FZS 600 01 flat spot/sluttering in heavy rain - Fixed.
andys675
PostPosted: 12:38 - 29 Mar 2015    Post subject: Reply with quote
I think you've found your problem, not common on fazer 600's
replace the cap, scrub the plug with a wire brush
weasley
PostPosted: 16:50 - 29 Mar 2015    Post subject: Reply with quote
No, it is part of the spark plug cap; they unscrew from the HT lead, with the replacement screwing back on. I replaced one on my Thundercat a while back. Check what resistance it is though... I recall mine was a 10k ohm cap, which is less common than 5k ohm ones. And mine was a very specific design that was only available either OEM or, as I found, second-hand from a breaker.
Keir
PostPosted: 16:01 - 31 Mar 2015    Post subject: Reply with quote
you need ones of these CLICK HERE
At £2.50 each you might as well swap all 4.
They are straight instead of angled like the OE ones but fit and work just fine. You simply unscrew the old from the HT lead and screw on the new one.
Current : '08 Yamaha FZ1s
The last post was made 11 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 49.52 Kb
