| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 09:52 - 27 Mar 2015 Post subject: Measuring SPRINGS |
hi,
i need 2 exhaust springs. its for a 30yr old 2t micron system, original new springs are n/a. (the flange is hand made anyway)
it fits like this : the flange slips onto engine,exhaust slips into flange,
the 2 springs connect the 2 lugs on the exhaust to the flange.
the distance from lug to manifold is 100mm.
according to some sort of caclulator i found on-line, this is what i need
type : extension spring (with open hook at either end)
wire guage : 2.5mm
outer diameter 13.5mm (compared an old, smaller exhaust spring)
number of active coils? f*ck knows, but looking at another exhaust spring, which has a free length of 36mm,
the distance needed is 100 divided by 36 is 2.7.
wee spring has 12 "active coils" so for a bigger spring i need to calculate
2.7 x 12 = 33.
so i need a spring that can cover 100mm, with outer diameter of 13.55mm with approx 33 coils.
problem is the hooks at either end. they seem to vary a bit in length. looking at 2 odd springs i have here, one has a hook of 10mm other is 15mm.
how to know what size of spring to order?
do i just take a gamble & order 100mm minus, say 20mm for the springs?
so order 80mm springs?
is there any easier way to work out what size springs i need?
this could turn into a game of chance. the springs needs to be tight enough to hold it onto the flange, too loose & it wouldnt be air tight.
anyone any ideas?
cheers,
GAZ |
| Minty |
 Minty World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:54 - 27 Mar 2015 Post subject: |
I'd err on the short side, on the basis that it can effectively be extended by looping <insert ghetto bodge solution> through the lugs. ____________________ Biking is 1/20th as dangerous as horse riding.
| Old Git Racing |
 Old Git Racing World Chat Champion
| stirlinggaz |
| temeluchus |
| Pete. |
 Pete. Super Spammer
 Posted: 07:09 - 28 Mar 2015 Post subject: Re: Measuring SPRINGS |
| stirlinggaz wrote: | hi,
wire guage : 2.5mm
2.7 x 12 = 33.
anyone any ideas?
cheers,
GAZ |
You're massively over-thinking it. Forget about coil count and wire thickness, just put your exhaust together and measure the lug to lug distance. Let's say that is 100mm for argument's sake. Find a spring that has an effective length of less than 100mm. No need to go too much shorter, say 10%, because the spring has to extend for the connection to come apart. ____________________ a.k.a 'Geri'
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
The last post was made 10 years, 329 days ago. Instead of replying here, would creating a new thread be more useful? |
