| Fowlersrs |
 Fowlersrs World Chat Champion
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Fowlersrs |
| b422063 |
 b422063 Crazy Courier
| esullivan |
 esullivan Could Be A Chat Bot
 Posted: 16:11 - 28 Mar 2015 Post subject: |
I believe the patent that Gore-Tex had on the material has long expired, so other manufacturers make very similar material. Breathable, waterproof layers come from several manufacturers now, under brands like SympaTex and Hipora.
That said, what you get with the Gore-Tex brand is strict manufacturing requirements and the (lifetime?) guarantee. That's how the company sets itself apart from competitors -- by ensuring that the brand name only appears on garments that are very sturdy and well-made. That's what you are paying for.
My Rukka gear is the very low-end of the range and uses the Performance Shell instead of the Pro Shell of the high-end. (IIRC, the difference is that the waterproof layer is on the inside of my jacket and trousers, while the Pro Shell repels water at the surface.) In the hardest rain, riding all day (like a 12-hour day through Glenco we did last year), the jacket never lets in a drop.
They're not perfect, though. The trousers start letting in a tiny bit at the knees where the zipper creases. I can live with a bit of wet behind the knees during the worst of the weather. It's better than my last set (something from JTS, I think) that stopped being even remotely waterproof after a couple of months. ____________________ Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125. |
| Beehive Bedlam |
| Fowlersrs |
 Posted: 16:20 - 28 Mar 2015 Post subject: |
| esullivan wrote: | I believe the patent that Gore-Tex had on the material has long expired, so other manufacturers make very similar material. Breathable, waterproof layers come from several manufacturers now, under brands like SympaTex and Hipora.
They're not perfect, though. The trousers start letting in a tiny bit at the knees where the zipper creases. I can live with a bit of wet behind the knees during the worst of the weather. It's better than my last set (something from JTS, I think) that stopped being even remotely waterproof after a couple of months. |
Thanks, the rukka gear is something I've been looking at. I'm thinking of investing in a decent set as then it saves having the hassle of stopping when the heavens open |
| mentalboy |
 mentalboy World Chat Champion
| esullivan |
 Posted: 16:50 - 28 Mar 2015 Post subject: |
| mentalboy wrote: | | esullivan wrote: |
What you get with the Gore-Tex brand is strict manufacturing requirements and the (lifetime?) guarantee.
Don't be fooled by quotes of a 'lifetime guarantee' there is no such thing offered by Goretex.
Goretex guarantee to 'keep you dry', what they are less keen to shout about is the fact that this applies only to garments that are not 'worn out' or 'past their useful life' nor will they be drawn on the definition of either. Accept it for what it is - I find that their stuff generally lasts about 5 years before letting water in, except gloves which never seem to stay waterproof for more than a year. |
Yes, I wasn't sure what "lifetime" meant, which is why I put the question mark. The Rukka outfits come with a five-year guarantee and I've had to use it twice because of the zippers that runs down the length of the leg, the same ones that sometimes leak a little at the knees. (I wouldn't bother with that feature next time -- I very rarely need to put on or take off the trousers over boots.)
First, the right side started to go and they replaced it with a sturdier zipper, but I wish they did both sides, because a year later the left started to go too and I had to return them again. But each time, I got a loaner pair and they took it back and repaired them without question. ____________________ Current: '14 VFR800X Test passed 31/10/12.
| mentalboy |
| b422063 |
| Moo. |
 Moo. World Chat Champion
 Posted: 17:26 - 28 Mar 2015 Post subject: |
Nothing is ever completely waterproof. But goretex is nearly there
I have a Klim badlands jacket picked up cheap on ebay. Has the goretex laminate..
I am well impressed! Nothing for water to soak into, just flys off. After a heavy downpour, cuppa tea in a cafe and its drip dried!
I also have a hein gericke goretex cruise jacket, was their flagship model years ago, bought at BMF for £20
The goretex is still waterproof, only problem is, when it gets wet, the fabric outside soaks it all up, and it gets heavy and takes ages to dry! Eventually, this soak outer channels the cold and although still dry, i get cold. Doesnt happen with the goretex laminate stuff! So would recommend.
