butterfly disc vs. normal?
NeolWhyt
PostPosted: 13:58 - 27 Mar 2015    Post subject: butterfly disc vs. normal? Reply with quote
Hey guys, I wanted to know the difference between butterfly discs and a normal circular one. Can someone link me to an article or explain? I can't find anything about butterfly discs on google.
totalllama82
PostPosted: 14:15 - 27 Mar 2015    Post subject: Reply with quote
Try 'wavy discs' instead? I presume you mean them?
Believe they're meant to give better bite. Haven't looked into them a great deal but they do look cooler Cool
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
PostPosted: 14:23 - 27 Mar 2015    Post subject: Reply with quote
My understanding is that they are variously claimed to:
Arrow Clear crud off when used offroad.
Arrow Dissipate more heat from the extra edges.
Arrow De-glaze pads.
Arrow Shave a few grammes off of unsprung weight.
My opinion is that they are fitted because they look sick weapon, blud, and are good for at least an extra 10mph down the pub.
SQL
PostPosted: 14:29 - 27 Mar 2015    Post subject: Reply with quote
Cheaper than oem disc too
Matt B
PostPosted: 15:39 - 27 Mar 2015    Post subject: Reply with quote
Kawasaki like them and fit them as standard - ZZR1400 as an example.
Wouldn't choose a cheap but sick looking set of wavy discs over a quality set of normal ones though.
PostPosted: 15:40 - 27 Mar 2015    Post subject: Reply with quote
They provide more leading edge for the pads to bite, and they look cool. That's pretty much it.
Northern Monkey
PostPosted: 16:14 - 27 Mar 2015    Post subject: Reply with quote
Are they available in Royal Enfield fitments?
Musketeer
PostPosted: 16:25 - 27 Mar 2015    Post subject: Reply with quote
They look cool. That's about it.
Standard ones are better, because more pad surface touches the discs. That's why you don't see wavy discs in racing Wink
They are more for off-road.
PostPosted: 16:36 - 27 Mar 2015    Post subject: Reply with quote
My understanding, and again it's shallow, is that they use ceramic discs.
No, but Blakeys on your loafers will help you stop more effectively.
Albigularis
PostPosted: 16:41 - 27 Mar 2015    Post subject: Reply with quote
The reason you don't see wavy discs in racing is that proper race cars/bikes use ceramic discs, so that they can withstand the temperatures that they get placed on them. The reason you don't get ceramic wavy discs is they couldn't handle the stresses and would crack at the thin points.
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
Northern Monkey
PostPosted: 18:52 - 27 Mar 2015    Post subject: Reply with quote
Albigularis wrote:
The reason you don't see wavy discs in racing is that proper race cars/bikes use ceramic discs, so that they can withstand the temperatures that they get placed on them. The reason you don't get ceramic wavy discs is they are purely a fashion statement, and serve no functional purpose. This makes them of no use on a race bike.
FIFY
Nemo
PostPosted: 20:52 - 27 Mar 2015    Post subject: Reply with quote
Rogerborg wrote:
My understanding, and again it's shallow, is that they use carbon discs.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
PostPosted: 21:15 - 27 Mar 2015    Post subject: Reply with quote
Suspect the Kawasaki ones are pretty much purely cosmetic. Wavey bits are not wide enough to do much useful
K
PostPosted: 21:56 - 27 Mar 2015    Post subject: Reply with quote
Nemo wrote:
No, I'm pretty sure I wrote ceramic.
Nexus Icon
PostPosted: 22:12 - 27 Mar 2015    Post subject: Reply with quote
Actually, carbon-ceramic. Thumbs Up
Greetings from Shitsville!
weasley
PostPosted: 22:26 - 27 Mar 2015    Post subject: Reply with quote
This. But they use metal discs in the wet (since CC discs aren't great when cold). Still not wavy though.
NeolWhyt
PostPosted: 01:42 - 28 Mar 2015    Post subject: Reply with quote
Thanks guys Smile
talkToTheHat
PostPosted: 02:17 - 28 Mar 2015    Post subject: Reply with quote
Carbon disks are prone to crack/shatter/explode if there is a flaw in them that concentrates stress. They are very fragile. You will note that motogp carbon disks are not vented, slotted or drilled as carbon is a worse conductor off heat than steel, so unless the disk is thick enough to vent radially as per a formula 1 disk, drillings mostly create local hotspots that hinder rather than help performance. As the disks are comparatively large, the heat mostly on the surface and are in the airflow, such provisions are not required in motorcycle racing when using carbon/carbon brakes. Yet.
Racing in controlled conditions on a closed course on a closed course of clean tarmac and are inspecting after each run ensures that brake performance me managed. Friction surfaces can be machined to deglaze as required, and will be cleaned after each run if required.
Contrast this to road riding where winter roads are filthy with grit and salt, and brakes do many thousands of miles between planned maintenance. Or off road bikes ridden through all kinds of adhesive gritty muddy slime. Or sand. Here the relatively light duty means ultimate braking performance can be compromised for more reliable braking.
