Derbi Terra 125
sutty86
PostPosted: 09:33 - 27 Mar 2015    Post subject: Derbi Terra 125 Reply with quote
Trying to get a manual for one of these bikes
Looking at buying one Saturday as a deal fell though on the NSR.
Anyone got any advice to check.
Not much on Google
SQL
PostPosted: 12:05 - 27 Mar 2015    Post subject: Re: Derbi Terra 125 Reply with quote
Not much on Google
Here you go the engine manual is the important one.
https://www.scribd.com/doc/129446337/Derbi-Technical-Training-2010-125-4T-4V#scribd
have these in PDF form too, engine manual, workshop manual for the 4T 4V engine
Nexus Icon
PostPosted: 14:21 - 27 Mar 2015    Post subject: Reply with quote
Check the HT cap for cracks. It was the only failure I had during my ownership of one. Great bike.
Greetings from Shitsville!
SQL
PostPosted: 14:31 - 27 Mar 2015    Post subject: Reply with quote
My mulhacen also did this, don't cheap out and buy a ngk replacement cap either, doesn't work.
sutty86
PostPosted: 15:55 - 27 Mar 2015    Post subject: Reply with quote
Will do cheers
Presume parts are hard to find then for this bike
SQL
PostPosted: 15:59 - 27 Mar 2015    Post subject: Reply with quote
sutty86 wrote:
Will do cheers
AJSutton, or _Iain_ has always helped me find Derbi bits.
Iain.
PostPosted: 17:43 - 27 Mar 2015    Post subject: Reply with quote
_Iain_ is dead, long live Iain. - Although I suspect I'll get this account banned too at some point in the future Laughing
sutty86
PostPosted: 19:14 - 27 Mar 2015    Post subject: Reply with quote
do you guys know of any faults with the electric system this one has all the lights on the dash are illuminated and dont come off, everything works fine ,
like lights and indicators but are permanently illuminating,
can see this getting quite annoying, or maybe be quite dangerous with not knowing ive left the indicators on,
a habit im trying to get out of , atm...
suppose it would be a earth issue?( not been playing with bikes long)
SQL
PostPosted: 20:21 - 27 Mar 2015    Post subject: Reply with quote
Mine was fine with electrics, check earth points, also check around the headstock for frayed wires
Nexus Icon
PostPosted: 21:32 - 27 Mar 2015    Post subject: Reply with quote
Yeah, no electrical problems here either. Do as SQL says really.
SQL
PostPosted: 17:03 - 28 Mar 2015    Post subject: Reply with quote
as for the indicators, when ever you change gear press the indicator button works for me.
sutty86
PostPosted: 17:52 - 28 Mar 2015    Post subject: Reply with quote
https://i.imgur.com/DAz9UOZ.jpg
New bike
900 pounds , bike rides beautifully compared to YBR.
Brakes are spot on
Only problem is lights on dash ,and line crack in fairing.
Odometers reset itself also when previous owner changed battery ,dash lights came on at same time.
No fuel gauge though, all digital thought it may have showed one..
SQL
PostPosted: 18:05 - 28 Mar 2015    Post subject: Reply with quote
looks great if one came up cheap i'd have one
Nemo
PostPosted: 10:21 - 29 Mar 2015    Post subject: Reply with quote
Check the dash connector for corrosion.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
sutty86
PostPosted: 17:40 - 29 Mar 2015    Post subject: Reply with quote
https://i.imgur.com/nImiKHg.jpg
Tidied up today, tryed changing spark plug for iridium one ,to see if it started better,
Realised don't habe 1/4 inch sockets
So will be later on in week
Reference the yellow earth wire, lights dimmer when not earth and most of the dash lights don't come on...
Engine cut out today whilst attempting to start and made a right metal racket....
Oil is fine..
Not sure what it was didn't sound healthy
sutty86
PostPosted: 18:04 - 29 Mar 2015    Post subject: Reply with quote
https://youtu.be/ZAgNYog1dE4
Video of fault...
Neutral seems to work goes on and off like it should....
Oil warning light flickers whilst revving..
Reference metal banging noise,checked oil again looks clean and good,was going to refil with new oil but no filter...
Going to buy oil filter ,funnel because it's tiny the hole and 1/4 drive for spark plug...
Is it normal for carb engines to take a few seconds to start.revs over 2000 for a few seconds then settles at around 1800 ...
Snod Blatter
PostPosted: 18:34 - 29 Mar 2015    Post subject: Reply with quote
Video is set to private..
A bloke at work has one of these, looks like a smart bit of kit. It has aged quite badly over the winter though, the exhaust looks like it'll crack around the weld at the end can quite soon. Seems reliable enough though Thumbs Up
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
SQL
PostPosted: 18:40 - 29 Mar 2015    Post subject: Reply with quote
Starting mine was a bitch, throw away the electric choke stick a polini manual one.
Or start with little throttle and nurse it like a 2 stroke until it will idle.
sutty86
PostPosted: 19:29 - 29 Mar 2015    Post subject: Reply with quote
SQL is that an hard job or expensive???
Video now public sorry
PatheGod
PostPosted: 14:27 - 26 Jun 2015    Post subject: Reply with quote
Hi just bought my terra and got the same problem .Does anybody know how to fix it yet ?
The last post was made 11 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 100.24 Kb