If you're looking for a cheap option, i use army goretex overs when i'm in my cheap gear, works perfectly. I have a british army light jacket that has zippers on the arm pits, so even when its hot and raining, i can get airflow through, never get much water coming in from the pits  ____________________ A2 Passed 18/6/10 |
| darkhorizon |
 darkhorizon Scooby Slapper
 Posted: 17:38 - 28 Mar 2015 Post subject: |
damp  ____________________ 2009 CBF600 - London hack - stolen then recovered - still going!
2006 CG125 - Was SORN'd, now back on road - sold Nov '16 |
| Joncrete Cungle |
 Joncrete Cungle World Chat Champion
| gorillaonabik... |
 gorillaonabik... Nearly there...
 Posted: 19:40 - 28 Mar 2015 Post subject: |
Had real problems with cold while wearing Goretex. It's good but if it's properly freezing then no, it'll hurt.
Have a Hein Gericke Goretex underjacket thingy and it's lasted more than 10 years so can be pretty good. ____________________ FZR400 (blown engine), ZXR750 (blown engine), ZX6R (accident), CBR600 which had engine issues after which I learned to change gear..., CBR900, CBR924 (stolen), CB600, CB1300 (everything blew up), BMW K1300GT (written off, hit from rear while stationary), Bandit 1250 for a couple of months, Triumph Sprint ST 1050 (nicked) and somewhere in there, I wrote off a Ducati 748 at Cadwell. |
| ScaredyCat |
 ScaredyCat World Chat Champion
| drbaig |
 drbaig Crazy Courier
 Posted: 22:22 - 28 Mar 2015 Post subject: |
Depends how long you want to stay waterproof. If you are riding all day in torrential rain then I think only the most expensive rukka gore-tex laminate stuff would keep you dry. But that is ludicrous price though 5 year warranty.
If it is up to an hour then the performance shell works very well IMO.
The way to keep the membrane working and keeping you waterproof is to wash it with nikwax or graingers or a similar product and reproof it to keep the DWR layer effective as that is the first layer of protection. When I see my gear starting to get wet on the outer layer I'll give it a wash and proof it.
I have noticed that as long as I maintain the DWR I don't get clammy and water just beads off. I even use nikwax to wash and proof hein gericke proprietary sheltex trousers that keep me dry as well. ____________________ yzf 600r  |
| haroman666 |
 haroman666 World Chat Champion
 Posted: 22:39 - 28 Mar 2015 Post subject: |
I wear a Lewis leather jacket and then I put an XL one of these over the top:
https://www.mountainwarehouse.com/mens/jackets/mens-waterproof-jackets/pakka-jacket-p8679.aspx?cl=BLACK
It's the dryest, warmest piece of clothing i've EVER worn. It's 2 years old and it doesn't leak in the slightest.
It's also an optional garment. Leave for work in the early hours when it's fucking freezing... Wear this jacket. Leave for home mid-afternoon when it's comfortable temperature... Pack this jacket into a tiny space and enjoy the breeze.
At £16, you may as well give it a go. It's fucking awesome.
(I don't work for mountain warehouse btw, so don't give me a spam rating!! I'm just really impressed by the jacket!) ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
| talkToTheHat |
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 11:19 - 29 Mar 2015 Post subject: |
I get the feeling that Gore-Tex is pretty close to the "holy grail" for waterproof-ness, and it seems they insist on certain standards of construction from the manufacturers who use their product. I'm slowly changing to it as funds permit.
I think if I were riding every day in all weather, I'd also invest in Rukka gear. From all I've heard, it's one of the most effective brands out there, and you get very good back-up when things do fail. But that's an expense I don't really feel the need to stretch to, as my riding is mostly fair-weather these days, so couldn't really justify spending that much.