A wavy disk can help remove debris from pads, much in the same way as a slotted or drilled disk can, only more so. They can also apply a light cyclic radial load to the pads which may keep the pads from sticking, and clear debris between the pad and caliper. There is also a big advantage in unsprung weight which will improve handling.
However, less weight of disk means less thermal mass, so the brakes will come up to operating temperature faster, and potentially overheat faster, depending on how well the excess heat can be exchanged with the airflow. A wavy disk has a high surface area to volume ratio and better structural integrity than a drilled disk with the same surface area and volume, so if chosen well, a wavy disk can offer moree efficient braking by reaching operating temperature faster and dissipate heat to the air more efficiently, or offer better streenght than a drilled disk.
Bandit. does. everything.
PostPosted: 08:13 - 28 Mar 2015    Post subject: Reply with quote
You sureabout the 'leading edge' bit? The leading edge of a wavy disc gets razor-sharp as it wears. If the edge had any more 'bite' than the rest of the disc it would quickly shave the pads down.
davebike
PostPosted: 08:21 - 28 Mar 2015    Post subject: Reply with quote
I seen well made ones that are fine but beware the cheap poorly made ones Saw one bike that was eating pads in 2/3 k miles EBC hh at that had same rider same use same pads but knackered UEM disks been doing 10K+
Good one look great if that is you thing
Cheap ones can prove expensive
Dave
NC750Xdct + others at work !
davebike1@gmail.com
totalllama82
PostPosted: 11:37 - 28 Mar 2015    Post subject: Reply with quote
Absolutely. Good brand names that I know of include Galfer, Braking.it, EBC, Brembo and Armstrong. I've not heard terribly great things about the cheap Chinese ones you find on eBay.
lihp
PostPosted: 11:53 - 28 Mar 2015    Post subject: Reply with quote
Carbon Ceramic discs are banned in World Superbike, they still don't have wavy steel discs.
PostPosted: 12:20 - 28 Mar 2015    Post subject: Reply with quote
Some teams do run them in Supersport.
https://www.hondaproracing.com/images/image_gallery/lightbox/2787__ZAX8423.jpg
Ten Kate for one. If they were slower they probably wouldn't be using them. Not saying they're faster and they're probably using them #becausesponsor, but if they actually made the machine slower under braking, they wouldn't be using them.
Also, Haga's 2006 R1
https://www.fastdates.com/PaddockGarageImages/PG02.R1SuperHaga05.01.530.jpg
PostPosted: 12:29 - 28 Mar 2015    Post subject: Reply with quote
I think that's part of the idea. The true wavy disks where the wavy part goes through the pad area are supposed to keep the surface of the pad clean, and the action of shaving a fraction off of the pad material must provide good friction!!
I didn't say they were a good idea, I was just saying how they are supposed to work. Most Kawasaki discs don't even have the wavy part going through the pads anyway, so they are purely cosmetic. I know that crossers have wavy discs and that is mainly for keeping the pads free from mud.
talkToTheHat
PostPosted: 03:52 - 29 Mar 2015    Post subject: Reply with quote
I have not paid careful attention to the use of them in WSB and BSB. I need a bigger TV. Have been reading around but I am a cheapskate and being out of academia no longer have decent access to engineering journals.
3 factors appear prominent: preventing glazing; allowing binder gasses to escape; and cooling. Wet performance is mostly unaffected.
Ideally, there should be uniform drilling or slotting of the rotors across the working portion of the disk. Drilled disks are easiest to machine, and with a good drilling pattern, an almost uniform pattern can be achieved across all but the edges of the disk. Slotted disks are an advance on this, with less thermal hotspotting and better stress distribution as curvature radii are grater. They sill do not sweep the entirety of the disk. A wavy pattern is perhaps best thought of as a slotted disk with slots at the inner and outer edges of the disk and can thus sweep the pad uniformly.
However slot size is limited by the size and compressibility of the pad. Some high performance brakes use one pad per piston as opposed to having several pistons acting on a single pad, which reduces the size of the hole that can be cut into a disk without the pad moving and wearing unevenly.
As the size of each slot in a wavy disk is large compared to the holes in a drilled disk, the amount of pad that domes slightly when passing over a slot is greater (try this with a clean sponge to visualise) the wear is accelerated.
Thus wavy disks perform favourably compared to slotted or drilled disks of the same ferrous metal. However proving they work in high stress environments is a complex FEA task, and in motorcycle sprint racing, uneven pad and disk wear is not a huge issue. Furthermore, development costs and higher pad wear rates are likely to offset any financial advantage in reduced glazing unless a specific glazing problem exists.
It may be the case that wavy disks favour a less compressible pad material than drilled disks, so may work better for riders preferring pads that give a harder lever feel.
I suspect the lack of slots or cross drilling in carbon disks is because they would de-laminate and flake around the slots. The radially drilled vents in carbon disks in formula 1 are a most impressive feat of manufacturing.
I suspect the right formulation of steel is more important than slotting design, which is where cheap disks may lose out over those from established brands.
The last post was made 11 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 139.92 Kb
