NC750X chain & sprocket
cyclistbruce
PostPosted: 21:16 - 29 Mar 2015    Post subject: NC750X chain & sprocket Reply with quote
I'm in desperate need of a new chain and sprocket for my NC750X, the dealer says there is a manufacturing delay and there won't be any available until October. I've looked at all the online retailers but can't fibd anything. Any ideas?!
PostPosted: 21:55 - 29 Mar 2015    Post subject: Reply with quote
October? What on earth do they expect you to do until then? Eh?
Sorry, I can't find any. JT Sprockets don't even list the 750, just the 700. Sad
What I'd suggest is getting on to MCN and VisorDown and kicking up a stink - see if they can shame Honda UK into hurrying it up. This is amateur hour stuff.
Oh, and bookmarked for the next time someone trots out "You can't get parts for Chinky bikes".
Scroll down, Rog, you muppet. Doh!
temeluchus
PostPosted: 22:06 - 29 Mar 2015    Post subject: Reply with quote
https://www.bike-parts-honda.com/microfiches-recherche_piece-06406-MJL-D70.html
looks like the 750 and 700 use the same chain and sprocket kit.
PostPosted: 22:12 - 29 Mar 2015    Post subject: Reply with quote
I'd have assumed so. Dealer just being spackers? I wonder why JT don't...
Oh, wait, they do.
https://www.jtsprockets.com/catalogue/model/518
Same bloody parts as the NC700X, just one more tooth on the front sprocket on the 750.
https://www.jtsprockets.com/catalogue/model/5000
LOL @ Honda. Victor Devine, flux, etc.
temeluchus
PostPosted: 22:14 - 29 Mar 2015    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Honda-NC700-S-X-Cabs-Dct-Upgrade-Did-Chain-Sprocket-Kit-/131151786742?pt=LH_DefaultDomain_3&hash=item1e894172f6
BooM
PostPosted: 22:23 - 29 Mar 2015    Post subject: Reply with quote
Should work. I can't find a 17 tooth JTF1373 front sprocket for the NC750 though - I expect that's what the dealer is on about.
A 16 front might not be ideal on the 750 with that low revving engine, but it'll keep you on the road.
moonzoomer
PostPosted: 22:44 - 29 Mar 2015    Post subject: Reply with quote
What a shower of sneaky rice grinding bastards Mr Honda are
ScaredyCat
PostPosted: 23:33 - 29 Mar 2015    Post subject: Reply with quote
Are you doing it yourself?
£184.69 is the dealer price...
... plus fitting...
For an inexpensive bike to run it's fucking expensive to run...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
cyclistbruce
PostPosted: 07:49 - 30 Mar 2015    Post subject: Reply with quote
Thanks all, so how much difference would having one less tooth on the front sprocket make? I use the bike as a work bike, so it gets a lot of heavy use, but can't afford for it to be off the road!
On an aside, I worked at an event yesterday, before I rode home loosened the wheel nut, took up the last bit of tension, forgot to tighten the wheel nut and rode 150 miles back home. When I got home the spindle was almost completely out! Squeaky bum moment! Lesson learnt!
PostPosted: 08:01 - 30 Mar 2015    Post subject: Reply with quote
Depends. I found it improved my GS by putting it back closer to the gearing that it was designed for and fixing an annoying gap between 1st and 2nd.
16 teeth on the front is good enough for the NC700, it'll work OK with your 750. Your fuel economy will likely drop a tiny bit (I lost about 2mpg according to Ze Computer) and you'll lose a few mph at the top end. I'd say "just shift up earlier", but it's an NC, that goes without saying. Wink
Are your sprockets badly worn, or is it just that the chain has stretched? You don't have to replace them as a unit, although it'd be better if you did.
cyclistbruce
PostPosted: 23:18 - 30 Mar 2015    Post subject: Reply with quote
The rear sprocket is quite worn, so I'll assume the front is as well... I'll report back if I notice a significant difference in performance....
The last post was made 11 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 69.69 Kb