Some breathable materials do leave you feeling the cold (eVent is a bugger for that) but it's about suitable layering for the conditions if you are feeling that. I tend to use a light weight wind-proof top under the textiles, plus an insulating layer or two, as required. All thin layers so they don't leave me feeling like the Michelin man. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| c-m |
 c-m World Chat Champion
| chickenstrip |
 Posted: 11:40 - 29 Mar 2015 Post subject: |
| c-m wrote: |
All depends on what you want from your gear. |
To be waterproof and comfortable. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| barrkel |
 barrkel World Chat Champion
 Posted: 16:49 - 29 Mar 2015 Post subject: |
| c-m wrote: | Like similar membrane fabrics it relies on the actual vapour pressure on the inside of the garment to be higher than that on the outside. |
As I understand it, temperature gradient is the deciding factor, and from my own empirical observation, this is the case. Warm wet weather: maybe, but it needs to be quite warm, warmer than any rain I've ridden through in Europe. I've never ridden in a tropical downpour. Wet windy weather: no, it's never been a problem. I've done extended trips at 80 mph on motorway sitting bolt upright on a scooter with no screen, and stayed completely dry.
Goretex membranes in leather gloves are not particularly effective, especially when used with heated grips. A bit of dampness can get in through the seat of my pants, on a long ride through prolonged downpour. Both involve close proximity between warmed water and the waterproof layer. But everywhere else, goretex has been fantastic, beating out every other solution.
I've done close to 100k touring miles at this point, a significant fraction of which through thunderstorms and the like, sometimes effectively chasing the thunderstorm so I get hit multiple times, and I've tried a lot of different techniques to stay dry. Any single non-goretex waterproof layer has failed within double-digit hours of use. Doubled-up waterproof layers are much more reliable, but they can get quite sweaty, they're awkward to get on, they tend to bunch up more, if they're not biker-specific then you tend to slide around on the seat, and they're very awkward to seal properly with gloves around the cuff area - the outermost layer often doesn't open wide enough to accommodate the layering of cuffs from everything underneath.
The weak point of almost all budget waterproof clothing is seams. Seams are also where goretex knock-offs seem to economize. Seams tend to be where joint movement applies stretching pressure to the garment. If the seam tape doesn't adhere effectively or doesn't stretch at a very similar rate to the fabric it's bonded to, it starts to get unstuck. You can see this as little bubbles in the tape over the thread of the seam on the interior of the garment. If one of these bubbles gets large enough to reach the edge of the tape, you've got a leak. Outside of higher-end outdoor wear manufacturers, I've not seen really good seam taping other than on goretex clothing. Leaks from seams typically hit you in the crotch on trousers and somewhere near your shoulders on jackets.
A second weak point of pretty much all waterproof motorcycle clothing is zips. If you have any folds on your front that collect water when riding, that water is going to go through zips, no matter what kind of storm flaps you've got, leaving you with a big damp patch on your belly. I've found it's well worth while to roll up the front of my jacket inwards at the bottom to make sure there's no folds to collect water. High end goretex jackets use gore lockout rubber zips to reduce this, but it's not enough if you're riding for several hours through rain. Some people don't like the rubber zips for reliability reasons too: if you're not careful with them or don't lubricate them often enough, you can damage them. My jacket came with a silicone applicator pen, but it's way too fiddly to use. I have a tub of silicone grease; a few fingerfuls of that pushed into the grooves is far more effective.
tl;dr: if I want to take an extended ride through mixed weather, I go with goretex bonded to the outer layer (not floating liner), and I think it's the best product available.
If I wanted to be cheap, I'd layer cheap (think: motorway) waterproofs, or medium/high-end outdoor clothing, if it fits on top. The middle ground is for mugs, IMO.
PS: watch out for wicking down the front of your jacket too, if you're wearing something like a balaclava or neck tube. I wear a waterproof neck tube sold as a sailing accessory if it's cold; if it's not cold, I prefer a bare neck, it transports less moisture than any fabric. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| c-m |
| SteveSmith |
 SteveSmith Nitrous Nuisance
The last post was made 11 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
