CBR 125-RW6 Won't idle or run for long before stalling
CBromyard
PostPosted: 10:41 - 28 Mar 2015    Post subject: CBR 125-RW6 Won't idle or run for long before stalling Reply with quote
Hi all,
Wanted to pick your brains if I could on an issue I'm having with a newly bought 06 CBR 125.The bike starts usually with a bit of choke or throttle, but will eventually stall at steady revs or when at idle. The bike has a big bore dyno jetted carb and a custom exhaust.
Things I've tried:
Checking fuel pump/hose
Cleaned pilot jet and float bowl
Replaced ignition coil
Replaced choke cable
Cleaned air box
Changed engine oil
Changed spark plug
Checked for blockages/uncleanliness in tubing
Checked for any kinked hoses.
Tried different idle screw adjustments
First bike, just want to get it up and running, any advice most welcome!
Fisty
PostPosted: 11:02 - 28 Mar 2015    Post subject: Reply with quote
Return it to standard.
Fatter and faster than Fret
bikenut
PostPosted: 11:19 - 28 Mar 2015    Post subject: idle Reply with quote
sounds like a fuel problem.....good sustained fuel flow from tank to an outside reservoir like a 2 litre pop bottle.......should fill the 2 litre bottle in about 2 minutes??
try that but be carefull of fire risk.......does the fuel "hang" or flow slow down and stop after 2 mins ish? I presume there is plently of fuel in the tank ( 3/4 full ) ??
did yopu buy this bike from a dealer and its under guarantee??
nuts about bikes
CBromyard
PostPosted: 16:43 - 28 Mar 2015    Post subject: Reply with quote
Fuel slow seems ok. Vacuum hose definitely works as with suction it pulls it through.
Took the carb off and gave everything a good clean. Removed main and pilot jets, no blockages. Now it won't start at all...
Sadly bought it privately. Booked in to see a mechanic but rather cut the two week wait and cost if I can get it running myself
Fisty
PostPosted: 16:56 - 28 Mar 2015    Post subject: Reply with quote
Stick a standard carb on it.
cb1rocket
PostPosted: 17:57 - 28 Mar 2015    Post subject: Reply with quote
2nd that, fit standard carb
temeluchus
PostPosted: 19:34 - 28 Mar 2015    Post subject: Reply with quote
returning it to standard is your best option.
Too large a carb will be far more trouble than its worth, it will never likely give you much more power and will not run as well most of the time even if you spent the time getting it running.
Northern Monkey
PostPosted: 19:39 - 28 Mar 2015    Post subject: Reply with quote
Have you tried returning it to standard?
mentalboy
PostPosted: 20:07 - 28 Mar 2015    Post subject: Reply with quote
Is the bike running an oversized piston and pot? It seems an odd thing to fit a large bore carb without running on a larger piston.
Whilst I agree with the 'return to standard' posts I'd hesitate to spend any more money throwing parts at it without making sure you've found the source of the problem - you are probably well on your way to spending more on the bike than it will ever be worth.
Make mine a Corona.
Nemo
PostPosted: 23:35 - 28 Mar 2015    Post subject: Reply with quote
Im in the standardize it column.
Could be float height, jetting, mixture, float valve.....
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
reckless_b
PostPosted: 13:50 - 29 Mar 2015    Post subject: Reply with quote
could be silly question, have you got a spark now?
did it start back up when it used to run, straight away or after some time?
40 years on the road on and sometimes off bikes with a very recent OFF
salem1987
PostPosted: 18:13 - 29 Mar 2015    Post subject: Reply with quote
Try having the fuel off and carb empty and fire the bike up with a small bit of fuel poured down the spark plug hole. If it fires then you know its probably a fueling issue.
Also with it all back on, try running with airbox off completly. Then vary the choke till it hopefully runs. Should give you an idea on jetting. If it fires itself up nice without the box and no choke its probably too rich.
These are just things ive had to do on my cb250rs i got that wouldnt fire up and had a very black spark plug. Turns out if i run it without the cheap cone airfilter its spot on, lowered the needle and jetting and its fine.
(someone had done some "tuning")
Intake manifold ok? no splits in it?
moonzoomer
PostPosted: 18:57 - 29 Mar 2015    Post subject: Reply with quote
Check that valve clearances are not too tight, i.e valves not sealing when bike has warmed up.
