reply with quote
Cheers guys.
salty21
PostPosted: 16:38 - 26 Mar 2015    Post subject: Reply with quote
Just been on maplins website trying to find a 1uf electrolytic capacitor and the only ones i can find seem to be rated at 100v?
I live down the road from maplins so can nip and get one straight away
PostPosted: 17:37 - 26 Mar 2015    Post subject: Reply with quote
Just a thought for the electrronics boffins. Would it be worth fitting a diode in paralell with the control unit?
Islander
PostPosted: 17:39 - 26 Mar 2015    Post subject: Reply with quote
Don't use an electrolytic. You're trying to decouple fast transient spikes and they are not suited for that - the battery itself will deal with anything that an electrolytic would. The ceramic disc capacitors are designed specifically for this purpose. Thumbs Up
Islander
PostPosted: 17:41 - 26 Mar 2015    Post subject: Reply with quote
That's only useful if there are induced back EMFs really. Dead right for relay coils and the like. Smile
salty21
PostPosted: 18:23 - 26 Mar 2015    Post subject: Reply with quote
Well I just fitted the electrolytic capacitor but the units gone pop again. Not sure if this happened last time I rode it or from todays tests but it has failed in the exact same way as last time so must have happened yesterday.
Not sure if they will send me another replacement but ive been at it so long now I dont think giving up is an option anymore. Confused £££
Taught2BCauti...
PostPosted: 18:26 - 26 Mar 2015    Post subject: Reply with quote
My thoughts were, that if the reg/rec is occasionally putting out a high enough spike to kill the shifter, it is probably a higher voltage than the battery will cope with (about 16v), and enough current to pop a ceramic disc capacitor.
If the OP lives close to Maplins, why not call in and explain the problem to one of the tech guys there, and see what they recommend. You usually find them lurking at the parts counter at the back of the store.
Islander
PostPosted: 18:35 - 26 Mar 2015    Post subject: Reply with quote
It won't cause the ceramic disc cap to fail - they're designed to deal with this. Decoupling has a lot to do with impedance and time constants and the faster the transient the lower the value needed which is why on some power supplies you'll see an electrolytic with a disc ceramic in parallel.
The last post was made 10 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 135.19 Kb