Stalk
PostPosted: 19:41 - 29 Mar 2015    Post subject: Reply with quote
Does it have a fuel filter fitted? If so it may be overly restricting the fuel flow as it is a gravity feed. Had the same problem with aanother bike and it would effectively run out of fuel. If so, try removing it. I know its a bit of a long shot but you never know
CBromyard
PostPosted: 09:30 - 02 Apr 2015    Post subject: Reply with quote
So I've replaced the custom carb back to a working stock carb, but it still won't start.
Fuel seems to be going through to the carb ok. Air filter is clean. No fuel filter. Good 1/4 + reserve in fuel. Spark plug has been changed, though with it not starting the plug is coming with a very small amount of wet oil on the end. Could this be a sign of flooding?
I've charged the battery and tried starting it with and without choke and throttle, no luck. Pulled out the plug and turned it over to see if that released anything in the engine, still no luck.
mentalboy
PostPosted: 09:50 - 02 Apr 2015    Post subject: Reply with quote
Oil or petrol on the end of the spark plug?
Petrol is a good sign, oil is not
Make mine a Corona.
CBromyard
PostPosted: 10:01 - 02 Apr 2015    Post subject: Reply with quote
I'd have to say it's very small amount of oil
mentalboy
PostPosted: 10:13 - 02 Apr 2015    Post subject: Reply with quote
Hmmm. I'd try to find for certain... If you wave a hairdryer over it (doesn't need to be for too long), will it dry up?
Make mine a Corona.
CBromyard
PostPosted: 20:42 - 02 Apr 2015    Post subject: Reply with quote
Ok, so hands up, I made a stupid mistake. When I changed out the carb I connected the float bowl overflow tube to the tank. Nothing drained out of the overflow once this has been properly reset.
I'm pretty sure I'm dealing with a flooded engine. I've tried taking out the plugs and starting it to evaporate the gases, but no success yet. Plugs are coming out wet with oil after a few cranks.
Leaving spark plug out overnight and charging battery, see what j get. Engine doesn't sound close to starting, though fuel is being delivered to the carb, battery and ignition all sound good.
mentalboy
PostPosted: 21:08 - 02 Apr 2015    Post subject: Reply with quote
If you think you've flooded the engine then find a nice clean tray (probably best if not one from the kitchen unless you fancy mother/wife's wrath) and drain off engine oil. Does it seem a little more fluid than it should be?
Best to put new clean engine oil in it as only a proper cheapskate would try to evaporate the petrol from the engine oil before putting it back (that and it probably doesn't do the lubrication properties of the oil much good having petrol dumped in with it!!)....
If you think that the plug is oiling up then you have a problem that will require a strip down as oil is passing piston rings - which it shouldn't!!
Make mine a Corona.
CBromyard
PostPosted: 09:41 - 03 Apr 2015    Post subject: Reply with quote
If excess fuel is in the engine, would this mix with the oil? I don't see how running through new engine oil would get rid of flooding?
Copycat73
PostPosted: 09:50 - 03 Apr 2015    Post subject: Reply with quote
yes.
won`t stop the floodin but
would stop the contaminated oil damaging your engine..
caveat emptor
mentalboy
PostPosted: 10:03 - 03 Apr 2015    Post subject: Reply with quote
It doesn't get rid of flooding, you have to attend to that first. I assumed that your earlier post suggested that excess fuel was entering the carb and bypassing the float via an overflow?
Considering that you now have a correctly hooked up carb, have you not stopped the flooding issue?
Or were you talking about flooding issues caused by winding the engine over with no firing?
Either way you are likely to have petrol in your oil (as it has gravity and lower viscosity on it's side) which will do several things...
Most likely is it will reduce viscosity of your oil which will then pass the rings and give you an oily plug - which doesn't help starting issues, that's not to say that an oily plug is the reason it won't start.
Secondly it will reduce the lubricating efficiency of the oil.
And thirdly, if there's enough petrol in your oil you could end up locking your piston hydraulically.
None of which is particularly desirable and could be catastrophic for your engine.
Make mine a Corona.
The last post was made 11 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 117.9 Kb
